Python DEAP Library -- List index out of range error
In summary: Also, "index" is a local variable within the function evalSymbReg, so it's value never changes between calls.Finally, in the third line I marked, you have "return diff,". I'm guessing you want to return the value of "diff", but you don't have the value of "diff" in the first place.In summary, the conversation discusses an error that the user is encountering while modifying a symbolic regression program using genetic programming. The error is caused by an index variable that is going beyond the range of the lists being used in the program. The user has tried debugging and reviewing the code but is unable to find the source of the error.
Prof. 27
50
So I'm currently modifying an example Symbolic Regression program that uses genetic programming, a type of evolutionary algorithm. I'm using the python deap library. Not sure if anyone on here is familiar with it, but I think that the error is more general to a misuse of python. I've "plotted" a series of values from the function x^2 to test the program on before working on more difficult problems in a list. I get a this error:
Traceback (most recent call last):
File "C:/Users/Anonymous/Downloads/WinPython-64bit-3.4.3.4/python-3.4.3.amd64/Lib/idlelib/Projects/GP SymbReg/Draft2.py", line 81, in <module>
main()
File "C:/Users/Anonymous/Downloads/WinPython-64bit-3.4.3.4/python-3.4.3.amd64/Lib/idlelib/Projects/GP SymbReg/Draft2.py", line 77, in main
halloffame=hof, verbose=True)
File "C:\Users\Anonymous\Downloads\WinPython-64bit-3.4.3.4\python-3.4.3.amd64\lib\site-packages\deap\algorithms.py", line 148, in eaSimple
for ind, fit in zip(invalid_ind, fitnesses):
File "C:/Users/Anonymous/Downloads/WinPython-64bit-3.4.3.4/python-3.4.3.amd64/Lib/idlelib/Projects/GP SymbReg/Draft2.py", line 47, in evalSymbReg
diff = ((func(testvals[index]) - values[index])**2)
IndexError: list index out of range
I assume this is exactly what it means, that the index variable achieves greater values than the index of one of my two lists. The trouble is, after an extensive review I am unable to find how this could be the case.
Here is the relevant code (as far as I'm aware, if you need the whole program, let me know.):
Python:
#Set data (x^2) and test vals.
values = [0, 1, 4, 9, 16, 25, 36, 49, 64, 81, 100]
L = []
testvals = L[0:len(values)-1:1]
#Evaluate Function
def evalSymbReg(individual):
    index=0
    # Transform the tree expression in a callable function
    func = toolbox.compile(expr=individual)
    # Evaluate the mean squared error between the function and the sample values.
    if index < len(values):
        index+1
        return diff,
    else:
        pass
Any ideas on why I'm getting the error?
None
A review of the material on stack overflow
Python Documentation on Lists, len()
DEAP Documentation
Technology news on Phys.org
Try adding debug prints before the point of fail to see what the index value is and what the table size is? From there you should be able to determine the problem.
Thanks, that's a good idea.
I added a bunch of print statements, but I just get the errors before they print. The only thing it does print is func. I'm assuming that's indicative that something else besides my index gets too high is wrong with my program. I'll post my entire code here, its not that much different than the DEAP GP Example, but anyone is free to use it (if they can fix it from my bad modifications. Lol).
Python:
import operator
import math
import random
import numpy
from deap import algorithms
from deap import base
from deap import creator
from deap import tools
from deap import gp
# Define new functions
def protectedDiv(left, right):
    try:
        return left / right
    except ZeroDivisionError:
        return 1
#Make Primitive Set
pset = gp.PrimitiveSet("MAIN", 1)
pset.addPrimitive(operator.add, 2)
pset.addPrimitive(operator.sub, 2)
pset.addPrimitive(operator.mul, 2)
pset.addPrimitive(protectedDiv, 2)
pset.addPrimitive(operator.neg, 1)
pset.addPrimitive(math.cos, 1)
pset.addPrimitive(math.sin, 1)
pset.addEphemeralConstant("rand101", lambda: random.randint(-100,100))
pset.renameArguments(ARG0='x')
#Create
creator.create("FitnessMin", base.Fitness, weights=(-1.0,))
creator.create("Individual", gp.PrimitiveTree, fitness=creator.FitnessMin)
#Register base.Toolbox() and assign to toolbox
toolbox = base.Toolbox()
toolbox.register("expr", gp.genHalfAndHalf, pset=pset, min_=1, max_=2)
toolbox.register("individual", tools.initIterate, creator.Individual, toolbox.expr)
toolbox.register("population", tools.initRepeat, list, toolbox.individual)
toolbox.register("compile", gp.compile, pset=pset)
L = []
#Evaluate Function
    index=0
    print(func)
    # Evaluate the mean squared error between the expression
    # and the real function : x**4 + x**3 + x**2 + x
    if index < values.length:
        index+1
        print(index)
        return diff,
    else:
        pass
        print(index)
    print(index)
#Register genetic operators
toolbox.register("evaluate", evalSymbReg)
toolbox.register("select", tools.selTournament, tournsize=3)
toolbox.register("mate", gp.cxOnePoint)
toolbox.register("expr_mut", gp.genFull, min_=0, max_=2)
toolbox.register("mutate", gp.mutUniform, expr=toolbox.expr_mut, pset=pset)
toolbox.decorate("mate", gp.staticLimit(key=operator.attrgetter("height"), max_value=17))
toolbox.decorate("mutate", gp.staticLimit(key=operator.attrgetter("height"), max_value=17))
#Main method
def main():
    random.seed(318)
#Create population and assign hof to tools.HallOfFame(1)
    pop = toolbox.population(n=300)
    hof = tools.HallOfFame(1)
#Statistics
    stats_fit = tools.Statistics(lambda ind: ind.fitness.values)
    stats_size = tools.Statistics(len)
    mstats = tools.MultiStatistics(fitness=stats_fit, size=stats_size)
    mstats.register("avg", numpy.mean)
    mstats.register("std", numpy.std)
    mstats.register("min", numpy.min)
    mstats.register("max", numpy.max)
#Set algorithm
    pop, log = algorithms.eaSimple(pop, toolbox, 0.5, 0.1, 40, stats=mstats,
    # print log
    return pop, log, hof
if __name__ == "__main__":
    main()
Prof. 27 said:
Python:
L = []
testvals = L[0:len(values)-1:1]  <---
#Evaluate Function
    index=0
        index+1  <---
        return diff,  <--
    else:
        pass
I have marked three lines of your code with "<---". In the first line I marked, L is an unintialized array. In the following line, you are setting testvals with the elements in the array L. I don't believe this is valid.
In the second line I marked, you have "index + 1". Your intent seems to be to increment index, but your code doesn't do that. It simply evaluated index, adds 1, and then does nothing to change the value of index. You should have either "index = index + 1" or "index++".
In the third line, you have a comma at the end of "return diff,". I don't believe that should be there.
Likes Prof. 27
Thanks for the pointers Mark44. Much appreciated.
The code now works thanks to your first two suggestions. I'm going to start working on a sympy version now.
Thanks for the help all
Related to Python DEAP Library -- List index out of range error
1. What is the Python DEAP library?
The Python DEAP library is a powerful and popular open-source framework for creating and implementing evolutionary algorithms in Python. It provides a variety of tools and functions for solving optimization problems through genetic programming, genetic algorithms, and other evolutionary computation techniques.
2. What does the "List index out of range" error mean?
The "List index out of range" error is a common error in Python, which occurs when trying to access an index in a list that does not exist. This means that the index provided is either larger or smaller than the range of the list. In the context of the DEAP library, this error can occur when trying to access a specific index in a data structure or when iterating through a list with incorrect index values.
3. How can I fix the "List index out of range" error?
To fix the "List index out of range" error, you need to ensure that the index provided is within the range of the list. This can be achieved by checking the length of the list and making sure the index is not larger than the length. Additionally, you can also use try-except blocks to handle the error and prevent the program from crashing.
4. How can I avoid the "List index out of range" error when using the DEAP library?
If you are using the DEAP library and encountering the "List index out of range" error, there are a few steps you can take to avoid it. First, make sure to thoroughly understand how the library works and how to access data within it. Additionally, always double-check your code for any potential errors or incorrect index values. You can also use debugging tools or print statements to track the values of your variables and indices.
5. Are there any common mistakes that can lead to the "List index out of range" error when using the DEAP library?
Yes, there are a few common mistakes that can lead to the "List index out of range" error when using the DEAP library. These include using incorrect indices when accessing data structures, not properly initializing or updating lists, and not accounting for the length of a list when iterating through it. It is essential to carefully review your code and ensure that all index values are valid before running the program to avoid this error.
  • Computing and Technology
