QM: Magnus expansion, Gaussian integral
In summary, the time-evolution operator for a time-dependent Hamiltonian can be expressed using a Magnus expansion, with the first two terms being given by \hat{F}_1=\int_{t_0}^t\hat{H}(t_1)dt_1 and \hat{F}_2=\int_{t_0}^t\int_{t_0}^{t_1}[\hat{H}(t_2),\hat{H}(t_1)]dt_2dt_1. For the case of a Harmonic oscillator interacting with an external field of the form \hat{V}=\hat{V}_0f(t), the Magnus expansion can be evaluated to second order
Bapelsin
The time-evolution operator [tex]\hat{U}(t,t_0)[/tex] for a time-dependent Hamiltonian can be expressed using a Magnus expansion, which can be written
[tex]\hat{U}(t,t_0)=e^{\hat{A}(t,t_0)}=exp\left(\sum_{n=1}^{\infty}\frac{1}{n!}\left(\frac{-\imath}{\hbar}\right)^n\hat{F}_n(t,t_0)\right)[/tex]
The first two terms are given by
[tex]\hat{F}_1=\int_{t_0}^t\hat{H}(t_1)dt_1[/tex]
[tex]\hat{F}_2=\int_{t_0}^t\int_{t_0}^{t_1}[\hat{H}(t_2),\hat{H}(t_1)]dt_2dt_1[/tex]
Consider a Harmonic oscillator with [tex]\hat{H}=\hat{H}_0 + \hat{V}(t)[/tex] where
[tex]\hat{H}_0=\frac{\hat{p}^2}{2m}+\frac{1}{2}m\omega^2\hat{x}^2[/tex]
It interacts with an external field of the form [tex]\hat{V}=\hat{V}_0f(t)[/tex]
Evaluate the Magnus expansion to second order for the case [tex]\hat{V}_0=V_0\hat{x}[/tex] and [tex]f(t)=e^{-t^2/\sigma^2}[/tex]
See above.
First term: [tex]\hat{F}_1=\int_{t_0}^t\left(\frac{\hat{p}^2}{2m}+\frac{1}{2}m\omega^2\hat{x}^2+V_0\hat{x}e^{-t^2/\sigma^2}\right)dt_1= \left(\frac{\hat{p}^2}{2m}+\frac{1}{2}m\omega^2\hat{x}^2\right)\cdot(t-t_0)+ ?[/tex]
Second term (after solving the commutator specified above): [tex]\hat{F}_2=\frac{1}{m}V_0\imath\hbar\hat{p}\int_{t_0}^t\int_{t_0}^{t_1}\left(e^{-t_2^2/\sigma^2}-e^{-t_1^2/\sigma^2}\right)dt_1dt_2 = ? + ?[/tex]
How do I integrate the Gaussian functions above? It seems like the integrals only are easily solvable when integrated from [tex]-\infty[/tex] to [tex]\infty[/tex], is there any trick to get past this problem?
Any kind of help appreciated!
Just make use of the error function:
[tex]\text{erf}(x)\equiv\frac{2}{\sqrt{\pi}}\int_0^x e^{-u^2}du[/tex]
And remember ,
[tex]\int_{t_0}^{t} f(t_1)dt_1=\int_{0}^{t} f(t_1)dt_1-\int_{0}^{t_0} f(t_1)dt_1[/tex]
Related to QM: Magnus expansion, Gaussian integral
1. What is the Magnus expansion in quantum mechanics?
The Magnus expansion is a mathematical technique used in quantum mechanics to simplify and approximate the time evolution of a system. It involves expanding the time-evolution operator in a series of terms, with each term containing a higher order of the system's Hamiltonian. This allows for more accurate calculations of quantum mechanical systems.
2. How is the Gaussian integral used in quantum mechanics?
The Gaussian integral is a mathematical integral that appears frequently in quantum mechanics, particularly in the calculation of path integrals and partition functions. It is often used to evaluate the probability amplitudes of quantum states and to calculate the expectation values of operators in quantum systems.
3. What are the advantages of using the Magnus expansion in quantum mechanics?
The Magnus expansion offers several advantages in quantum mechanics. It allows for a more accurate and efficient calculation of time-evolution operators, making it a valuable tool for studying complex quantum systems. It also provides a better understanding of the dynamics of quantum systems and their stability.
4. Are there any limitations to the Magnus expansion in quantum mechanics?
Like any mathematical technique, the Magnus expansion has its limitations. It is most useful for systems with small perturbations, and its accuracy decreases as the perturbations become larger. Additionally, the convergence of the expansion can be slow, making it challenging to use for certain systems.
5. How is the Magnus expansion related to other techniques in quantum mechanics?
The Magnus expansion is closely related to other techniques in quantum mechanics, such as the Dyson series and the Baker-Campbell-Hausdorff formula. In fact, the Magnus expansion can be seen as a generalization of these techniques, allowing for a more complete and accurate calculation of time-evolution operators in quantum systems.
