Pumping Bicycle tire: Find volume, work done, temperature
In summary, the problem involves compressing a liter of air at atmospheric pressure to 7 atm adiabatically. The final volume, work done, and final temperature are to be determined. The ideal gas law and the assumption of quasistatic compression are used to find the final volume, which is approximately 0.25 liters. The work done is found using the equation W= \int_{V_i}^{V_f} P dV, but there is disagreement on the correct method to use. Using the high school method, the final temperature is calculated to be 522 K, which seems unreasonable. However, using the first law of thermodynamics and the equipartition theorem, the final temperature is found to be
Edge Of Pain
Daniel Schroeder, introduction to thermal physics problem 1.36 (page 26):
"In the course of pumping up a bicycle tire, a liter of air at atmospheric pressure is compressed adiabatically to a pressure of 7 atm. (Air is mostly diatomic nitrogen and oxygen.)
a) What is the final volume of this air after compression?
b) How much work is done in compression the air?
c) If the temperature of the air is initially at 300K, what is the temperature after compression?
Also, can anyone tell me how to properly write things as fractions in LaTeX? I'm finding that \frac is annoying to use.
Ideal gas law, given by [tex] PV = NkT. [/tex]
Assuming quasistatic compression, so for work done we can use [tex] W= \int_{V_i}^{V_f} P dV. [/tex]
For adiabatic + quasistatic processes, we know that [tex] VT^{f/2} = constant. [/tex]
It also follows that [tex] PV^{(2+f)/f} = constant. [/tex]
To make things simpler to write, let [tex] \gamma := (2+f)/f. [/tex]
First law of thermodynamics might help, too. That's [tex] \Delta U = Q + W. [/tex]
Equipartition theorem: For a system at temperature T, each quadratic degree of freedom has energy [itex] {(1/2)} (fkT). [/itex]
a) doesn't trouble me, but b) does, and for c) there seem to be two methods that disagree with one another. I'll put all my working for all three of them anyway.
a) To find final volume, we recall that for an adiabatic, quasistatic process (which, according to Schroeder, is a fairly accurate approximation of real-life processes), we have [itex] PV^{(2+f)/f} = constant. [/itex] Since we know initial pressure, final pressure, and initial volume we should be able to find final volume fairly quickly, it's just rearrangement. Since the product of pressure and volume is constant it follows that initial pressure times initial volume raised to the power of gamma must equal final pressure times final volume raised to the power of gamma.
That is, [tex] P_i V_i^{\gamma} = P_f V_f^{\gamma} . [/tex]
Using logarithms and exponentiation of both sides gives that [tex] V_f = ((P_i V_i^{\gamma})/P_f)^{1/\gamma} .[/tex]
Substituting numerical values after unit conversion (1 atmosphere is 10^5 pascals, 1 liter is 0.001 cubic metres, degrees of freedom f = 5 for a diatomic gas at room temperature) gives that [tex] V_f = 2.49*10^{-4} m^{3} [/tex] or about 0.25 liters.
b) We must find the work done in compressing the air. We will use [tex] W= \int_{V_i}^{V_f} P dV. [/tex]
Now, since it's not an isothermal process we can't just use P = NkT/V in the integral. We need to use that [itex] PV^{\gamma} = constant. [/itex] So, it would follow that for an arbitrary P and corresponding V, we have that [tex] PV^{\gamma} = P_i V_i ^{\gamma}. [/tex] We should also be able to use P_f and V_f instead, it would give us the same result since the product of them is constant.
But according to a solution I found this is wrong, and you should instead use [itex] PV_i^{\gamma} = P_i V^{\gamma}, [/itex] then rearrange for P and put this into the integral. What?! That seems completely wrong since the values of P_i and V_i aren't corresponding to the right values of P and V. Blindly trusting the [itex] PV_i^{\gamma} = P_i V^{\gamma} [/itex] rearrangement and plugging it into the integral gives work done as about 40 Joules. But I don't care about getting the right answer until I understand why [itex] PV_i^{\gamma} = P_i V^{\gamma} [/itex] is correct.
c) We must find the final temperature due to the changes in volume and pressure, given that initial temperature T_i = 300 kelvin.
The high school method which I completely forgot about, but do understand, is one method of doing it. That is, we know that Boltzmann's constant k and number of molecules N are constant. So, [tex] P_i V_i = NkT_i [/tex] and [tex] P_f V_f = NkT_f, [/tex] so it follows that [tex] (P_i V_i )/T_i = (P_f V_f) / T_f. [/tex] Substituting numbers in and rearranging gives an answer of 522 kelvin, which seems ridiculous. It doesn't seem right that pumping a bicycle tire increases its temperature by over 200 degrees.
The other method, the one I thought to use gives an apparently wrong answer. I used the first law of thermodynamics. We invoke [tex] \Delta U = Q + W. [/tex]
Now, it's an adiabatic process so the compression was fast enough to not allow any heat to escape during. So we can set Q to 0. Now we have [tex] \Delta U = W. [/tex]
For change in internal energy, recall the equipartition theorem: For a system at temperature T, each quadratic degree of freedom has energy [itex] {(1/2)} (fkT). [/itex] In this case we have a system with N molecules so we just multiply this by N to get the total internal thermal energy. The change in energy is provided entirely by the change in temperature, so we have [tex] \Delta U = (1/2) (Nkf) \Delta T. [/tex]
We now have that [itex] (1/2) (Nkf) \Delta T = W. [/itex]
Problem is that we don't know what N is. No matter, we know from the ideal gas law that [itex] P_i V_i = NkT_i [/itex] and [itex] P_f V_f = NkT_f [/itex]. So we can rearrange for Nk. We get [itex] (P_i V_i) / T_i = Nk [/itex]. We now substitute this in for Nk in [itex] (1/2) (Nkf) \Delta T = W, [/itex] to get [tex] ((P_i V_i) / T_i) * 0.5 *f * (T_f - T_i) = W. [/tex] Rearranging gives T_f = 348 kelvin, which seems far more reasonable. But both methods seem to be correct, so why do they disagree?
Thank you for taking the time to read my wall of text.
Hint, the auto-ignition temperature of diesel fuel is 210 deg C (483 K), and diesel engines usually require a compression ratio of at least 14 for autoignition to occur reliably.
I'm sorry but I'm not sure how this relates to the problem unless I'm missing something.
Your problem about how compression ratio is related to heating.
The diesel engine provides an experimental example where a certain compression ratio is required to reach a certain temperature. It provides a reality check which can help you determine which of your two methods is incorrect.
I'm just going through this textbook "Introduction to Thermal Physics" by Daniel Schroeder and I've not come across compression ratios or diesel engines yet. Also, no heating actually happened. Work was done, increasing the temperature, but no "heat" was added or removed.
On the algebra, I agree with you... ##PV^{\gamma}## should be constant, giving a temperature ratio of about 7/4.
From personal experience, which is far from adiabatic, 348K and 40J are too low.
@Chestermiller , any comment?
Likes Edge Of Pain
I agree with you and with Edge of Pain. He correctly assessed that the equation given in the "accepted solution" is incorrect. Regarding the 522 versus the 348, the 522 is correct. The first law equation he used to get the final temperature is just the integrated version of the differential equation that led to the 522 value. I wonder what value he got for the work when he used the correct equation between P and V? I wonder what value that would have given for the final temperature. The final temperatures calculated the two different ways have to agree.
Chet
Likes Edge Of Pain
Chestermiller said:
I agree with you and with Edge of Pain. He correctly assessed that the equation given in the "accepted solution" is incorrect. Regarding the 522 versus the 348, the 522 is correct. The first law equation he used to get the final temperature is just the integrated version of the differential equation that led to the 522 value. I wonder what value he got for the work when he used the correct equation between P and V? I wonder what value that would have given for the final temperature. The final temperatures calculated the two different ways have to agree. Chet
OK, so I should use a rearrangement of [itex] PV^{\gamma} = P_i V_i ^{\gamma} [/itex] in part b)? If so that makes me happy because it fits with what I understand. But I got gamma as 7/5 rather than 7/4 because diatomic at room temperature => f = 5.
I will now find the work done using the right equation for part b) and see if the work done I find leads to the two methods in part c) agreeing. I'll be back soon - I'll just edit this post with new answers if nobody replies within that time.
EDIT:
OK, with the correct equation for b), I get about 186J of work, and it leads to the two methods in part c) agreeing with each other, at 522K!
Thank you everyone, I've learned to go with what seems intuitively correct rather than abandoning my own thoughts after seeing a solution.
There doesn't seem to be an option for editing the OP. I would like to edit the OP with the correction at the top of the post, as I think it will be helpful for other users who see this. Can I do that?
The 7/4 value is the approximate temperature ratio, not γ.
Regarding the editing of posts, you have a certain amount of time after submitting a post to edit it. After that time expires, you can no longer edit. In this thread, I see no compelling reason for any of the posts to be edited. The existing sequence accurately reflects the history of the transition to a solution.
Chet
Likes Edge Of Pain
Related to Pumping Bicycle tire: Find volume, work done, temperature
1. How do I find the volume of my bicycle tire?
To find the volume of your bicycle tire, you can use the formula for the volume of a cylinder: V = π * r^2 * h, where r is the radius of the tire and h is the height (or thickness) of the tire. Measure these values and plug them into the formula to calculate the volume.
2. What is the work done when pumping a bicycle tire?
The work done when pumping a bicycle tire is the energy transferred from the pump to the tire to increase its pressure. This can be calculated using the formula W = F * d, where F is the force applied and d is the distance over which the force is applied. You can measure the force applied by the pump and the distance the handle is pulled to determine the work done.
3. How does pumping a bicycle tire affect its temperature?
Pumping a bicycle tire can cause a slight increase in its temperature due to the compression of the air inside. As the air molecules are compressed, their kinetic energy increases, leading to a rise in temperature. However, this temperature change is usually very small and not significant enough to cause any damage to the tire.
4. Does the type of pump used affect the volume and work done when pumping a bicycle tire?
Yes, the type of pump used can affect the volume and work done when pumping a bicycle tire. A hand pump, for example, may require more force and distance to pump the same amount of air as a foot pump, leading to a higher work done. The type of pump can also affect the accuracy of the volume measurement, as some pumps may have a smaller or larger chamber for air compression.
5. How often should I pump my bicycle tire?
It is recommended to check and pump your bicycle tire at least once a week, or before every ride. The more you ride your bike, the more often you may need to pump your tires. It is important to maintain proper tire pressure for optimal performance and to prevent damage to the tire.
