QM: Infinitesimal Generator for Scale Transformation
In summary, the scale transformation is a continuous transformation that can be described by the equation D_{s}f(x) = f(sx), where s is a real number. This includes the identity transformation when s=1. To find the infinitesimal generator for this transformation, we can use the same method as for the translation operator, where \frac{p}{\hbar} is the generator for infinitesimal translation. Further information can be found in graduate-level textbooks for quantum mechanics.
brooke1525
The scale transformation is a continuous transformation which acts on a function f(x) according to
[tex]D_{s}[/tex]f(x) = f(sx)
where s is a real number. There is a continuous family of such transformations, including the identity transformation corresponding to s = 1. Calculate the infinitesimal generator for scale transformation in terms of familiar quantum operators.
This question was in a foreign language to me. I don't recall ever hearing of such a thing as an 'infinitesimal generator' in my quantum mechanics course, so I have absolutely NO clue what this question means or how to do it. Any guidance is much appreciated.
To demonstrate how we found the generator, let's consider the case of the translation operator
[tex] T(x)[f(x)] = f(x-a) [/tex] (translation by a)
For an infinitesimal translation [tex]\delta[/tex]
[tex] T(\delta)[f(x)] = f(x-\delta) = f(x) - \delta \frac{df(x)}{dx} = \left( 1 - \delta \frac{d}{dx} \right) f(x) = \left( 1 - i\delta\frac{p}{\hbar} \right) f(x) [/tex]
In this case, [tex]\frac{p}{\hbar}[/tex] (or just p) is called the generator of the infinitesimal translation.
Maybe you can proceed accordingly for the scale trasformation?
For further information you may consider any graduate-level textbooks for QM. (e.g. Sakurai)
Related to QM: Infinitesimal Generator for Scale Transformation
1. What is QM: Infinitesimal Generator for Scale Transformation?
QM: Infinitesimal Generator for Scale Transformation is a mathematical concept used in quantum mechanics to describe the transformation of physical systems under scale changes. It is also known as the "dilatation operator" or "scaling operator".
2. How does the QM: Infinitesimal Generator for Scale Transformation work?
The QM: Infinitesimal Generator for Scale Transformation is represented by a mathematical operator that acts on the wave function of a quantum system, causing it to change in a specific way under scale transformations. This operator is closely related to the Hamiltonian operator, which represents the total energy of the system.
3. What is the significance of QM: Infinitesimal Generator for Scale Transformation in quantum mechanics?
The QM: Infinitesimal Generator for Scale Transformation is a fundamental concept in quantum mechanics that helps us understand how physical systems behave under changes in scale. It is essential for describing the behavior of quantum systems at different length scales and has applications in many areas of physics, including particle physics and condensed matter physics.
4. How is QM: Infinitesimal Generator for Scale Transformation related to symmetry in quantum mechanics?
The QM: Infinitesimal Generator for Scale Transformation is closely related to the concept of symmetry in quantum mechanics. This operator is a generator of scale transformations, and symmetries can be thought of as operations that leave a physical system unchanged. This relationship is described by the Noether's theorem in quantum mechanics.
5. Can QM: Infinitesimal Generator for Scale Transformation be applied to classical systems?
Yes, QM: Infinitesimal Generator for Scale Transformation can be applied to classical systems as well. It is a general concept that describes the behavior of physical systems under scale transformations, and it has applications in both classical and quantum mechanics. However, the mathematical representation of this operator may differ in classical and quantum mechanics.
  • Differential Equations
  • Topology and Analysis
