QFT on the lattice and Green's functions
In summary, QFT on the lattice is a numerical approach used to study quantum field theories (QFTs) by discretizing space and time into a lattice and using computational techniques. Unlike analytical approaches, it relies on numerical simulations to study complex systems. Green's functions, or correlation functions, are used to describe interactions between particles in QFT on the lattice and are calculated using Monte Carlo methods. This approach has various applications in theoretical physics and practical fields such as material design and drug discovery.
Ramil
[/B]
I'm trying to write a program for caclulating Green's function using Monte Carlo method (Metropolis algorithm) in scalar field theory with a potential λφ4 in 4D. I'm writing it in python.
N_t, N_x, N_y, N_z - total number of lattice sites in each directions.
Field fi(i,j,k,l). Here (i, j, k, l) corresponds to (t, x, y, z).
I want to calculate two-point Green's function G(0) in the coincident limit. I want to get the dependency of G(0) on x coordinate.
G(r,r')=<φ(r)φ(r')>, r→r'. (Here r is a space-time point r=(t,x,y,z))
G(0)=<φ2>
Using Metropolis algorithm i do the following:
1. Generate an arbitrary configuration of the field fi, let it, for instance, be all zeros:
fi=np.zeros(N_t, N_x, N_y, N_z)
2. Then, using standard procedure I thermalise my configurations of the field, to get configurations fi(i, j, k, l) that satisfy a minima of an action.
3. Using obtained configurations fi(i, j, k, l) I want to calculate two-point Green's function G(0) in the coincident limit.
An excerpt of my code:
def Grin_0(fi):
N_x=10
N_y=10
N_z=10
N_t=60
for i in range(0,N_t):
for j in range(0,N_x):
for k in range(0,N_y):
for l in range(0,N_z):
G_0[i,j,k,l]=fi[i,j,k,l]*fi[i,j,k,l]
return G_0
Then i summirize G_0 along i,k,l indices and get the dependency of G_0 on index j.
Is it correct? How to find G_0 and its dependency on x correctly?
Your approach seems reasonable, but there are a few things you may want to consider or clarify:
1. In step 1, you mention generating an arbitrary configuration of the field, but then you specify that it will be all zeros. If you want to test your code, this may be a good starting point, but in general, you may want to generate a random configuration of the field to get a more realistic result.
2. In step 2, you mention thermalizing the configurations of the field, but you don't specify how you are doing this. It may be helpful to explain your thermalization procedure in more detail.
3. In step 3, you mention wanting to calculate the two-point Green's function in the coincident limit, but your code seems to calculate it for all points in the lattice. If you only want the coincident limit, you may want to specify how you are selecting the points for the calculation.
4. In your code, you define G_0 as a function, but then you don't use it as a function in your code. Instead, you seem to be calculating the two-point Green's function for all points in the lattice and then summarizing it later. If you want to use G_0 as a function, you may want to pass the field configuration as an argument and calculate the Green's function for each point in the lattice within the function.
5. Finally, you mention wanting to find the dependency of G_0 on the x coordinate, but your code only seems to be calculating the Green's function for each point in the lattice. If you want to find the dependency on the x coordinate, you may need to plot or analyze the results of your code in a way that shows this dependency.
Overall, your approach seems reasonable, but it may be helpful to provide more details and clarify some of the steps in your code. Additionally, you may want to consider how you will test or validate your results to ensure they are accurate.
Related to QFT on the lattice and Green's functions
1. What is QFT on the lattice?
QFT on the lattice is a numerical approach used to study quantum field theories (QFTs). It involves discretizing space and time into a lattice and using computational techniques to solve for the behavior of the system.
2. How does QFT on the lattice differ from other approaches to studying QFTs?
Unlike analytical approaches, QFT on the lattice relies on numerical simulations to study the behavior of QFTs. This allows for the study of more complex systems that cannot be solved analytically.
3. What are Green's functions in QFT on the lattice?
Green's functions, also known as correlation functions, are mathematical functions used to describe the correlations between different points in a QFT on the lattice. They provide information about the interactions between particles in the system.
4. How are Green's functions calculated in QFT on the lattice?
Green's functions are calculated using Monte Carlo methods, which involve generating random samples to approximate the behavior of the system. This allows for the numerical evaluation of integrals that would be difficult to solve analytically.
5. What are some applications of QFT on the lattice and Green's functions?
QFT on the lattice and Green's functions have a wide range of applications in theoretical physics, including the study of condensed matter systems, high energy physics, and cosmology. They are also used in practical applications such as material design and drug discovery.
  • Quantum Physics
  • Atomic and Condensed Matter
