Pump with intake and compression using different pressure ratios
In summary, the conversation discusses the concept of using a larger cylinder-piston combo and a smaller one to create an efficient compression design. The process involves moving the larger cylinder, filling it with vacuum, then pumping in air using the smaller cylinder isothermally with a variable expansion ratio. The efficiency of the design is dependent on factors such as adiabatic losses, friction losses, capital cost, and operating cost. The conditions necessary for isothermal and adiabatic compression are also discussed, along with the need for correct equations and calculations to accurately assess the efficiency. The conversation also mentions the use of a gas container to maintain high inlet pressure and the potential for negative efficiency due to heat flow in the cylinders. Additional research and calculations
goran d
32
Lets say we got a larger cylinder-piston combo and a smaller one.
First we move the larger cylinder, filling in with vacuum. Then we pump in air, using the smaller cylinder, isothermally, with variable expansion ratio.
Here, we clearly have exp ratio > P_atm/P_final
We then compress the larger cylinder isothermally, this time
we have exp ratio = P_atm/P_final
Thus we have gained energy from the air, or so it seems?
This is because work of isothermal expansion is proportional to ln(exp ratio)
Any piston that compresses isothermally must do so at low speed. A practical reality of low speed operation is that mechanical friction losses and leakage losses become a larger percentage of the total work. There is a speed that minimizes both adiabatic losses and mechanical friction losses, for the best compression efficiency. At that speed, the compression cylinder is "large", thus expensive. The most economical compression design trades off adiabatic losses, friction losses, capital cost, and operating cost to get minimum net present operating cost.
For an example of the reverse situation, search Atkinson cycle engine. The Wikipedia hit is a good place to start.
Then study some thermodynamics until you understand that you are trying to invent, if not a perpetual motion machine, a cycle better than the Carnot cycle (search that term also).
Do all of that until you can discuss your cycle using the correct equations, and calculating the efficiency relative to both isothermal and adiabatic compression. Do this while recognizing that your design cannot do perfect isothermal or adiabatic compression. Include pressure - temperature - time curves for your cycle, isothermal compression, and adiabatic compression. Discuss the conditions necessary to get isothermal and adiabatic compression, with calculations.
If you spend sufficient time studying the above, show us your work and we can help you proceed further.
Likes phinds and berkeman
I do get net work with adiabatic compression, but only if the large cylinder is kept under environment temperature during the fill phase. If the heat is left to build up freely, negative work done.
It is relatively inefficient with 60L large cylinder and 1L small.
To make it efficient a gas container for keeping the inlet pressure high can be used, but it will have to be huge!
At one atmosphere its about 1.5KW with two alternating phase 1L small cylinders and one larger 60L one.
I guess it would need a 3-4 K drop in the large cylinder due to high volume (drop at the fill in phase), hopefully it still works then.
You still need to do this.
Then you have an energy flow that must be included in your calculations.
Wrong. See above for why it's wrong.
It seems that to get 10K drop in a 1L small cylinder it needs to have area of 6m^2.
About the large cylinder, to be able to do sufficient heat exchange area can be similar.
Note that "everything" is isothermal except the compression.
So it is outputting air hotter than the environment, while doing work.
But the heat is flowing in through a heat exchanger in the cylinders.
Technically that makes the efficiency negative even though its doing work since the heat is flowing from colder to hotter air.
FAQ: Pump with intake and compression using different pressure ratios
1. What is a pump with intake and compression using different pressure ratios?
A pump with intake and compression using different pressure ratios is a type of pump that is designed to increase the pressure of a fluid by using an intake process and compressing it at different pressure levels. This allows for the fluid to be pumped at a higher pressure than it was originally at.
2. How does a pump with intake and compression using different pressure ratios work?
The pump works by first drawing in the fluid through an intake process, which increases the pressure slightly. Then, the fluid is compressed at different pressure levels, increasing the pressure even further. This process continues until the desired pressure is reached and the fluid is pumped out.
3. What are the benefits of using a pump with intake and compression using different pressure ratios?
There are several benefits of using this type of pump. First, it allows for a higher pressure output, making it useful for pumping fluids over long distances or to higher elevations. It also reduces the risk of cavitation, which can damage pumps and decrease their efficiency. Additionally, it can handle a wide range of fluid viscosities and is more energy efficient than other types of pumps.
4. What are some common applications of a pump with intake and compression using different pressure ratios?
This type of pump is commonly used in industries such as oil and gas, chemical processing, and water treatment. It is also used in municipal water systems, irrigation, and firefighting. It can be used for pumping a variety of fluids, including water, oil, and chemicals.
5. How do I choose the right pump with intake and compression using different pressure ratios for my application?
Choosing the right pump depends on factors such as the type of fluid being pumped, the required pressure and flow rate, and the operating conditions. It is important to consult with a pump expert to determine the best pump for your specific application.
