PV Diagrams (Curve v. Straight)
  • Thread starter jaysonr
  • Tags
    Diagrams
In summary, the lines on a PV diagram are curved because the pressure and temperature are not directly proportional.
jaysonr
Why are some lines on a PV digram curved and some lines are straight?
Be more specific. Give an example of a PV diagram you don't understand.
Assuming that the no gas enters or leaves, there's a third relevant variable: temperature. If you heat something, it will either expand, increase in pressure, or a little of both.
edit: There are only these 3 variables if nothing enters or leaves the system if the gas is assumed to be ideal (the molecules neither take up space nor attract each other).
That still doesn't explain why the state at (Po, To) is curved when it goes to state (0.5Po, 2Vo). If it's directly proportional, shouldn't it be a decreasing straight line slope?
Pressure and temperature are not directly proportional. PV = constant if the temperature is constant.
So how do you know if one of the lines need to be straight or need to be curved?
You can just make a back-of-the-envelope graph. For example if the temperature is constant (which would be expected if everything happens slowly and there's poor insulation) you can assume PV = 1 (although any constant would do) and then make a rough graph with P being 1/4, 1/2, 1, 2, and 4 (V would be the inverse).
That's a pretty general question, so here is a general answer.
If the line is curved, then a problem statement will either:
(1) tell you that the process is isothermal
(2) tell you that the process is adiabatic
(3) present you with a diagram that shows a curved line
or (4) provide some other information that allows you to conclude that the line is curved.
If the line is straight, then a problem statement will either:
(1) tell you that the process is at constant pressure (for a horizontal line)
(2) tell you that the process is at constant volume (for a vertical line)
(3) present you with a diagram that shows a straight line (could be horizontal, vertical, or slanted)
or (4) provide some other information that allows you to conclude that the line is straight
That is so much clearer. Thank you!
FAQ: PV Diagrams (Curve v. Straight)
What is a PV diagram and what does it represent?
A PV diagram, also known as a pressure-volume diagram, is a graph that shows the relationship between the pressure (P) and volume (V) of a gas at constant temperature. It represents the changes in pressure and volume of a gas as it undergoes a thermodynamic process.
How is a curve on a PV diagram different from a straight line?
A curve on a PV diagram represents a non-ideal gas, while a straight line represents an ideal gas. This means that for a non-ideal gas, the pressure and volume are not directly proportional and can change with temperature and other external factors. On the other hand, for an ideal gas, the pressure and volume are directly proportional and can be described by the ideal gas law.
What information can be obtained from a PV diagram?
A PV diagram can provide information about the work done, heat transfer, and changes in internal energy of a gas as it undergoes a thermodynamic process. It can also be used to determine the efficiency of a heat engine or the amount of work that can be done by a system.
How is a PV diagram useful in thermodynamics?
PV diagrams are useful in thermodynamics as they help in visualizing and understanding the changes that occur in a gas during a thermodynamic process. They also help in analyzing the efficiency of a heat engine and determining the work done by a system.
Can a PV diagram be used for any gas?
Yes, a PV diagram can be used for any gas, whether it is ideal or non-ideal. However, for an ideal gas, the diagram will be a straight line, while for a non-ideal gas, it will be a curve. It is important to note that the behavior of the gas must be consistent with the ideal gas law for the PV diagram to be accurate.
