Q5|8.5.17 int of rational expression...
In summary, the conversation discusses how to evaluate the integral $\int_0^9\frac{x^3}{x^2+18x+81}\,dx$ using various methods, including substitution, long division and remainder, and partial fractions. The final result is $I=243\ln2-162$.
karush
MHB
3,269
$\tiny{Q5|8.5.17}$
$\textsf{Evaluate}$
\begin{align*}\displaystyle
I&=\int_0^{9}\frac{x^3 \, dx}{x^2+18x+81}
\color{red}{=243\ln2-162}
\end{align*}
OK even before I try to get this answer
trying to see what road to take
u substituion
partial fractions (the denominator is a square $(x+9)^2$)
other?
I tried $u=x+9$ $du=dx$ but it got ? fast
Let's try your substitution of:
\(\displaystyle u=x+9\implies du=dx\)
\(\displaystyle I=\int_9^{18}\frac{(u-9)^3}{u^2}\,du\)
By the binomial theorem:
\(\displaystyle (u-9)^3=u^3+3u^2(-9)+3u(-9)^2+(-9)^3=u^3-27u^2+243u-729\)
Hence:
\(\displaystyle I=\int_9^{18} u-27+243u^{-1}-729u^{-2}\,du\)
Now, you can integrate term by term. :D
FAQ: Q5|8.5.17 int of rational expression...
What is a rational expression?
A rational expression is a mathematical expression in which two polynomials are divided by each other. It is also known as a rational function.
How do you simplify a rational expression?
To simplify a rational expression, you need to first factor both the numerator and denominator. Then, you can cancel out common factors and multiply any remaining factors together. Lastly, simplify any remaining terms if possible.
Can a rational expression have a negative exponent?
Yes, a rational expression can have a negative exponent. When simplifying, negative exponents can be moved to the opposite part of the fraction and become positive. For example, 1/x^-2 would become x^2.
What is the domain of a rational expression?
The domain of a rational expression is all the values that the variable can take on without making the denominator equal to zero. This is because dividing by zero is undefined in mathematics.
How do you solve equations with rational expressions?
To solve equations with rational expressions, you can first try to simplify the expressions on both sides of the equation. Then, cross multiply to eliminate any fractions. Finally, solve for the variable as you would in a regular algebraic equation.
