Python IDLE and print function....
In summary: That's not a CLI. A CLI is a command line interface, and the MS-DOS prompt is not a CLI. Thanks for catching that.GUI: we can have graphical user interface with more functionalities, menus, etc.Python IDLE is a GUI user interface.
fog37
1,568
108
TL;DR Summary
print function in IDLE
Hello,
While using the IDLE editor, I noticed that it is possible to simply type the variable name, list name, dict name and view its content without using the print() function...For example, if the variable a=5, then I would expect print(a) to output 5. And it does. But I can also simply type "a" and obtain the same result...this makes the use of print superfluous...
What is going on? I though we would always need the print function to output something to the screen...
Thanks!
Technology news on Phys.org
You might be entering these in a console window.
Likes fog37
Thanks jedishrfu.
I am sure I am using the IDLE that comes with the Python installation...
(1) This only works when running python interactively.
(2) There is a distinction for strings, as shown in the following example.
Python:
>>> foo = 'a\nb'
>>> foo
'a\nb'
>>> print(foo)
a
b
Likes fog37
ok. I see. Thanks pasmith. It only works in the IDLE to not use print and still get the same output...
It works whenever python is interactive mode. Just typing python at the command line starts python like that, as does running through IDLE. If you run a script, though, you get no output except print commands and similar.
Python:
>>> foo = 'a\nb'
>>> foo
'a\nb'
>>> print(foo)
a
b
More precisely, print() prints the default "display" or "aesthetic" string representation of its argument, as returned by calling str() on it. By contrast, Python's interactive interpreter evaluates the expression you give it and tries to display it in source form, as returned by the repr() function. For objects that have a source syntax, the idea is that evaluating eval(repr(x)) should return an object with the same type and value as x. In other words, you can see repr() as a partial inverse of the eval() function. For some objects, the two string representations happen to be the same.
Here are some examples:
Python:
>>> 'hello'
'hello'
>>> str('hello')
'hello'
>>> repr('hello')
"'hello'"
>>> print('hello')
hello
>>> print(str('hello'))
hello
>>> print(repr('hello'))
'hello'
>>> from fractions import Fraction
>>> x = Fraction(3, 2)
>>> print(x)
3/2
>>> x
Fraction(3, 2)
>>> str(x)
'3/2'
>>> repr(x)
'Fraction(3, 2)'
>>> eval(str(x))
1.5
>>> eval(repr(x))
Fraction(3, 2)
You can define one or both kinds of string representation for user-defined objects by writing __str__() or __repr__() methods for them.
Likes fog37
That works because you are in python shell by default when you start IDLE. If you see a screen like this:
with >>> on each line, it means you are in a shell. In that case, you can view the value of variables without using print function.
IDLE gives you an option to save the commands you have executed in the shell, which is generally lost if you use command prompt/terminal. But that is not the way you should write programs in Python. It is always better to use a script for writing programs.
To create a script, go to File -> New File.
Likes fog37
Thank you everyone.
I guess we are talking about user interfaces (UI). The terms "console", "terminal" and "prompt" are all synonyms of user interface. Is that correct?
There are two types of user interface:
  1. CLI: A user interface can be a command line interface (CLI), i.e. text-based interface with a black screen, white, text, no other functionality. The Windows prompt is CLI.
  2. GUI: we can have graphical user interface with more functionalities, menus, etc. Python IDLE is a GUI user interface.
Both CLI and GUI interfaces are shells (i.e. interpreters), correct? To me, a shell is the program that controls the user interface. So IDLE is a shell. There is also the Windows shell that opens up when we type the command cmd.
Being interactive mode means that we are running one or multiple commands directly in the console/user interface and not from a saved Python file...
Let me know if I have anything wrong.
Thank you!
Not by this description. When you open "Command Prompt" in Windows, the Windows desktop doesn't disappear; the command prompt appears in a GUI window on the Windows desktop, just like any other GUI program. In other words, the Windows "Command Prompt" program is just a GUI program whose main window displays an interactive session with the Windows command interpreter, cmd.exe. (Note that Windows now also has PowerShell, which displays an interactive session with a different command interpreter, powershell.exe.) IDLE is the same sort of thing, except that it displays an interactive session with the Python interpreter.
A true CLI in this sense would be, for example, MS-DOS, where literally all you have is a C:> prompt on a bare black screen. (You can also get this in Linux by not booting X Windows. You used to be able to get it in Windows by booting into DOS mode, but I don't think that's been possible since at least Windows XP, if not earlier.)
So is any program that runs on Windows today. See above.
The term "shell" usually means an interactive session with a command interpreter--something that interprets commands you type, executes them, and prints the results. So the Windows command prompt, Windows PowerShell, and IDLE are all shells in this sense, just with different command interpreters.
Likes Wrichik Basu and fog37
Related to Python IDLE and print function....
1. What is Python IDLE?
Python IDLE (Integrated Development and Learning Environment) is an interactive development environment for writing and executing Python code. It is included with the standard installation of Python and provides features such as code completion, debugging, and a built-in text editor.
2. How do I open Python IDLE?
To open Python IDLE, go to the Start menu and select "Python X.X" (where X.X is the version of Python you have installed). This will open the Python shell, which is the interactive command line interface for Python. From there, you can open a new window by selecting "File" and then "New File" or by pressing Ctrl+N.
3. What is the print function in Python?
The print function in Python is used to display output on the screen. It takes in one or more arguments and prints them to the standard output (usually the console). The syntax for the print function is: print(object(s), sep=separator, end=end). The default separator is a single space and the default end is a newline character.
4. How do I use the print function in Python IDLE?
To use the print function in Python IDLE, simply type print() followed by the object(s) you want to print. For example, print("Hello World!") will print the string "Hello World!" to the screen. You can also use the sep and end parameters to change the separator and end characters if desired.
5. Can I use the print function to display variables in Python IDLE?
Yes, you can use the print function to display variables in Python IDLE. Simply include the variable name as an argument inside the print function. For example, num = 10print("The value of num is:", num) will print "The value of num is: 10" to the screen. You can also use string formatting to customize the output, such as print("The value of num is: %d" % num).
