Pyrite roasting -- Mass balance with chemical reaction
In summary, the pyrite ore contains 85% of FeS2 and 15% of inerts. The ore is introduced into a roasting furnace with 20% excess air, in order to oxidize the FeS2. The solid product contains 2% FeS2 in mass.
MexChemE
237
55
A certain pyrite ore contains 85% of FeS2 and 15% of inerts. This ore is introduced into a roasting furnace with 20% excess air, in order to oxidize the FeS2 in the reaction:
[tex]\textrm{FeS}_2 + \frac{11}{4}\textrm{O}_2 \rightarrow \frac{1}{2}\textrm{Fe}_2 \textrm{O}_3 + 2\textrm{SO}_2[/tex]
The solid product contains 2% FeS2 in mass. Using 100 lb as basis, determine:
a) The chemical equation describing the process using the calculation basis, in mass and mole.
b) Conversion percentage.
c) The volume of the exhaust gases at 300 °C and 1 atm.
d) The amount of solid product obtained.
e) The amount of sulfuric acid which can be formed from the exhaust gases.
Steady state mass balance with chemical reaction
[tex]\textrm{In} + \textrm{Generation} = \textrm{Out} + \textrm{Consumption}[/tex]
First, I sketched a diagram of the process, as you can see in the attachments. Now, here's my work.
Part a)
85 lb (0.708 lbmol) of FeS2 are being fed into the furnace. So, here's the balanced equation in molar base:
[tex]0.708\textrm{FeS}_2 + 1.947\textrm{O}_2 \rightarrow 0.354\textrm{Fe}_2 \textrm{O}_3 + 1.416\textrm{SO}_2[/tex]
And mass base:
[tex]85\textrm{FeS}_2 + 62.3\textrm{O}_2 \rightarrow 56.6\textrm{Fe}_2 \textrm{O}_3 + 90.6\textrm{SO}_2[/tex]
Part b)
Now, for part b) I need to know how much FeS2 reacted (in lb). We'll call this quantity "A." We now also know that the O2 required is 1.947 lbmol. Assuming dry air (21% oxygen; 79% nitrogen), the moles of air required are 9.271 lbmol; and since we have a 20% of excess air, the air fed into the furnace is 11.125 lbmol, of which 2.336 lbmol are oxygen (74.76 lb). Now, we'll analyze the mass exchange occurring with the reaction. We know 85 lb of FeS2 and 74.76 lb O2 were fed into the furnace. If A lb of FeS2 reacted, we will have an output of:
(85 - A) FeS2
(74.76 - 0.73A) O2
(0.67A) Fe2O3
(1.07A) SO2
We know M3 is composed of 15 lb of inerts plus some amount of iron sulphide and ferric oxide.
[tex]M_3=15+(85-A) + 0.67A= 100-0.33A[/tex]
Now, if we perform a sulphide balance we have:
[tex]85 = A + 0.02M_3[/tex]
Now we have a 2x2 linear equation system which we cal solve in order to obtain M3 and A.
A = 83.551 lb
M3 = 72.428 lb
The percentage of conversion will be given by:
[tex]\% \textrm{Conversion} = \frac{83.551}{85} \times 100\% = 98.3\%[/tex]
Part c)
Now that we know A, we can calculate the amount of moles of exhaust gases, which is 10.616 lbmol. Assuming ideal beahvior, at 300 °C and 1 atm of pressure, the exhaust gases occupy a volume of 7997.3 ft3.
Part d)
The solid product is M3, which are 72.428 lb, with a composition of:
(15 lb) Inerts
(1.499 lb) FeS2
(55.979 lb) Fe2O3
Part e)
I have some doubts about my procedure for this part. We have 1.397 lbmol of SO2, of which only 0.8604 lbmol can react with the limited amount of O2 moles in the exhaust gases (which are 0.4302 lbmol) to form 0.8604 lbmol of SO3. This amount of SO3 will in turn react with a stoichiometric amount of water in order to produce 0.8604 lbmol of H2SO4.
Therefore, with an output of 1.397 lbmol of SO2 and 0.4302 lbmol of O2 as limiting reactant, 0.8604 lbmol of H2SO4 can be produced.
My concerns are mostly focused on part e), but feel free to point out any inconsistencies you may find along the way. Thanks in advance for any input!
It is not clear to me what the e asks. Process of producing sulfuric acid requires several steps and at least one additional reagent (water). If you can add water, why can't you use more air to oxidize all sulfur to SO3?
You have a good point; if I took the freedom of adding water I could just add more air and oxidize the 1.397 lbmol of SO2, and because of stoichiometry, that amount will produce 1.397 lbmol of H2SO4.. I originally used the limited amount of oxygen because the problem asked to use the product gases, but actually the only product gas of interest is SO2. Also, the reaction SO3 + H2O is not very common in industry, it releases too much heat, as far as I know. So there's that little detail too.
Related to Pyrite roasting -- Mass balance with chemical reaction
1. What is pyrite roasting and why is it important?
Pyrite roasting is a process used in metallurgy to extract valuable metals such as gold and copper from sulfide ores. It involves heating the ore at high temperatures in the presence of oxygen, which causes a chemical reaction that transforms the sulfides into oxides. This process is important because it allows for the extraction of valuable metals from ores that would otherwise be too low-grade to be economically viable.
2. How is mass balance achieved during pyrite roasting?
Mass balance is achieved during pyrite roasting by ensuring that the total mass of the input materials (sulfide ore, oxygen, and any other additives) equals the total mass of the output materials (roasted ore, sulfur dioxide gas, and any other byproducts). This is important for accurately calculating the efficiency of the process and determining the amount of valuable metals that have been extracted.
3. What is the role of chemical reactions in pyrite roasting?
Chemical reactions play a crucial role in pyrite roasting. The main chemical reaction that occurs is the oxidation of sulfides to oxides, which releases heat and produces sulfur dioxide gas. This reaction is exothermic, meaning it generates heat, which is important for maintaining the high temperatures required for the process. Other secondary reactions may also occur, depending on the composition of the ore and the conditions of the roasting process.
4. How is the mass balance affected by chemical reactions during pyrite roasting?
The mass balance is affected by chemical reactions during pyrite roasting because the chemical reactions consume or produce materials, thus changing the total mass of the input and output materials. For example, the oxidation of sulfides to oxides reduces the total mass of the ore, while the production of sulfur dioxide gas increases the total mass of the output materials. Therefore, it is important to take these reactions into account when calculating the mass balance.
5. What factors can affect the mass balance during pyrite roasting?
Several factors can affect the mass balance during pyrite roasting. These include the composition of the ore, the temperature and duration of the roasting process, the amount of oxygen present, and any additives or impurities in the materials. It is important to carefully control these factors to achieve an accurate mass balance and ensure the efficiency of the pyrite roasting process.
