UR_Correct
- 37
I've been doing a project with condenser microphones, and I came across a schematic (see attached). I was wondering what some of the components do.
I know the 10uF cap across pins 1 and 8 are used to set the gain (just cap makes maximum gain) of the LM386. I was told the 470uF cap is used as a decoupling capacitor. From my understanding, this means it tries to disassociate the pin it's connected to from the rest of the circuit (i.e., quick changes won't affect that input). Does the 100uF cap next to the 10k steady the voltage to the microphone? Is the 220nF cap just standard when you hook up an electret? I've seen simpler schematics without the amplifier that usually connect like a 10uF straight to the microphone output.
And the 100k variable resistor; is that just for helping with gain also? Is it used to bias the amp? Are the 1k and 10k just used to limit the current to the mic?
I fear I might be wrong on all these explanations, so I figured I'd ask the wise folks here. Hopefully you guys can clear up my uncertainty. Thanks in advance for any help,
Mike
Mike
