Pump probe spectroscopy as linear process away from equilibrium
In summary, the conversation is about generating theoretical pump probe spectroscopy data and the use of third order time dependent perturbation theory and linear absorption in non-equilibrium systems. The person is looking for papers or textbooks that discuss this formalism and is directed to an article by Prof. Wolfgang Domcke.
qu_bio
Greetings everyone,
I have recently been trying to generate some theoretical pump probe spectroscopy data. The typical way to do this is via third order time dependent perturbation theory and applying phase matching approximations / Rotating wave approx etc etc.
There is however, no reason one cannot simply consider the state of the system after interacting with the first (strong) pump pulse and then looking at linear absorption in the non-equilibrium system $\rho_{eq} \to \rho_{neq}(t)$.
Naturally this has a few issues with the system actually evolving while the probe is interacting, but this pulse is considered short so it isn't a problem.
I was wondering if anyone can suggest any papers / textbooks that work through this formalism for absorption spectroscopy?
That seems to be what I was looking for, many thanks.
Related to Pump probe spectroscopy as linear process away from equilibrium
What is pump probe spectroscopy?
Pump probe spectroscopy is a technique used in physics and chemistry to study the dynamics of systems away from equilibrium. It involves the use of two laser pulses, the "pump" and "probe," which are used to excite and probe the system, respectively.
How does pump probe spectroscopy work?
In pump probe spectroscopy, the pump pulse is used to excite the system to a higher energy state, while the probe pulse is used to measure the changes in the system's properties. By varying the time delay between the two pulses, the dynamics of the system can be studied.
What types of systems can be studied with pump probe spectroscopy?
Pump probe spectroscopy can be used to study a wide range of systems, including chemical reactions, biological processes, and materials such as semiconductors and nanoparticles. It is particularly useful for studying systems in non-equilibrium conditions, such as those found in biological systems or during chemical reactions.
What are the advantages of using pump probe spectroscopy?
One of the main advantages of pump probe spectroscopy is its ability to study systems in real time, providing detailed information about the dynamics of the system. It is also a non-destructive technique, allowing for multiple measurements to be taken on the same sample.
What are some applications of pump probe spectroscopy?
Pump probe spectroscopy has a wide range of applications in various fields, including chemistry, physics, materials science, and biology. It can be used to study the dynamics of chemical reactions, investigate the properties of materials, and understand biological processes at the molecular level.
  • STEM Academic Advising
  • Beyond the Standard Models
  • Astronomy and Astrophysics
