Pulley with 2 Blocks on an Inclined Plane. Help please
In summary, a Homework Statement tells the reader about a problem the writer is having. The writer asks for help on completing the problem, and provides equations to help solve the problem. The writer does not follow my suggestion of drawing free body diagrams for each of the masses, and showing the forces acting on each of them. The writer is still confused.
BioCat
I've been stuck on this problem for hours now. I know it has to be somewhat simple, but I am not too great in physics, so I am asking for help on how to complete this problem.
Two blocks are positioned on surfaces, each inclined at the same angle 50 degrees with respect to the horizontal. The blocks are connected by a rope which rests on a frictionless pulley at the top of the inclines as shown, so the blocks can slide together. The mass of block B is 4.5kg, and the coefficient of friction for both blocks and inclines is .75. Assume gravity is g=10m/[itex]s^{2}[/itex]
Here is the closest picture I can find of it. Its basically the same thing except it is an isosceles triangle.
e3923ac4-5917-484c-afb5-f43f704edec8.jpe
What must be the mass of block A if both blocks are to slide to the right at a constant velocity?
What must be the mass of block A if both blocks are to slide to the left at a constant velocity?
From all of the info I found online and in books, these are equations that I thought might be needed.
F=ma
Ff=μFn
T=mg? (I am not exactly sure how to get tension..)
Assuming the acceleration is 0, i got 0=Fg+Fn+Ff+T
Fgx=mgsin(θ)
Fgy=mgcos(θ)
So according to above, does Fgy=Fn?
And is T equal for both sides? I am unsure how to set up an equation where I can find which side the blocks are sliding based on the mass of block A. Please help!
Hi Biocat. Welcome to Physics Forums!
For a rope passing over a frictionless pulley, how does the tension of the rope on mass A compare with the tension of the rope on mass B?
In a problem like this, it is best to resolve all the forces into components in the directions parallel and perpendicular to the inclines. This will make it easier to get the normal and frictional forces. Do a free body diagram on mass A, and another free body diagram on mass B. In these free body diagrams, show all the components of the forces acting on the masses in the directions parallel and perpendicular to the inclines. If the blocks are sliding to the right, what direction are the frictional forces on the blocks acting? If the blocks are sliding to the left, what direction are the frictional forces on the blocks acting?
Chet
Well, I thought that tension was equal on both sides, is that correct? So if the equation T=mg is right, then wouldn't that mean the mass is the same on both sides? That is obviously not that right answer though, so I am not sure what to do.
For the directions, would i have to change the signs of the coefficient of friction? So to the left would be negative, and the right, positive?
Yes.
Yes. But the equation is not correct.
You haven't followed my suggestion of drawing a free body diagram for each of the masses, and showing the forces acting on each of them. That is what to do.
No. The coefficient of friction is always positive. But, the direction of the frictional force exerted by the inclines on each of the masses would change. Until you draw your free body diagrams, you are going to continue to remain confused.
Chet
I would first recommend that you take a step back and review the basics of inclined planes, pulleys, and the equations you have listed. It is important to have a solid understanding of the concepts before attempting to solve a problem.
Now, to answer your questions specifically:
1. What must be the mass of block A if both blocks are to slide to the right at a constant velocity?
In order for both blocks to slide to the right at a constant velocity, the net force on both blocks must be zero. This means that the force of friction must be equal to the force of gravity pulling the blocks down the incline. Using the equation Ff=μFn, we can set this up as:
Ff = μmgcos(θ) = mg sin(θ)
Solving for the mass of block A:
mA = mB μcos(θ)/sin(θ)
2. What must be the mass of block A if both blocks are to slide to the left at a constant velocity?
Similarly, in order for both blocks to slide to the left at a constant velocity, the net force on both blocks must be zero. This means that the force of friction must be equal to the force of gravity pulling the blocks down the incline. Using the equation Ff=μFn, we can set this up as:
However, in this case, the force of friction will act in the opposite direction, so we need to take the negative value:
Ff = -μmgcos(θ) = mg sin(θ)
mA = mB -μcos(θ)/sin(θ)
I highly recommend that you double check these equations and solutions, and also try to understand the underlying concepts behind them. Good luck!
Related to Pulley with 2 Blocks on an Inclined Plane. Help please
1. How does a pulley with 2 blocks on an inclined plane work?
A pulley with 2 blocks on an inclined plane works by using the principles of mechanical advantage and gravity. The pulley acts as a simple machine to redirect the force of gravity, allowing a smaller force to lift a heavier object.
2. What is the purpose of using a pulley with 2 blocks on an inclined plane?
The purpose of using a pulley with 2 blocks on an inclined plane is to make lifting heavy objects easier. By using the pulley system, the weight of the object is distributed between the two blocks, reducing the amount of force needed to lift the object.
3. How does the angle of the inclined plane affect the pulley system?
The angle of the inclined plane affects the pulley system by changing the direction and magnitude of the force needed to lift the object. A steeper angle will require more force to lift the object, while a shallower angle will require less force.
4. What are the advantages of using a pulley with 2 blocks on an inclined plane?
The main advantage of using a pulley with 2 blocks on an inclined plane is that it allows for the lifting of heavier objects with less force. It also allows for the direction of the force to be redirected, making it easier to lift objects in certain directions.
5. Are there any limitations to using a pulley with 2 blocks on an inclined plane?
One limitation of using a pulley with 2 blocks on an inclined plane is that it is not as efficient as other lifting methods, such as using a lever or a hydraulic system. It also requires a longer distance to lift an object compared to other methods. Additionally, the angle of the inclined plane must be carefully calculated to ensure the system works properly.
