Pulsed electromagnetic field indicator
In summary, the conversation is about creating an indicator that lights up when placed next to a pulsed electromagnetic field. The person is considering using a small LED and the housing of a key ring flashlight for this indicator and is asking for advice on what internals would be needed to make the LED turn on when placed near the field. The field in question is a medical application for bone growth stimulation and has a strength of 790 milligauss with pulses at 3.8 kHz and 350 pulses per second. Suggestions are given for using a pickup coil and soundcard, as well as purchasing a gauss meter. The person is considering the Elf Zone reader, which has a peak sensitivity in hertz, and is asking for advice on whether this will
Trikemenace86
I just found this forum and would love some help on creating an indicator that lights up when placed next to a pulsed electromagnetic field. I'm thinking a small LED that lights up when placed near a pulsed electromagnetic field to confirm the electromagnetic field is active.
How would I design this? I would like to use the housing of a small key ring flashlight with an LED in it.
My question is what internals would I need to create the LED to turn on simply by placing the unit near a pulsed electromagnetic field?
Thanks for the help guys
Welcome to the PF.
What is the source of the field? How strong is it, and what is the center frequency? How often is it pulsed? If you hold an AM radio next to it, can you tune the radio to hear the pulses? Or maybe an FM radio?
It is a medical application for use as a bone growth stimulator to promote healing of bone fractures.
My interest is in proving that the unit is actually functioning and emitting a pulse. If I can show this visually by lighting an LED then I'm happy.
To answer your questions:
The pulsed electromagnetic field strength is 790 milligauss
The pulses are 3.8 kHz per pulse and 350 pulses per second
I havn't tried the radio experiment but that's a good idea and something I will try.
Let me know what you think
Likes berkeman
Thanks for the help guys. I'm now considering buying a gauss meter. I noticed that most of them have a peak sensitivity in hertz- my device is putting out 3.8khz per pulse. Does this mean I'm going to need to purchase one of the more expensive units that reads kHz or will the $13 Elf Zone reader with LED's suffice?
Elf Zone reader: I have no idea what this will do. It could pick up stray fields in your environment or any local ghosts you may have (? :nb)). Or it may work fine.
It seems sensitive and wideband (to 10KHz)
I tried the radio experiment both AM and FM and there was no interference with either frequency. I suppose that's understandable since the frequency is 3.8khz
I guess I will buy the cheapest gauss meter (elf zone) and see if that picks up anything from the device
FAQ: Pulsed electromagnetic field indicator
What is a pulsed electromagnetic field (PEMF) indicator?
A PEMF indicator is a device used to measure and display the strength and frequency of a pulsed electromagnetic field. This type of field is created by an electrical current passing through a coil, which creates a magnetic field that can have therapeutic effects on the body.
How does a PEMF indicator work?
A PEMF indicator works by detecting the magnetic field created by the electrical current passing through a coil. The device then converts this magnetic field into an electrical signal, which is displayed on a screen in the form of numbers and/or a graph.
What are the benefits of using a PEMF indicator?
Using a PEMF indicator can help researchers and practitioners determine the strength and frequency of a pulsed electromagnetic field, which can be useful for studying the effects of PEMF on the body. It can also be used to ensure that the device is functioning properly and delivering the desired intensity and frequency of the field.
Is a PEMF indicator safe to use?
Yes, a PEMF indicator is safe to use as it does not emit any electromagnetic fields itself. It simply measures the existing fields created by the electrical current passing through a coil. However, it is important to follow safety guidelines and use PEMF devices only as directed by a healthcare professional.
Are there different types of PEMF indicators?
Yes, there are various types of PEMF indicators available on the market, ranging from basic handheld devices to more advanced computerized systems. Some may also have additional features such as data storage and analysis capabilities. The type of PEMF indicator needed will depend on the specific research or therapeutic purpose.
