Putnam Solution (Differential Calculus)
In summary, we have a function $f: \mathbb{R} \rightarrow \mathbb{R}$, where the derivative is defined as $f'(x) = \frac{f(x+n) - f(x)}{n}$ for all real numbers $x$ and positive integers $n$. The slope of the tangent line to the graph of $f(x)$ is denoted as $m$ and we can find points $(x, y)$ and $(x_1, y_1)$ such that $x_1 > x$ and $x_1 - x = n$. Using the difference in $y$ values, we can rewrite the equation of a line as $y - y_1 =
Amad27
412
Hello,
From the 2010 Putnam A2
Find all differentiable functions such that
$$f: R \implies R$$
$$f'(x) = \frac{f(x+n) - f(x)}{n}$$
For all real numbers $$x$$ and POSITIVE Integers $$n$$
Let "m" be the slope of the tangent line to the graph of f(x).
Let there be points, $$(x, y) (x1, y1)$$ such that
$$x1 > x, (x1 - x) = n$$
$$ \Delta y = f(x + n) - f(x)$$
$$y1 - y1 = \Delta y$$
$$ y - y1 = m(x - x1)$$ [equation of a line]
$$f(x + n) = m(x -x1) + f(x) $$
$$f'(x) = \frac{f(x + n) - f(x)}{x - x1} $$
$$f'(x) = \frac{m(x - x1)}{(x - x1)} $$
$$f'(x) = \frac{m}{1} = m$$
So we proved the slope is "that," now we need to prove this is a line. By definition,
$$f''(x) = \lim_{{h}\to{0}}\frac{f'(x+h) - f'(x)}{h}$$
$$f'(x) = m$$ [we proved]
$$f''(x) = \lim_{{h}\to{0}}\frac{(m-m)}{h} = \lim_{{h}\to{0}}\frac{(0)}{h}$$
The only issue is the $$\lim_{{h}\to{0}}$$ we can't direct substitute in the remaining fraction.
IS IT LEGAL TO DO THE FOLLOWING:
$$\lim_{{h}\to{0}}\frac{(0)}{h} = \lim_{{h}\to{0}}0$$
Because the 0/h takes care of it being 0, but the problem is can I do this? Without direct substitution. IF YES,
$$f''(x) = 0$$
We know the second derivative is 0, this means the first derivative doesn't change in slope, the slope f'(x) is a HORIZONTAL LINE, it is CONSTANT.
If the FIRST derivative is constant, the equation is a line. We use point slope form now.
The line we have passes through (h, k) so we get,
$$y - k = m(x - h) \implies y = mx - mh + k$$
Let $$C = k - mh$$ therefore,
$$y = mx + C$$
Hi Olok,
You can't just substitute $f'(x+h)=m$ here.
As it is, both numerator and denominator tend to 0, so there is still something to figure out.
You are on the right track though.
What if you evaluate your $f''(x)$ in 2 different ways with the given relationship?
Is it legal to do the following:
This is legal.
(No need to SHOUT.)
I like Serena said:
Hi Olok,
This is legal.
(No need to SHOUT.)
I can't evaluate $f''(x)$ is two different ways though.
$f'(x) = m$ so that is the ONLY case.
Why can't we substitution $f(x + h) = m$?
Oh wait, because it is the indeterminate form (after you do two direct subbings).
What else do you suggest. Also,
What was the second way of finding $f''(x)$?
What do you get if you substitute $f'(x+h) = f(x+h+1)-f(x+h)$ respectively $f'(x) = f(x+1)-f(x)$?
I had a question instantly when I saw this. How do you say
$f'(x+h) = f(x+h+1) - f(x+h)$ In other words, how do you derive this result?
The same for
$f'(x) = f(x+1) - f(x)$, how did you derive this result here?
For the first one, is this related to what you did:?
$f'(x) = [f(x + h) - f(x)]/h$
$f'(x+h) = [f(x + 2h) = f(x + h)]/h$
?? Any relation?
The same for
You stated in your problem statement that:
$$f'(x) = \frac{f(x+n)-f(x)}{n}$$
for any $x$ and any integer $n$.In particular that means for $n=1$ that:
$$f'(x) = \frac{f(x+1)-f(x)}{1} = f(x+1)-f(x)$$
And since it holds for any $x$, it will also hold for $x+h$, meaning:
$$f'(x+h) = \frac{f((x+h)+1)-f(x+h)}{1} = f(x+h+1)-f(x+h)$$
?? Any relation?
This comes after, together with \(\displaystyle \lim_{h\to 0}\).
Hi Olok,
If you want to solve this problem, then I suggest using the condition
$\displaystyle (*) f'(x) = \frac{f(x + n) - f(x)}{n}$
(which holds for all $x\in \Bbb R$ and $n\in \Bbb N$) to show that $f'$ is 1-periodic. That is, show that $f'(x + 1) = f'(x)$ for all real $x$. After showing this, you may deduce that $f(x + 1) - f(x)$ is a constant function. On the other hand, setting $n = 1$ in $(*)$ yields $f'(x) = f(x + 1) - f(x)$ for all real $x$. Therefore $f'$ is constant. What then can you say about $f$?
Hello,
This was helpful.
The Problem is this is for a special case $n=1$ we need to consider all real positive integers "n"
Euge said:
Hi Olok,
Hi there,
From the definition of periodic, I can see that if something has a period of 1 then for each one it moves it is the same shape, same place etc.. So
[a, b] it has the shape $Q$ suppose it is periodic 1. [b, c] it still has the shape $Q$ assuming $c = b + 1$
What does the period of the first derivative have anything to do with f(x+1) - f(x) being constant?
How does this prove $f(x+1) - f(x)$ is constant from this?
I might be having an issue with definitions,
What is the definition of a periodic function of period = $Q$???
Also for when you state using $n = 1$, you are simply proving this for ONLY ONE $n$ we need to prove it for all positive real integers $n$.
Thanks
Hi Olok,
I don't understand what you're saying in the second paragraph, but given $p\in \Bbb R$, a function $g : \Bbb R \to \Bbb R$ is $p$-periodic if $g(x + p) = g(x)$ for all $x$. So, again, when I say $f'$ is 1-periodic, I mean $f'(x + 1) = f'(x)$ for all $x$.
If you know that $f'$ is 1-periodic, then
$\displaystyle \frac{d}{dx}(f(x + 1) - f(x)) = f'(x + 1) - f'(x) = 0$.
Since the function $f(x + 1) - f(x)$ has derivative zero, it must be constant.
You're last paragraph indicates that you're misunderstanding the Putnam question. You have to determine all differentiable functions $f : \Bbb R \to \Bbb R$ which satisfy
$\displaystyle f'(x) = \frac{f(x + n) - f(x)}{n}$
for all positive integers $n$ and real numbers $x$. So you start with a differentiable $f : \Bbb R \to \Bbb R$ which satisfies the above condition and use that condition to find what $f$ is. It will turn out that $f$ will be a linear function. Next, you must show that all linear functions satisfy the above condition. What you're suggesting is proving the condition you're assuming, which is circular reasoning.
Euge said:
Hi Olok,
Alright, that is helpful.
Therefore,
$f'(x+1) = \frac{f(x+n+1) - f(x+1)}{n}$
But the question is, how do you prove this is 1-periodic?
We must prove $f'(x + 1) = f'(x) = \frac{f(x+n+1) - f(x+1)}{n} = \frac{f(x+n) - f(x)}{n}$
I'm stuck again.
Fix $x\in\Bbb R$. For all positive integers $n$,
$\displaystyle f'(x + 1) = \frac{f(x + n + 1) - f(x + 1)}{n} = \frac{f(x + n + 1) - f(x) + f(x) - f(x + 1)}{n}$
$\displaystyle = \frac{f(x + n + 1) - f(x)}{n} + \frac{f(x) - f(x + 1)}{n}$
$\displaystyle = \frac{f(x + n + 1) - f(x)}{n + 1} \frac{n + 1}{n} + \frac{f(x) - f(x + 1)}{n}$
$\displaystyle = f'(x)\frac{n + 1}{n} + \frac{f(x) - f(x + 1)}{n}$.
Taking the limit as $n \to \infty$ yields $f'(x + 1) = f'(x)$. Since $x$ was arbitrary, $f'$ is 1-periodic.
Before I continue with this method.
I would like to put out there, this is LARGELY intuitive.
This just wouldn't strike an average person, I had no idea how you came up with this.
What made you think of this idea? Especially the
$\frac{n+1}{n}$ How did you think of this?
As an alternative, you might go back to your own:
$$f''(x) = \lim_{h\to 0} \frac{f'(x+h)-f'(x)}{h}$$
and substitute $f'(x+h)=f(x+h+1)-f(x+h)$ respectively $f'(x)=f(x+1)-f(x)$.
These substitutions are the simplest possible applications of what is given in your problem statement, so it makes sense to explore them.
Then see where this takes you...
Hi Olok,
Since the condition that $f$ satisfies involves a sequence of functions, I know that I have to take the limit of a sequence at some point. Since
for all $n\in \Bbb N$ and all $x\in \Bbb R$, in particular,
$\displaystyle f'(x) = \frac{f(x + n + 1) - f(x)}{n + 1}$
for all $n\in N$ and $x\in \Bbb R$. So in the expression
$\displaystyle \frac{f(x + n + 1) - f(x)}{n}$,
I multiply by $\frac{n + 1}{n+ 1}$ to get
$\displaystyle \frac{f(x + n + 1) - f(x)}{n + 1}\frac{n + 1}{n} = f'(x) \frac{n + 1}{n} \to f'(x)$ as $n\to \infty$.
Hello,
I am still confused, how is
$f'(x + h) = f(x + h + 1) - f(x + h)$?
From what we know,
$f'(x) = [f(x+h) - f(x)]/h$
Oh so you are considering the interval where $h = \Delta x$ = 1?
Just a question, how could the relation between the period(1) and $\Delta x$ be called?
By Period(1) I mean a period of 1.
I mean how is
Period(1) = $\Delta x$?
Olok said:
Hello,
That is because $f'(x)=f(x+1)-f(x)$ holds for any $x$.
That includes that it holds for $(x+h)$ instead of $x$.
See post http://mathhelpboards.com/calculus-10/putnam-solution-differential-calculus-11789-post55388.html#post55388.
From what we know,
This is not (necessarily) true.
It should be:
$$f'(x) = \lim_{h\to 0} \frac{f(x+h) - f(x)}{h}$$
I mean how is
Err... no. I don't know what you mean here.
Well... we can pick $\Delta x=1$ if we want to...
It should be:
But we need to prove it is true for ALL positive integers $n$. We can't just choose $\Delta x=1$
Wait I think I know what you are trying to do.
If you want to prove period-1 then you choose $\Delta x=1$
If you want to prove period-2 then you choose $\Delta x=2$
etc...?
etc...?
Erm... I'm not trying to do anything with periodicity... :confused:
That is my question, WHY can you pick delta(x) as YOUR choice?
It says prove it for all positive integers $n = \Delta x$ not just for $\Delta x = 1$
What is the logic behind this letting $n = 1$?
We begin with $n=1$ because it is the simplest case.
After we have found all solutions, we have to verify if those solutions also satisfy other $n$
... and they do.
... and they do.
Hello,
Let's try this approach, let n = 1 so
Jeez, this is tough, I just can't seem to find a next lead. =(
FAQ: Putnam Solution (Differential Calculus)
What is the Putnam Solution?
The Putnam Solution is a widely used mathematical method in differential calculus for solving problems that involve optimization and finding maximum or minimum values of functions. It was developed by mathematician George D. Birkhoff in the early 20th century and has since been used extensively in various fields of science and engineering.
How does the Putnam Solution work?
The Putnam Solution involves taking derivatives of a given function and setting them equal to zero to find critical points. These critical points are then evaluated to determine if they correspond to a maximum or minimum value of the function. The solution also takes into account the boundary conditions and any other constraints given in the problem to find the optimal solution.
When is the Putnam Solution applicable?
The Putnam Solution is applicable in any problem that involves finding the maximum or minimum value of a function, subject to certain constraints or boundary conditions. It is commonly used in optimization problems in physics, economics, engineering, and other fields of science.
What are the advantages of using the Putnam Solution?
The Putnam Solution provides a systematic and efficient method for solving complex optimization problems. It also allows for the incorporation of constraints and boundary conditions, making it a versatile tool for a wide range of applications. Additionally, the solution is often more accurate and precise compared to other methods used for optimization problems.
Are there any limitations to the Putnam Solution?
While the Putnam Solution is a powerful tool, it does have some limitations. It is not applicable to all types of functions, especially those that are not continuous or differentiable. Additionally, it may not always provide the global optimum solution, but rather a local optimum. In some cases, it may also be computationally intensive and require advanced mathematical knowledge to use effectively.
