Purified filtered water pitcher worse than regular water?
In summary: If you're fortunate enough to live here, I think you may be an exception...If you're living in an area where the water is especially clean, then you may not need a filter.
ppppparker
I bought a water pitcher that purifies water. It supposedly filters out a lot of contaminants like lead. (It doesn't filter out fluoride but I knew this before I got it)
It came with a little warning sticker saying that its important to use the product as specified, other wise you will be at risk of contaminants.
So now I'm wondering if these filter systems do more harm than good. Does anyone have experience about this?
fyi I'm just talking about a water pitcher with a filter mechanism in it, which I use when I'm at school, this isn't like a water purification "system" or anything .. its just a cheapo $20 filtered water pitcher I got on amazon (its pretty popular).
Do you think I'm making big deal out of the warning sticker it came with? or what? thanks
The problem with these devices (and I've had Brita for years till recently) is that you MUST replace the filters as required by the manufacturer. Otherwise, the charcoal activation, or whatever the mechanism they use to clean the water, will not be useful beyond a certain number of usage or period of time. Then, depending on your usage, the filter might be a harbor for bacteria, etc.
If you use it according to the instruction, then there isn't a problem.
Zz.
Likes collinsmark
yup that's the same brand I got its a "Brita Everyday Water Filter Pitcher, 10 Cup". I get what your saying about filter.. if you don't replace it then the filter is pointless. But also my general question is do you think using this filtered water is safer or healthier than water that comes out of the faucet? you said you used Brita for years until recently, so has your opinion changed about filtered water or are britas not very good or something? thanks
Absolutely, it offers an extra layer of filtering over the water treatment done in the municipal plants. I don't think the FDA would approve their sale if they lowered the quality of the water. Even if they didn't improve the quality of the water, I would use a pitcher filter anyway because drinking water straight from my tap makes me want to barf. Once you get used to filtered water, the straight tap is disgusting.
I'm not very impressed with Brita myself, but it's better than nothing. I use zero water exclusively. It's a 5 stage filter instead of Brita's 2 stage filter, I think, plus it has a device to measure the concentrations of "dissolved solids," which indicates when to change the filter. I don't think the Brita has a tester, which means you have to guess when to change it. As ZapperZ said, the important thing to be vigilant of if you don't want the filter to end up working against you at some point is to change it when it's time to do so.
http://www.naturalnews.com/046536_water_filters_heavy_metals_lab_results.html
Depends on where you are. Being in the Swiss Alpes it's probably better to drink the water as it flows out of the faucet.
I always wonder if those filters also extract all the minerals which we need.
Likes billy_joule
Well, if you're fortunate enough to live here, I think you may be an exception...
For the rest of us, though, I'd suggest getting a zero water filter..:oldsmile:
Likes Mostafa1978
I always thought that those water filters were, uh, ineffective. The rate of flow is too high. The percentage of the water that actually comes in contact with the filter surface is low. Also, the variety of contaminants is large.
I suspect that most people don't replace the filters very often.
When backpacking and so forth I use a water filter to get rid of bacteria, but that's easy because bacteria are so big.
In Bali I lived next to a spring and drank water straight out of the ground. It tasted SO good. Holy water is a very big deal in Bali. Indeed, I suspect that this was one of the main things that attracted settlers: the prevalence of springs as a source of pure water. They're everywhere. There are two ancient craters that serve as natural reservoirs and the water filters many a mile through the soft, porous rock.
Likes Mostafa1978
Related to Purified filtered water pitcher worse than regular water?
1. Why is purified filtered water pitcher worse than regular water?
Purified filtered water pitchers may not necessarily be worse than regular water. It depends on the source and quality of the water being filtered. Some people may perceive a difference in taste, but this does not necessarily mean that one is better than the other.
2. Is purified filtered water pitcher less healthy than regular water?
No, purified filtered water pitchers typically remove impurities and contaminants from the water, making it safer to drink. Regular tap water may contain traces of chemicals or bacteria, which can be harmful to one's health.
3. Can purified filtered water pitcher remove all impurities?
No, while purified filtered water pitchers are effective in removing many impurities such as chlorine, lead, and other pollutants, they may not be able to remove all impurities. Some contaminants may require more advanced filtration methods.
4. Is purified filtered water pitcher more expensive than regular water?
Purified filtered water pitchers can be more expensive upfront, as they require the purchase of the pitcher and replacement filters. However, in the long run, they may be more cost-effective compared to regularly purchasing bottled water.
5. How often should I replace the filter in a purified filtered water pitcher?
The frequency of filter replacement depends on the brand and type of filter being used. It is typically recommended to replace the filter every 2-3 months or after filtering a certain amount of water. It is important to follow the manufacturer's instructions for proper maintenance and replacement of the filter.
  • Materials and Chemical Engineering
  • Chemistry
  • General Discussion
39K
41K
  • DIY Projects
