Puzzled by this application of L'Hospital's rule
  • Thread starter quasar987
  • Tags
    Application
In summary, the conversation discusses the application of L'Hospital's rule to evaluate the derivative of a function at a specific point. The function is defined piecewise and the textbook provides an example of how to use L'Hospital's rule to find the derivative at the point x=0. It is explained that as x approaches 0, the denominator tends to infinity faster than the numerator tends to zero, allowing for the use of L'Hospital's rule. A change of variable is also suggested to simplify the calculation.
quasar987
32
[SOLVED] Puzzled by this application of L'Hospital's rule
In an example in my textbook, they define a function f on the real line by f(0)=0 and f(x)=exp(-1/x^2) otherwise.
They then say that we can evaluate f'(0) by L'Hospital's rule, and they write
[tex]f'(0)=\lim_{x\rightarrow 0}\frac{f(x)-f(0)}{x-0}=\lim_{x\rightarrow 0}\frac{e^{-1/x^2}}{x}=0[/tex]
How did they get that?? It seems if I apply L'Hospital, I get
[tex]\lim_{x\rightarrow 0}\frac{e^{-1/x^2}}{x}=\lim_{x\rightarrow 0}\frac{-2x^{-3}e^{-1/x^2}}{1}=\lim_{x\rightarrow 0}\frac{-2e^{-1/x^2}}{x^{3}}[/tex]
and thus I'm not more advanced!
Well I guess you can say that as x tends to zero
[itex]\frac{1}{x^2}\rightarrow \infty[/itex] faster than [itex]\frac{1}{x}[/itex]
so that exp(-1/x^2) tends to zero before 1/x (from the denominator) can tend to infinity.
[itex] \lim_{x\rightarrow 0}\frac{e^{-1/x^2}}{x}= \lim_{x\rightarrow 0} \frac{x^{-1}}{e^{1/x^2}} [/itex] and now do L'Hospital's rule.
Change the variable to s=1/x. Now you have the limit as s->infinity of s/e^(s^2). Now use l'Hopital. Which is what eok is basically saying.
FAQ: Puzzled by this application of L'Hospital's rule
How does L'Hospital's rule work?
L'Hospital's rule is a mathematical theorem used for evaluating limits of indeterminate forms, typically involving fractions with a numerator and denominator that both approach zero or infinity. It states that if the limit of a ratio of two functions is indeterminate, then the limit of the ratio of their derivatives will be the same. This rule helps simplify complex limits and is a useful tool in calculus and other branches of mathematics.
When should L'Hospital's rule be used?
L'Hospital's rule should only be used when evaluating limits of indeterminate forms, which are expressions where the limit cannot be determined by direct substitution. These forms include 0/0, ∞/∞, 0*∞, ∞-∞, and 1^∞. Using L'Hospital's rule on other types of limits will not provide an accurate result.
Can L'Hospital's rule be applied multiple times?
Yes, L'Hospital's rule can be applied multiple times as long as the resulting limit remains indeterminate. However, it is important to note that blindly applying the rule without fully understanding the problem can lead to incorrect solutions. It is recommended to use other techniques, such as factoring or algebraic manipulation, before turning to L'Hospital's rule.
Are there any limitations to L'Hospital's rule?
One limitation of L'Hospital's rule is that it only applies to limits of indeterminate forms. It cannot be used to evaluate other types of limits. Additionally, it may not always work for certain types of functions, such as oscillating or discontinuous functions. It is important to carefully analyze the limit before applying L'Hospital's rule.
Can L'Hospital's rule be used to find the limit of a function at a specific point?
No, L'Hospital's rule cannot be used to find the limit of a function at a specific point. It is only used to evaluate the limit as x approaches a certain value. To find the limit at a specific point, you can use other methods such as direct substitution or graphing the function.
