QED: Electron/Positron Scattering & Bosonic Propagators
In summary, the perturbation theory for the electron/positron scattering is that the propagator is: T=<f|H|i>+\sum<f|H|n>\frac{1}{E_i-E_n}<n|H|i>+... where f is the final state and i the initial state, and there is just one intermediate state |n>. The final formula for T is obtained by considering two different diagrams.
eoghan
210
Hi!
I'm studying an introduction to QED and I don't understand the bosonic propagators.
Consider the electron/positron scattering with the exchange of a virtual photon. According to perturbation theory, the propagator is:
[tex]T=<f|H|i>+\sum<f|H|n>\frac{1}{E_i-E_n}<n|H|i>+...[/tex]
where f is the final state and i the initial state.
Now, I guess both the final and the initial states are the states of an electron and a positron, but with different momenta.
Moreover there is just one intermediate state |n> which is the state of the virtual photon.
Now, looking at the final formula for T and doing a sort of back-engineering I guess that the perturbation term H is [tex]e[/tex], so the first term in the approximation becomes
[tex]e<f|i>[/tex]
and the second term gives:
[tex]\frac{e^2}{E_i-E_{\gamma}}<f|i><i|f>[/tex]
Again, looking at the final formula I see that <i|f>=1 so that the second term becomes:
[tex]\frac{e^2}{E_i-E_{\gamma}}[/tex]
Now, my questions are:
1) the first term in the approximation vanishes in the final formula so <i|f>=0. But then also the second term vanishes! So, what is <f|i>?
2)Why the perturbation hamiltonian is constant and equal to the charge of the electron?
P.s. the final formula of the propagator is obtained by considering two different diagrams. Here I considered only one of them.
You seem to be missing a lot of background. Rather than backtrack from the answer to try to guess at how to solve the problem, you should go back and figure out the very basics again.
eoghan said:
Hi!
This is true.
Not quite. Each intermediate state has an electron, a positron and a photon. We sum over all energies of the virtual photon, so a continuum of states actually contributes to the sum above.
[tex]e<f|i>[/tex]
You should really look through your notes to figure out what Hamiltonian [tex]H[/tex] that you're using. Written in terms of quantum fields, it should look like [tex] H\sim e \bar{\psi}\gamma^\mu \psi A_\mu[/tex] where [tex]\psi[/tex] is the quantum field for the electron and [tex]A_\mu[/tex] is the photon field. Since neither the initial nor final state has a photon in it, [tex] \langle f| H| i\rangle =0[/tex].
It's a bit more complicated than this, since we're summing over all intermediate states. Furthermore, because of momentum conservation, the electron and positron have different momenta in the intermediate state as compared to the initial state, so [tex]|n\rangle \neq | \gamma\rangle |i\langle[/tex].
[tex]\langle i|f\rangle \neq 0[/tex], only [tex]\langle i|H|f\rangle =0 [/tex], see above.
It isn't, check your notes or text to figure out what Hamiltonian they're using.
Yes, it is. The course is just an introduction to particle physics. I've studied quantum mechanics and relativistic quantum mechanics, but I haven't studied yet QFT. The notes just says that the propagator is found by applying the second order perturbation theory. I thought it was simpler, but it's too complicated! I think I'm going to learn the propagator by heart without trying to justify it.
Thank you!
FAQ: QED: Electron/Positron Scattering & Bosonic Propagators
1. What is QED?
QED stands for Quantum Electrodynamics, which is a theory that describes the interactions between electrically charged particles, such as electrons and positrons, through the exchange of photons.
2. What is electron/positron scattering?
Electron/positron scattering is a process in which an electron and a positron interact and exchange energy through the emission and absorption of virtual photons. This process is described by the QED theory and is important in understanding the behavior of subatomic particles.
3. What are bosonic propagators?
Bosonic propagators are mathematical quantities used in QED to describe the probability of an electron and a positron exchanging photons at a specific time and location. They are represented by mathematical equations and help to predict the behavior of particles in a scattering event.
4. What is the significance of QED in modern physics?
QED is considered one of the most successful theories in modern physics as it accurately describes the behavior of particles at the subatomic level. It has been extensively tested and is used in many areas of research, such as particle accelerators and quantum computing.
5. How does QED explain the behavior of particles in an atom?
QED helps to explain the behavior of particles in an atom by describing the interactions between electrons and the positively charged nucleus. It also explains the behavior of photons, which are responsible for the electromagnetic force that binds the particles in an atom together.
