Pulling down on the string connected to a whirling block on a table
The discussion focuses on the equations of motion for two blocks connected by a string, where block A moves in a circle and block B hangs vertically. The tension in the string is initially calculated using the equations T - m_a*g = m_a*a and T = m_b*ω²*R, but there are concerns about the assumptions made regarding tension at the moment of release. It is noted that the tension just before block B is released is different from the tension immediately after release due to the change in dynamics. Additionally, the use of polar coordinates for block A's motion is suggested for better accuracy in expressing acceleration. Clarification on the subscripts for the blocks is also recommended to avoid confusion.
farfromdaijoubu
A horizontal frictionless table has a small hole in its centre. Block A on the table is connected to block B hanging beneath by a massless string which passes through the hole. Initially, B is held stationary and A rotates at constant radius R with constant angular velocity \omega If B is released at t=0, what is its acceleration immediately afterward?
[tex]T-m_ag = m_aa[/tex]
[tex]T=m_b\omega^2R[/tex]
At the time of release, the equation of motion of blocks A and B T-m_ag = m_aa and T=m_b\omega^2R respectively, where T is the tension in the string. Solving for the acceleration a then gives a=\frac{m_b\omega^2R - m_ag}{m_a}. Not sure what I did wrong or what incorrect assumptions I made here...
Thanks
Welcome to PF!
farfromdaijoubu said:
Relevant Equations:: T-m_ag = m_aa
T=m_b\omega^2R
Block ##A## is the block that is initially moving in a circle. Block ##B## is the hanging block. It looks like your subscripts ##a## and ##b## should be switched if ##a## is meant to refer to block ##A## and ##b## to block ##B##.
A couple of things to consider:
(1) When block ##B## is released, the tension ##T## will "instantaneously" change from what it was just before ##B## was released. Just before ##B## is released, the tension is ##m_a \omega^2 R## because ##A## is moving in uniform circular motion before ##B## is released. But this will generally not be the tension just after ##B## is released.
(2) Block ##A## moves on a plane where polar coordinates would be appropriate for this problem. You might want to review how acceleration is expressed in polar coordinates. For example, see equation 4 here.
Likes farfromdaijoubu and Lnewqban
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
