A QFT S-matrix explanations are incomprehensible
jostpuur
TL;DR Summary
I've failed to understand S-matrix explanations. Does anyone feel like understanding them?
The first look at a scattering process is something like this: We define an initial state
<br /> |\textrm{in}\rangle = \int dp_1dp_2 f_{\textrm{in,1}}(p_1) f_{\textrm{in,2}}(p_2) a_{p_1}^{\dagger} a_{p_2}^{\dagger} |0\rangle<br />
Here f_{\textrm{in,1}} and f_{\textrm{in,2}} are wavefunctions that define some wavepackets that are about collide. Schrodinger equation will determine what happens, so we define an out state as
<br /> |\textrm{out}\rangle = e^{-\frac{it}{\hbar}H} |\textrm{in}\rangle<br />
If it turns out at that N particles fly out from the collision as some wavepackets, then something like
<br /> |\textrm{out}\rangle \approx \int dq_1 dq_2 \cdots dq_N f_{\textrm{out,1}}(q_1) f_{\textrm{out,2}}(q_2)\cdots f_{\textrm{out,N}}(q_N) a_{q_1}^{\dagger} a_{q_2}^{\dagger}\cdots a_{q_N}^{\dagger}|0\rangle<br />
is true. So far I feel like I understand what this all means. However, in the fully developed QFT the scattering is not handled like above. Instead we define an initial state as
<br /> |\textrm{in}\rangle = |p_1,p_2\rangle = a_{p_1}^{\dagger} a_{p_2}^{\dagger} |0\rangle<br />
So instead of wavepackets we wave planewaves that extend to infinities. Then we have an S-matrix operator that works so that it will give an amplitude for N particles flying out as
<br /> \langle q_1, q_2,\cdots, q_N|S|p_1,p_2\rangle<br />
What confuses me about this is that planewaves cannot really collide, can they? Wavepackets are something can actually collide, but planewaves are somekind of artificial tool? So how do you make the S-matrix operator work so that it makes the planewaves collide?
One formula for S-matrix is
<br /> S = \lim_{t_{\textrm{B}}\to\infty} \lim_{t_{\textrm{A}}\to -\infty} e^{\frac{i}{\hbar}t_{\textrm{B}}H_0} e^{-\frac{i}{\hbar}(t_{\textrm{B}}-t_{\textrm{A}})H}e^{-\frac{i}{\hbar}t_{\textrm{A}}H_0}<br />
It is nice that a formula exists, but I still don't understand that what calculations turn the wavepackets into planewaves.
Sure. Why not? Whether this has any nontrivial outcome depends on whether there's an interaction term in the total Hamiltonian.
Wavepackets can be expressed as a linear combination of planewaves (as in Fourier theory).
If we can compute a general formula for the scattering of any (combination of) incoming planewaves into any combination of outgoing planewaves then we have a theory that can be compared with experiment.
One of the early chapters in Peskin& Schroeder has a section on how physically realistic beams (like in an accelerator) are modeled in these terms, and then how to compute scattering cross sections therefrom.
Likes vanhees71, Demystifier and topsquark
This is not necessarily related to QFT, the same issue arises also in nonrelativistic QM. I would suggest you to first try to understand it in this simpler context.
The crucial insight is the fact that QM is linear. So to understand how a wave packet scatters, you can expand the packet into plane waves and consider each plane wave separately. A nice analysis can be found e.g. in the book Bohm and Hiley, The Undivided Universe, Sec. 5.2.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
