Q about 2nd derivative test for multivariable functions
In summary, the Hessian matrix of a multivariate function can be used to determine whether a point is a local minimum, maximum, or saddle point. If the second derivatives at a critical point are all positive, the point is a local minimum. If they are all negative, the point is a local maximum. If there are some positive and some negative second derivatives, the point is a saddle point.
kostoglotov
234
So the test is to take the determinant (D) of the Hessian matrix of your multivar function.
Then if D>0 & fxx>0 it's a min point, if D>0 & fxx<0 it's a max point.
For D<0 it's a saddle point, and D=0 gives no information.
My question is, what happens if fxx=0? Is that equivalent to D=0?
Your first statement isn't true. D>0 doesn't tell much of anything about the type of extremum in the general multivariate case. What is the complete statement of your problem ?
It's not my statement, it's the textbooks...there's no specific problem to which I can refer. I was just wondering what it tells us if fxx=0.
In the textbook (Stewart's Calculus 6 edt. p960 ) it says
Suppose the second partial derivatives of f are continuous on a disk with center (a,b) and suppose that fx(a,b) = 0 and fy(a,b) = 0 [that is, (a,b) is a critical point of f], Let
D = D(a,b) = fxx(a,b)fyy(a,b) - [fxy(a,b)]^2
(a) If D > 0 and fxx > 0, then f(a,b) is a local minimum
(b) If D > 0 and fxx < 0, then f(a,b) is a local maximum
(c) If D < 0 then f(a,b) is not a local min or max, it is a saddle point
You and Wabbit are both right. For the special case of 2 variables, ##f_{xx} > 0## and ##D > 0## guarantee a strict local min. However, for 3 or more variables, having ##D > 0## really does not give much useful information at all. For example, for ##f(x,y,z) = x^2-y^2-z^2##, the point (0,0,0) is stationary, and the Hessian is
[tex] H = \left[ \begin{array}{ccc}2 &0 & 0 \\ 0 & -2 & 0 \\ 0 & 0 & -2\end{array} \right] [/tex]
which has ##f_{xx} > 0## and ##D > 0##. But (0,0,0) is a saddle point.
In general, it is necessary (not sufficient) that all ##f_{x_i x_i} > 0## in order to have a strict local min. For the 2-variable case, having ##f_{xx} > 0## and ##D > 0## automatically guarantees ##f_{yy} > 0## as well.
Likes kostoglotov
@kostoglotov. Yes as explained by Ray your statement is correct in the bivariate case and then fxx=0 leads to D<0 or D=0, it only excludes the case D>0.
And no, it's not the textbook that is to blame.
Your statement is false because it says "multivar", The textbook is correct because it does no such thing and talks about functions of two variables.
Likes kostoglotov
Ah, ok, I'm being loose with my terminology. I'll take note of that! Thanks.
A little bit more detail: strictly speaking, "the derivative" of a multi-variable function is the gradient vector- the vector whose components, in a given coordinate system, are the partial derivatives of the function and the second derivative is the Hessian- the matrix having all second partial derivatives as components. Since [itex]f_{xy}= f_{yx}[/itex], this is a symmetric matrix and so is diagonalizable. That is, there exist a coordinate system in which the "mixed" second partials are 0.
Now, if the second derivatives at a critical point, in this coordinate system, are all positive the point is "relative minimum". If they are all negative a "relative maximum". If there are some positive and some negative second derivatives we have a "saddle point".
For two variables, it is fairly easy to see which we have without having to change coordinate system. If the matrix of second derivatives is
[tex]\begin{bmatrix} f_{xx} & f_{xy} \\ f_{xy} & f_{yy} \end{bmatrix}[/tex]
then its determinant is [itex]f_{xx}f_{yy}- f_{xy}^2[/itex]. Since the determinant is independent of coordinate changes, that would be the same as [itex]f_{x'x'}f_{y'y'}[/itex] in a coordinate system in which the mixed partials were 0. So if that determinant were positive, [itex]f_{x'x'}[/itex] and [itex]f_{y'y'}[/itex] must have the same sign so the critical point is either a maximum or a minimum. We can determine which by looking at either [itex]f_{x'x'}[/itex] or [itex]f_{y'y'}[/itex] separately. If that determinant were negative then we would have a saddle point.
But with more than two coordinates, it is no longer that simple. Now, the determinant might be positive if there are an even number of negative second derivatives in that diagonalized matrix. For example, in three dimensions, if the determinant is positive, we might have all three second derivatives positive, a minimum, or we might have two negative and one positive, a saddle point.
The only way to be sure is to find the specific eigenvalues of the Hessian matrix since they will be the numbers on the diagonal matrix. If all eigenvalues are positive, we have a minimum, if all are negative, a maximum, and, if some are positive and some negative, a saddle point.
Likes kostoglotov
In the n-variable case, the stationary point ##\vec{x}_0 = (x_{10}, x_{20}, \ldots, x_{n0})## is a strict local minimizing point of ##f(\vec{x})## if the Hessian matrix ##H_0 = H(\vec{x}_0)## is positive-definite. One test for this is that all the principle minors of ##H_0## be positive; that is, the ##1\times 1## upper-left determinant should be > 0---and of course, that is just the statement ##f_{x_1 x_1} > 0##; as well, the upper left ##2 \times 2## determinant should be >0, the upper-left ##3 \times 3## determinant should be >0, etc. In other words, the upper left submatrices having rows ##1\ldots i## and columns ##1\ldots i## should all have positive determinants for ##i = 1, 2, \ldots, n##. Note that for the case ##n = 2## this is exactly what your textbook says.
If the Hessian is "indefinite", the point ##\vec{x}_0## is a saddle point; if the Hessian is not indefinite but is only positive semi-definite, we cannot say: the point could be a minimum or a saddle point (but for sure it is not a maximum).
Likes kostoglotov
That's fascinating. I'm doing the MIT linear algebra course in the second half of this year, I'll have to bookmark your post and come back to it when I understand changing of coordinate systems and eigen-stuff better! Thanks.
Related to Q about 2nd derivative test for multivariable functions
What is the second derivative test for multivariable functions?
The second derivative test is a method used in multivariable calculus to determine the nature of critical points (maximum, minimum, or saddle points) of a function with two or more independent variables. It involves finding the second-order partial derivatives of the function and evaluating them at the critical point.
How is the second derivative test used to find critical points?
The second derivative test states that if the second derivative of a function is positive at a critical point, then the critical point is a local minimum. If the second derivative is negative, then the critical point is a local maximum. And if the second derivative is zero, the test is inconclusive and further investigation is needed.
Can the second derivative test be used to find global extrema?
No, the second derivative test can only determine the nature of critical points, which are local extrema. To find global extrema, other methods such as the first derivative test or the optimization techniques must be used.
What are the limitations of the second derivative test?
The second derivative test can only be applied to functions with two or more independent variables. It also assumes that the function is twice differentiable, which may not always be the case. The test also does not provide information about the exact location of the critical points.
Are there any alternatives to the second derivative test?
Yes, there are other methods such as the first derivative test, the Hessian matrix test, and the optimization techniques that can be used to find critical points and determine the nature of extrema in multivariable functions. Each method may have its own advantages and limitations, and it is important to choose the appropriate method based on the given function and problem.
14K
