QM light experiements at home.
In summary, the conversation discusses the topic of performing quantum mechanics and light experiments at home. The participants share their interests and experiences with various experiments, including Young's double slit experiment and single slit diffraction. They also mention simple and affordable materials, such as laser pointers and household objects, that can be used for these experiments. Some participants express their surprise at the accessibility and low cost of these materials, while others share their doubts about the effectiveness of these experiments in demonstrating quantum properties. Overall, the conversation provides a range of ideas and suggestions for conducting DIY quantum experiments at home.
Glenn
Hi,
Reading about physics is a pastime of mine. I have read about many of the famous experiemts such as Young's double slit experiment and such.
I would like to do some of these experiements at home to start teaching my kids about QM and light.
What types of QM light experiments are within reach for the serious home experimenter? Are there any books or references that are tailored to this type of work?
I am an engineer by day, spend my after hours building full size experimental aircraft, telescopes, etc... so complex or precise construction won't scare me away, nor will a having to purchase some moderately priced components if need be.
Any thoughts or recommendations?
Thanks,
Glenn
there is an easy experiment with single slit diffraction. All you need is a 5 dollar laser, you can purchace them nowadays in convenence stores. What you do is take a human hair, strap it vertically between two holders and let there be vertical portion hanging out in mid air. Now aim your laser at the hair, and observe the effect about 5m away. It would act as a single slit and it should have a single slit diffraction pattern. You can calculate the width of the hair by measuring out the spacing of the fringes of light 5 m away. Use equations like dsin(theta) = m(lamda), where d is the width of the slit, or hair in this case. m is the fringe number as an integer, starting from the centre fringe as 0. Lamda is the wavelength of light. You can also use dx/L = m(lamda), where x is the fringe spacing, and L is the distance from the screen to the hair.
You can also do and experiment with soap bubbles. When you watch a soap bubble, you see different colours at different heights of it. This is double inversion, and it teaches about thickness of the bubble and the wavelenght of light.
You can also do a diffraction grating by aiming your lased at a cd. You will see a grating appear on your ceeling if you aim the laser at a 45 degree angle. Using the equations I stated above, you can find out lots of neat stuff about CD's and light.
My God! Now people refer casually to "5 dollar lasers" that you can buy in convenience stores! Am I the only one so old that I can remember when lasers cost a hundred thousand dollars and required a whole room to themselves?
(Now that I think of it, I also remember when computers required a whole room to themselves- and had 16 K memory!)
Oh, phew! I thought I was the only one who still remember computer punch cards! :)
Zz.
You don't need a laser in order to perform the Yojung's double slit experiment, infact all you need is a light bulb, some 'blinds' and a metal sheet with suitably sized slits (when I was school we had loads of these kits consisting of a normal light bulb in a wooden frame with suitable places for blinds and slits to be slotted in).
Of course though ther double slit experiment only really demsontsrtes the classical wave model of light and doesn't in itself demonstrate the need for quantum physics.
Indeed, I think that if you want to demonstrate quantum properties, that you need one, or a few, photomultiplier tubes, with associated electronics, and a oscilloscope and/or an acquisition system on a PC. This can quickly become expensive (although maybe not for someone who builds airplanes in his spare time :biggrin:
cheers,
Patrick.
It's a question that's been asked svereal time before and I've always been a little dubious of whether some of the cut-price experiments that have been described will unambigously demonstrate what they are meant to demonstarte.
That said I guess that an experiment to illustarte the photoelectric effect and thus show the quantum nature of light wouldn't be too hard to perform.
I have a way. Take a card from a deck or an index card or something, get a flashlight, and poke two holes in it that is smaller than the circumfrence of the flashlight head, and at night put the card up to the light with the two holes inside, and aim it at a ceiling or wall. You will see two lights, but in the middle will be the brightest spot of all, with two spirals connected. It is very beautiful, but it is too complicated to write how it does this here.
FAQ: QM light experiements at home.
What is "QM light experimentation"?
QM light experimentation, or quantum mechanics light experimentation, refers to conducting experiments at home that involve the principles of quantum mechanics, such as the dual nature of light and the particle-wave duality.
Is it possible to conduct QM light experiments at home?
Yes, it is possible to conduct QM light experiments at home using basic materials such as lasers, prisms, and diffraction gratings. There are many online resources and DIY kits available for conducting these experiments.
What are some examples of QM light experiments that can be done at home?
Some examples of QM light experiments that can be done at home include the double-slit experiment, the photoelectric effect, and the diffraction of light through a narrow slit. These experiments help to demonstrate the wave-particle duality of light and its quantized nature.
Can QM light experiments at home provide valuable insights into quantum mechanics?
Yes, QM light experiments at home can provide valuable insights into the principles of quantum mechanics, as they allow for hands-on experience and visualization of these complex concepts. They can also spark curiosity and interest in the subject for those who may not have access to a formal laboratory setting.
Are there any safety precautions to keep in mind when conducting QM light experiments at home?
Yes, it is important to always follow safety precautions when conducting any type of experiment, including QM light experiments. This may include wearing protective eyewear and handling lasers with caution. It is also important to carefully read and follow instructions provided by reputable sources to ensure safe and accurate experimentation.
