WWCY
- 479
- 12
Hi all,
My question is in reference to the following paper: https://arxiv.org/pdf/1202.1783.pdf
In equation 3.8, the author computes an order-of-magnitude approximation of probability of measuring negative momentum from the following wavefunction:
\Psi_k =\sum_{k=1,2} \frac{B_k}{\sqrt{4\sigma ^2 + 2it}} \exp (ip_k (x - \frac{p_k}{2}t) - \frac{(x - p_k t)^2}{4\sigma ^2 + 2it})
Equation 3.8 is:
$$\int_{-\infty}^{0} dp \exp[-200(p-0.3)^2]$$
From what I understand, one should first take a Fourier-Transform of the above wavefuction, find ##|\Psi_k (p,t)|^2## and then take an integral from ##-\infty## to ##0## to get an expression that allows such a computation.
However, I'm not so sure what the term "order-of-magnitude approximation" entails. Would it be right to assume that the computation steps I mentioned above only considers terms of the highest order of magnitude?
Thanks in advance for any assistance.
Equation 3.8 is:
