- 15,950
- 5,963
- TL;DR Summary
- A constructor doesn't seem to be invoked when it should be.
I mentioned in another thread that I've been playing with a C++ class for 3D vectors, to review overloaded operators, constructors, etc. All those functions display output so I can follow which ones get called, and when. The class generates a serial number for each vector so I can tell them apart.
I've been puzzled by something. To illustrate it, here's a trimmed-down version of the class that contains only the operations needed for this demonstration.
First, here's a
and its output:
Vectors #1, #2 and #3 are
Vector #4 is the local variable
This all seems reasonable to me.
Now, let's combine the declaration of
Based on my (possibly faulty) memory of how C++ compilers are supposed to handle this, I expected that this would bypass
Output:
Indeed,
What is vector #3?
If it's
If it's the local
If the compiler is doing some optimization, they why is it happening only in the second program and not the first one?
C++:
class ThreeVector
private:
double x, y, z;
int serialNum; // unique for each ThreeVector instance
static int numVectors; // counts the number of ThreeVectors constructed
public:
ThreeVector (); // default constructor
ThreeVector (double, double, double);
ThreeVector (const ThreeVector&); // copy constructor
~ThreeVector ();
const ThreeVector operator+ (const ThreeVector&) const;
ThreeVector& operator= (const ThreeVector&);
friend ostream& operator<< (ostream& out, const ThreeVector& v);
int ThreeVector::numVectors = 0;
ThreeVector::ThreeVector ()
x = 0; y = 0; z = 0;
numVectors++;
serialNum = numVectors;
cout << "-- Default-constructed vector #" << serialNum
<< " containing " << *this << "." << endl;
ThreeVector::ThreeVector (double x0, double y0, double z0)
x = x0; y = y0; z = z0;
numVectors++;
cout << "-- Constructed vector #" << serialNum << " containing "
ThreeVector::ThreeVector (const ThreeVector& original)
x = original.x; y = original.y; z = original.z;
numVectors++;
cout << "-- Copy-constructed vector #" << serialNum << " containing "
ThreeVector::~ThreeVector ()
cout << "-- Destructed vector #" << serialNum << " containing "
const ThreeVector ThreeVector::operator+ (const ThreeVector& rhs) const
ThreeVector sum;
sum.x = x + rhs.x; sum.y = y + rhs.y; sum.z = z + rhs.z;
cout << "-- " << *this << " + " << rhs
<< " = " << sum << "." << endl;
cout << "Return from operator+..." << endl;
return sum;
ThreeVector& ThreeVector::operator= (const ThreeVector& rhs)
x = rhs.x;
y = rhs.y;
z = rhs.z;
cout << "-- Assigned " << *this << " to vector #" << serialNum
<< "." << endl;
return *this;
out << "(" << v.x << ", " << v.y << ", " << v.z << ")";
return out;
main()
function that works as I expected:
C++:
int main ()
cout << "Declare a and b..." << endl;
ThreeVector a(1, 2, 3), b(4, 5, 6);
cout << "Declare c..." << endl;
ThreeVector c;
cout << "Add c = a + b..." << endl;
c = a + b;
cout << "Return from main()..." << endl;
return 0;
Code:
Declare a and b...
-- Constructed vector #1 containing (1, 2, 3).
-- Constructed vector #2 containing (4, 5, 6).
Declare c...
-- Default-constructed vector #3 containing (0, 0, 0).
Add c = a + b...
-- Default-constructed vector #4 containing (0, 0, 0).
-- (1, 2, 3) + (4, 5, 6) = (5, 7, 9).
-- Assigned (5, 7, 9) to vector #3.
-- Destructed vector #4 containing (5, 7, 9).
-- Destructed vector #3 containing (5, 7, 9).
-- Destructed vector #2 containing (4, 5, 6).
-- Destructed vector #1 containing (1, 2, 3).
a
, b
, and c
in main()
. They are destructed at the end of main()
. Vector #4 is the local variable
sum
in operator+()
. It is destructed when that function finishes, after its value is assigned (copied) to c
in main()
.This all seems reasonable to me.
c
with the addition of a
and b
C++:
int main ()
cout << "Declare c and add c = a + b..." << endl;
ThreeVector c = a + b;
return 0;
operator=()
and use the copy-constructor to construct c.Output:
Code:
Declare a and b...
operator=()
was not used, but neither was the copy-constructor!What is vector #3?
If it's
c
in main()
, then why is there no vector #4 for the local sum
in operator+()
?If it's the local
sum
in operator+()
, then how does c
in main()
get constructed? Is there another constructor that I've overlooked?If the compiler is doing some optimization, they why is it happening only in the second program and not the first one?
