PV diagram full circle cycle help
In summary, you can use the ideal gas law, PV = nRT, and the equations for work and internal energy to calculate the total internal energy, work, and heat flow in a full cycle of the system. I hope this helps and good luck with your homework!
blackdog666
I'm given a PV diagram, it goes from A, B, C, D, in a full circle, counter-clock wise. A is at the top, and is at 30 Pa and 25 m^3 for volume. B is at 20 Pa and 15 m^3. C is at 10 Pa and 25 m^3, and D is at 20 Pa and 35 m^3 (It goes in a full circle with A and C having the same volume, and B and D having the same pressure) Sorry I can't post a real picture of it. The question now asks:
Calculate:
A) The total internal energy in a full cycle from A-->B-->C-->D-->A
B) The total work done on or by the system in a full cycle from A-->B-->C-->D-->A.
C) The total heat flow in a full cycle from A-->B-->C-->D-->A
D) The work done on or by the system from A-->B-->C
PV=nRT
(delta)U = Q - W
I've thought about A, and see that in a full cycle the total change in internal energy would be 0, however I don't think that it's asking for the total change, just the total. Also for B, C, and D I'm having trouble trying to find the right equation, as I can't determine if this cycle would be isobaric, isochoric, isothermal, or adiabatic. Please help.
Thank you for sharing your PV diagram and questions with us. From your diagram, it appears that the system goes through a full cycle of four states - A, B, C, and D - with each state having different pressure and volume values.
To answer your first question, you are correct in thinking that the total change in internal energy over a full cycle is 0. This is because the internal energy of the system at state A is the same as at state C, and the internal energy at state B is the same as at state D. Therefore, the total internal energy in a full cycle is equal to the internal energy at any one state, which in this case is state A. So, the total internal energy in a full cycle from A-->B-->C-->D-->A is simply the internal energy at state A, which can be calculated using the ideal gas law, PV = nRT.
For the second question, the total work done on or by the system in a full cycle can be calculated by adding up the work done in each individual step of the cycle. From your diagram, it seems that the system undergoes a clockwise cycle, which means that the work done in the first half of the cycle (A-->B-->C) is negative, and the work done in the second half (C-->D-->A) is positive. You can use the equation W = -PΔV to calculate the work done in each step, where P is the pressure and ΔV is the change in volume. Add up the work done in each step to find the total work done on or by the system in a full cycle.
For the third question, the total heat flow in a full cycle can be calculated using the first law of thermodynamics, which states that the change in internal energy (ΔU) of a system is equal to the heat flow (Q) into the system minus the work (W) done by the system. Since the total change in internal energy over a full cycle is 0, as we discussed in the first question, the total heat flow must also be 0.
Finally, for the fourth question, the work done on or by the system from A-->B-->C can be calculated using the same equation as in the second question, W = -PΔV. In this case, you will only need to consider the work done in the first half of the cycle, as the system
FAQ: PV diagram full circle cycle help
What is a PV diagram?
A PV diagram, also known as a pressure-volume diagram, is a graphical representation of the changes in pressure and volume of a system as it undergoes a thermodynamic process. It is commonly used in thermodynamics to analyze and understand the work done by a system.
How is a PV diagram read?
A PV diagram is read by looking at the axes, where the x-axis represents the volume and the y-axis represents the pressure. The curve on the graph shows the relationship between pressure and volume, and the area under the curve represents the work done by the system.
What is a full circle cycle on a PV diagram?
A full circle cycle on a PV diagram is a thermodynamic process where the system undergoes a complete cycle, starting and ending at the same state. This can be represented by a closed loop on the PV diagram, and the area enclosed by the loop represents the net work done by the system.
How can a PV diagram help in analyzing a thermodynamic process?
A PV diagram can help in analyzing a thermodynamic process by providing visual representation of the changes in pressure and volume of the system. It can also help in determining the efficiency of the process and the work done by the system.
What are some examples of processes that can be represented on a PV diagram?
Some examples of processes that can be represented on a PV diagram are isobaric processes (constant pressure), isothermal processes (constant temperature), adiabatic processes (no heat transfer), and isochoric processes (constant volume). These processes can be combined to form a full circle cycle on the PV diagram.
