Pulley rotational speed in block and tackle
In summary, the rotational speed of each sheave wheel can be determined by solving an equation for the length of rope that passes each pulley.
KentVibEngineer
For the pictured block and tackle system, formulate an equation to solve for the rotational speed of each sheave wheel for a given line pull speed. (ignore friction, slippage, line stretch) (Mass, force, efficiency, mechanical advantage are not the focus of this. Pulley speeds are desired for bearing fault detection by frequency spectrum analysis)
All pulley sheave diameters are same.
Numbering sheave from draw line toward fixed rope anchor, I know 1 rotates fastest and 4 rotates slowest, but I can't determine the reduction % at each wheel.
Hi Kent, :welcome:
PF rules dictate that you make an attempt at solution. If four pulleys is confusing, try two to begin with.
BvU said:
Hi Kent, :welcome:
My actual application has 5 sets of pulleys above and below. But its not the number that is the issue, it is the complete lack of equations applicable to this topic. Sure there a tons of equations about the FORCE of pulley sets, but 2 weeks of scouring every bit of written material google can access got me nowhere.
[Mentor's note - edited to remove some discussion of the HW forum rules, which might be better in the forum feedback section]
Forget the pulleys and focus on the amount of rope passing each pulley, starting at the right. The load rises a distance X. What happens to the rightmost vertical length of rope, and what length of rope passes the rightmost bottom pulley? That gives you its speed.
Now whatever length passes that rightmost bottom pulley must also pass all the other pulleys... But there's an additional length that must pass the second pulley in the chain (the rightmost top one) because the distance between that pulley and the first (bottom right) pulley has also decreased. Keep working from right to left and the general formula will become apparent pretty quickly.
(And a historical note: I first saw this as an extra-credit problem in a high-school math class long ago. I thought it was a fun problem then, and seeing it again, think it is still is).
Related to Pulley rotational speed in block and tackle
What is a pulley rotational speed in block and tackle?
A pulley rotational speed in block and tackle refers to the speed at which the pulleys in a block and tackle system rotate. This is determined by the size and number of pulleys in the system, as well as the force applied to the rope or cable.
How is pulley rotational speed calculated?
Pulley rotational speed is calculated by dividing the speed of the load by the number of pulleys in the system. This is known as the mechanical advantage of the pulley system. For example, if a load is moving at a speed of 10 meters per second and the pulley system has a mechanical advantage of 2, then the pulley rotational speed would be 5 meters per second.
What factors affect pulley rotational speed?
The factors that affect pulley rotational speed include the size and number of pulleys in the system, the weight of the load being lifted, and the force applied to the rope or cable. Friction and the condition of the pulleys can also impact the rotational speed.
How does pulley rotational speed impact the efficiency of a block and tackle system?
The higher the pulley rotational speed, the more efficient the block and tackle system will be. This is because the load can be lifted or moved at a faster rate, reducing the amount of time and effort required. However, if the rotational speed is too high, it can cause wear and tear on the pulleys and decrease the overall efficiency of the system.
Can the pulley rotational speed be increased?
Yes, the pulley rotational speed can be increased by increasing the mechanical advantage of the system. This can be done by adding more pulleys or using larger pulleys. However, it is important to consider the weight of the load and the strength of the rope or cable being used to ensure the system can handle the increased speed and force.
