QM questions: MO theory orbital combination
In summary, the linearity principle prohibits taking linear combinations of the squared-orbitals because doing so would result in wavefunctions with no phases.
kayan
37
1) When we learn about MO theory, we learn that there are different ways to combine atomic orbitals to find the molecular orbitals for a molecule. However, going back to the fundamental/physical meaning of orbitals, orbitals are the wavefunctions. Wavefunctions do not have any physical meaning (so I'm told). However, when you square the wavefunction, suddenly it represents the spatial probability of finding the electron.
Getting to my question: why is it that in MO theory, the AOs (no physical meaning) are added to construct the MOs instead of combining the SQUARE of the AOs (which have physical meaning) to construct the MOs? To see this from my perspective, think about the physicality of what we are doing: we are saying that if we have, say, 2 atoms close to each other, then a bond forms if the electrons are concentrated in between the nuclei. It would make more sense to me that you add the square of the AOs together since you want to add the regions of electron probability.
I thought about this question while thinking about the concept of orbital phase. If we added the square of the orbitals rather than the orbitals themselves, then there would be no phases since all negative wavefunctions would go positive. But the concept of phase is so central in MO theory. I'm sure this conclusion is wrong, but trying to reconcile it with a physical picture is making it hard to see why.
The linearity principle which allows you to take sums of quantum states is valid only for wavefunctions themselves, not for their squares. So a molecular orbital must still be an orbital, hence on an equal footing with the atomic orbitals which is made up from.
Thanks.
Why does the linearity principle prohibit taking linear combinations of the squared-orbitals? Also, is there a more physical explanation for this?
Because the whole mathematical machinery is based on vectors (of Hilbert spaces), not on reals (vectors' magnitudes). An atomic or a molecular orbital is a state and states are vectors in a Hilbert space by the most common axiomatization of Quantum Mechanics.
That's why the phase is important, because it's assigned to the wavefunction, not to its square.
You should also remember that the MO's also aren't physical observable objects. Orbitals are also not general wavefunctions but only one-particle wavefunctions. We use them as basis states to approximate the whole many body wavefunction of a molecule. Even the latter one is not an observable quantity but we can calculate all relevant properties of the molecules from expressions quadratic in the wavefunction.
FAQ: QM questions: MO theory orbital combination
1. What is MO theory?
MO theory, or molecular orbital theory, is a method used in chemistry to describe the bonding and properties of molecules based on the combination of atomic orbitals. It is a quantum mechanical approach that takes into account the wave-like nature of electrons and their interactions within a molecule.
2. How is MO theory used?
MO theory is used to predict the electronic structure and properties of molecules. It can provide information about the stability, reactivity, and spectroscopic properties of a molecule. It is also used to explain and predict the shapes of molecules and their bond strengths.
3. What is orbital combination in MO theory?
Orbital combination in MO theory refers to the process of combining atomic orbitals to form molecular orbitals. This can result in bonding or antibonding orbitals, which determine the stability or instability of a molecule. The combination of atomic orbitals is based on the principle of wave interference and results in the delocalization of electrons in a molecule.
4. What is the difference between bonding and antibonding orbitals?
Bonding orbitals are lower in energy and result from the constructive interference of atomic orbitals. They contribute to the stability of a molecule by allowing electrons to be shared between atoms. On the other hand, antibonding orbitals are higher in energy and result from the destructive interference of atomic orbitals. They contribute to the instability of a molecule by preventing electron sharing between atoms.
5. How does MO theory explain the properties of molecules?
MO theory explains the properties of molecules by taking into account the electronic structure of a molecule, which is determined by the combination of atomic orbitals. The number and type of molecular orbitals can determine the stability, reactivity, and spectroscopic properties of a molecule. It can also explain the bond lengths, bond strengths, and molecular shapes observed in molecules.
