Physicist3
- 104
Hi, I understand that the PWM inverter drive system first uses a diode bridge rectifier in order to convert the AC incoming into DC before using an inverter to convert this DC into PWM for use on the induction motor. Could someone please explain in simple terms how the PWM inverter section works, (i.e. Pairing the wave with a triangle wave) etc and what the original sine wave and dc waves are used for?? Also, how does the mark-space ratio of the output signal change with a change in frequency?? How is the frequency changed?? Is it by changing the triangle wave frequency or what?? Thanks
