Pulley's-have test coming up soon-
  • Thread starter Dannystu
  • Tags
    Test
In summary: If you plug in this into the equation for object one, you will get.T=-196NNow that you know the direction of each acceleration, you can use the equations to solve for the acceleration and tension.
Dannystu
Two objects of masses, m1=10 kg and m2=20kg are connected by a cord over pulley. m1 sits on a horizontal frictionless table. The system is released and m1 accelerates to the right while m2 accelerates downward.
a.) Calculate the magnitude of the normal force exerted by the table on m1.
b.)By applying Newton's 2nd law to m1 and m2, find the two equations needed to determine the acceleration and the tension in the cord.
c.)using the equations from part a, calculate the acceleration and the tension
You do not seem to have included any work, but nonetheless I will give you a push in the right direction.
For part a) I assume you know that the normal force presses up on the object with the same force that the object presses on the table (its weight). In Newtons of course~
For part b) I believe you should first draw free-body diagrams for each, then work on finding the [tex]\sum[/tex]Fx and [tex]\sum[/tex]Fy.
That should give you an idea of what to do next.
Let us know how things move along and good luck on your test. :zzz: I'm sleepy..
Okay here goes my attempt:
a.) The object does not move on the vertical axis, so Fn=m*g
9.8*10=98
Normal force acting on object one is 98N
b.)
For object one- The only force acting on the x-axis is the tension.
So: T=m*a
For object two- I came up with
-m2g+T=m*a
c.) So, For object one T=m*a
For object two: T-mg=m*a
I used the substitution method and got a= -19.9 m/s^2 and T=-196N
I'm pretty sure I did something wrong, but I can't figure it out!
Hmm. From the way you word things it seems like you cannot check this answer online.. I have a bad track record with these types of problems as recently as last week, but I will try to give some input.
First of all, consider the direction of each acceleration. Are both acceleration in the positive direction?
The equation you used to solve for your answer was.
T-m2g=m2a
substituting in gave you.
m1a-m2g=m2a
However these equations do not take into account the direction of each acceleration.
The acceleration of m2 is negative along the y-axis, see what you can change within the equation to show that the acceleration is negative along the y-axis
FAQ: Pulley's-have test coming up soon-
What is a pulley?
A pulley is a simple machine that consists of a wheel with a groove around its circumference and a rope or cable that runs along the groove. It is used to change the direction of a force and make it easier to lift or move heavy objects.
How do pulleys work?
Pulleys work by distributing the weight of an object across multiple ropes or cables, reducing the amount of force needed to lift the object. The pulley also changes the direction of the force, making it easier to move the object in a desired direction.
What are the different types of pulleys?
There are three main types of pulleys: fixed pulleys, movable pulleys, and compound pulleys. Fixed pulleys have a stationary axle and are used to change the direction of a force. Movable pulleys have a movable axle and are used to multiply the force applied to the rope. Compound pulleys combine both fixed and movable pulleys to create a system that can lift heavy objects with less force.
How do I calculate the mechanical advantage of a pulley system?
The mechanical advantage of a pulley system is the ratio of the output force to the input force. To calculate it, divide the weight of the object being lifted by the force applied to the rope. For example, if a 100-pound object is being lifted with a force of 20 pounds, the mechanical advantage would be 5 (100/20 = 5).
What are some real-life applications of pulleys?
Pulleys are used in a variety of everyday objects, such as elevators, cranes, and flagpoles. They are also used in exercise equipment, construction machinery, and even in the human body (such as in the muscles and tendons of the hand). In addition, pulleys are commonly used in sailing and rock climbing for hauling and rigging systems.
