QCD vacuum and anomaly [Axions]
In summary, the paper discusses the strong CP problem and axions, focusing on the U(2)_A x U(2)_V global symmetry for massless quarks in QCD and the resulting axial current divergence. Questions are raised about the transformations and the gauge transformation of A. The paper also briefly mentions an SU(2) gauge transformation for an SU(2) QCD theory. The approximate symmetry of isospin is also mentioned and its experimental verification. The transformation \Omega(x) is discussed in terms of going to unity at spatial infinite with a specific phase.
ChrisVer
464
I am studying this paper about the strong CP problem and axions by R.D. Peccei:
http://arxiv.org/abs/hep-ph/0607268
At the moment I read through the introduction and I have some questions about some points, so please could you help me clear out some things?. [In general I'll try to feed back this thread with more questions around the topic].
#1. It says that for massless quarks, and 2 light quarks [for QCD scale] we have an approximate global symmetry [itex]U[2]_V \times U[2]_A [/itex], so a vector and axial current symmetry. However if I look at the massless lagrangian [just the kinetic term] I have:
[itex] \mathcal{L}= i \bar{q} \gamma^\mu \partial_\mu q [/itex]
What are the transformations done for the U[1] cases? I think the axial will have something like [itex]\propto \exp[ia \gamma_5][/itex]. In that case I don't see how the [itex] \exp[-ia \gamma_5] \gamma^\mu \exp[ia \gamma_5]= \gamma^\mu[/itex] (it's not even a symmetry for the massless lagrangian)
#2. In Eq 1: I am having a problem in seeing that the triangle chiral anomaly gives rise to a divergence to the axial current of the form: [itex] \partial_\mu J^\mu_5 = g F^{\mu \nu}_a \tilde{F}_{a \mu \nu}[/itex]. Do you have any source where I can see how does someone extract this result?
#3. In Eq 7: The gauge transformation of [itex]A[/itex] goes like:
[itex]A^i \rightarrow \Omega A^i \Omega ^{-1} + \frac{i}{g} \nabla^i \Omega \Omega^{-1}[/itex]
I think the second term is zero ([itex]\Omega \Omega^{-1}=1[/itex]) or does it mean that [itex](\nabla^i \Omega ) \Omega^{-1}[/itex]. Then, also why does it give to the Omegas a spatial dependence ([itex]\textbf{r}[/itex])?
#4 Finally for now, under Eq8, I don't understand what it means by the Jacobian of the mapping [itex]S_3 \rightarrow S_3 [/itex] (what is [itex]S_3[/itex]? the symmetry group of order 3!=6?)
#1 Be careful with the transformation for [itex]\bar q[/itex]. In fact we have: [itex]q\to e^{ia\gamma_5}q[/itex] and so [itex]q^\dagger\to q^\dagger e^{-ia\gamma_5}[/itex]. Therefore: [itex]\bar q=q^\dagger\gamma_0\to \bar q e^{ia\gamma_5}[/itex]. And so when they switch with the [itex]\gamma_\mu[/itex] they change sign again, thus canceling each other.
#2 Have you tried to take a look at Peskin? There should be a chapter on QCD axial anomaly. Or also Donoghue's book.
#3 It's the second thing you wrote: [itex](\nabla^i\Omega)\Omega^{-1}[/itex]. Also, [itex]\Omega(x)[/itex] has a space-time dependence because that's how you define a gauge trasformation, i.e. a symmetry which depends on the space-time point where it si applied.
#4 I'm not sure but I think that [itex]S_3[/itex] is supposed to be the 3-dimensional sphere.
Likes ChrisVer
Thanks for the reply. Oh my god, I didn't even care about the [itex]\gamma^0[/itex] in (1) ... :s
True about the gauge transformations, but isn't that supposed to be the case for local symmetry transformations and not global? In fact I'm getting confused of how he changes transformations: first he has U_A(2) xU_V(2), then goes to a U(1)_A that is not a symmetry. Then in the A^i case, he works with an SU(2) QCD (what is that SU(2)?- SU(2)_isospin?)
Yes, in fact [itex]\Omega(x)[/itex] is supposed to be a local symmetry. In particular, [itex]\Omega\in SU(2)[/itex] since he is saying that he is dealing with SU(2) QCD. This just means to build QCD with an SU(2) group (i.e. 2 colors and using the Pauli matrices instead of the Gell-Mann ones) instead of an SU(3) group. It's just to make everything simpler.
I haven't looked in details at the paper but it seems to me that the U_A(2) xU_V(2) is a global symmetry.
But by SU(2) QCD we mean a gauge SU(2), so it is a local transformation. This SU(2) is not isospin (which is an approximate symmetry of SU(3) QCD). By SU(2) QCD, they mean an hypothetical theory where the SU(3) of QCD is replaced by SU(2) so there would be two colours.
Also how can someone decide on approximate symmetries? I think this question concerns the experimental verification.
For example up until today SU(3) for strong interactions [QCD] has been experimentally verified...
But when you talk about approximate symmetries, like that of isospin, due to [itex]\Lambda_{QCD} \gg m_{u,d}[/itex], how can you experimentally see that? I mean we know that the up and down quarks have masses, and so I don't get the approximation : [itex]m_{u,d}=0[/itex] ...
The isospin approximation is not [itex]m_{u,d}=0[/itex] but it's the [itex]m_u=m_d[/itex] which is experimentally verified simply looking at the mass difference between proton and neutron being very small.
Thanks. Back to the topic, extending my #3...
I don't understand how the transformation [itex] \Omega \rightarrow \exp (2i \pi n)[/itex]
All I was able to find is that (for SU(2)): [itex]\Omega_j = \exp (- i \pi \frac{x_j \sigma_j}{\sqrt{x^2 + \lambda^2}})[/itex] in the n-th power... as:
In my opinion, getting to the actual result in Eq. (9) can be a rather complicated problem (try to take a look at reference [6] cited in the paper). However, Eq. (8) is rather simple to understand. You are performing an SU(2) gauge transformation, [itex]\Omega(x)[/itex]. This simply means that, for each point of your space-time, you are performing a different transformation. Now, it is clear that you want this transformation to be trivial when you are at spatial infinite (you don't want to trasform your field at infinite!). This means that for [itex]\vec{r}\to\infty[/itex] the gauge transformatio [itex]\Omega(t,\vec{r})[/itex] must go to a unity transformation. However, this does not specify the phase with which [itex]\Omega(t,\vec{r})[/itex] goes to unity.
This is what the paper is saying. Even if all your transformations go to 1 at infinite you can still classify them based on how the go to unity (from which direction if you want).
One other question...
http://pdg.lbl.gov/2013/reviews/rpp2013-rev-axions.pdf
page 3:
In supersymmetric models the axion is part of a supermultiplet and thus inevitably accompanied by a spin-0 saxion and a spin-1 axino, [,,,]
How can this be true for a scalar field? I know this might sound stupid, but the axion as a scalar field it should have a superpartner that is a fermion... (I don't have access in ref 18)
I think you are right, but it also says:
The KSVZ and DFSZ models are
frequently used as generic examples, but other models exist
where both heavy quarks and Higgs doublets carry PQ charges.
This makes me think that in some models axions can also be fermions. I think the important aspect is that they have to carry PQ charge, in order to acquire a non-zero VEV.
However, if you try to give nonzero vev to a fermion you are going to break the Lorentz invariance...
Absolutely correct! I have no idea, I'm sorry :D
This is going to be a very fast question, however I'd like to make it clear for my understanding.
In the pdg review, they state that the axion is coupled to the nucleons with some dimensionless constants $$C_{p,n}$$ which are related to the nucleon axial vector current matrix elements by the generalized Goldberger-Treiman relation [I'll restrict myself only to the proton]:
$$C_p =(C_u - \eta) \Delta u + (C_d - \eta z) \Delta d + (C_s - \eta w) \Delta s $$
where
$$\eta = (1+z+w)^{-1}$$, $$z= \frac{m_u}{m_d}$$ and $$w=\frac{m_u}{m_s}$$
and $$\Delta q$$ represent the axial vector current coupling to the proton:
$$\Delta q S_\mu = <p|~\bar{q} \gamma_\mu \gamma_5 q ~|p>$$
where $$S_\mu$$ the proton's spin.
I guess the bracket represents the proton right?
Can the last equation be rewritten:
$$\Delta q S_\mu S^\mu= <p|~\bar{q} \gamma_\mu \gamma_5 q ~|p> S^\mu \Rightarrow \Delta q = \frac{<p|~\bar{q} \gamma_\mu \gamma_5 q ~|p> }{S^2} S^{\mu}$$
So it depends on the spin and thus allows for the axion to couple to the proton's spin?
I am afraid that the last equation kills dofs of the initial one...
Related to QCD vacuum and anomaly [Axions]
1. What is the QCD vacuum and anomaly?
The QCD (Quantum Chromodynamics) vacuum is the lowest energy state of the universe, which is filled with a constantly fluctuating field of virtual particles. The QCD anomaly refers to a violation of a symmetry in QCD that leads to a non-zero vacuum energy density.
2. What are axions?
Axions are hypothetical particles that were proposed to solve the strong CP problem in QCD. They are expected to be extremely light and have very weak interactions with other particles, making them difficult to detect.
3. How do axions relate to the QCD vacuum and anomaly?
Axions are closely related to the QCD vacuum and anomaly because they were originally proposed as a solution to the strong CP problem, which is a consequence of the QCD anomaly. Axions are also predicted to interact with the QCD vacuum, affecting its energy density.
4. Why are axions important in particle physics?
Axions are important in particle physics because they could potentially explain the mystery of dark matter, which makes up about 85% of the matter in the universe. They are also a key candidate for solving the strong CP problem and have other potential applications in cosmology and astrophysics.
5. How are scientists searching for axions?
Scientists are using a variety of experimental techniques to search for axions, including looking for their effects on the QCD vacuum using high-energy particle colliders, searching for their conversion into photons in strong magnetic fields, and using specialized detectors to directly detect their interactions with matter.
  • Other Physics Topics
