QR decomposition with permutation matrix
In summary, QR decomposition with permutation matrix is a mathematical technique used to factorize a matrix into an orthogonal matrix and an upper triangular matrix, with the additional use of a permutation matrix. This method differs from standard QR decomposition by incorporating the use of a permutation matrix, which helps improve the numerical stability and efficiency of the decomposition. The purpose of using a permutation matrix in QR decomposition is to improve the conditioning of the triangular matrix and reduce the number of operations needed. This decomposition is useful in solving linear systems of equations, as well as in various fields such as engineering, physics, and statistics. It also has applications in data compression, signal processing, image processing, and machine learning algorithms.
mathmari
MHB
5,049
Hey! :giggle:
At the QR-decomposition with permutation matrix is the matrix $R$ equal to $R=G_3^{-1}P_1G_2^{-1}P_0G_1^{-1}A$ or $G_3P_1G_2P_0G_1A=R$? Which is the correct one? Or are these two equivalent?
In general, it holds that $QR=PA$, right?
:unsure:
Hey mathmari!
It depends on how we define the $G_i$ and $P_j$ to say which one we should use.
The important part is that we get indeed a right upper matrix when we multiply them.
Other than that, those 2 expressions are equivalent but not the same. 🤔
According to wiki, we have $QR=AP$. 🤔
I have done the following : \begin{align*}\begin{pmatrix}3 & 1 & -3 & 2 \\ -2 & 1 & 0 & 0 \\ 2 & -2 & 4 & 1 \\ 0 & -1 & -1 & 3\end{pmatrix} & \ \overset{Z_2:Z_2+\frac{2}{3}\cdot Z_1}{\longrightarrow} \ \begin{pmatrix}3 & 1 & -3 & 2 \\ 0 & \frac{5}{3} & -2 & \frac{4}{3} \\ 2 & -2 & 4 & 1 \\ 0 & -1 & -1 & 3\end{pmatrix} \\ & \overset{Z_3:Z_3-\frac{2}{3}\cdot Z_1}{\longrightarrow} \begin{pmatrix}3 & 1 & -3 & 2 \\ 0 & \frac{5}{3} & -2 & \frac{4}{3} \\ 0 & -\frac{8}{3} & 6 & -\frac{1}{3} \\ 0 & -1 & -1 & 3\end{pmatrix} \\ & \overset{Z_2\leftrightarrow Z_3}{\longrightarrow} \begin{pmatrix}3 & 1 & -3 & 2 \\ 0 & -\frac{8}{3} & 6 & -\frac{1}{3} \\ 0 & \frac{5}{3} & -2 & \frac{4}{3} \\ 0 & -1 & -1 & 3\end{pmatrix} \\ & \overset{Z_3:Z_3+\frac{5}{8}\cdot Z_2}{\longrightarrow} \begin{pmatrix}3 & 1 & -3 & 2 \\ 0 & -\frac{8}{3} & 6 & -\frac{1}{3} \\ 0 & 0 & \frac{7}{4} & \frac{9}{8}\\ 0 & -1 & -1 & 3\end{pmatrix} \\ & \overset{Z_4:Z_4-\frac{3}{8}\cdot Z_2}{\longrightarrow} \begin{pmatrix}3 & 1 & -3 & 2 \\ 0 & -\frac{8}{3} & 6 & -\frac{1}{3} \\ 0 & 0 & \frac{7}{4} & \frac{9}{8}\\ 0 & 0 & -\frac{13}{4} & \frac{25}{8}\end{pmatrix} \\ & \overset{Z_3 \leftrightarrow Z_4}{\longrightarrow} \begin{pmatrix}3 & 1 & -3 & 2 \\ 0 & -\frac{8}{3} & 6 & -\frac{1}{3} \\ 0 & 0 & -\frac{13}{4} & \frac{25}{8} \\ 0 & 0 & \frac{7}{4} & \frac{9}{8} \end{pmatrix} \\ & \overset{Z_4 : Z_4+\frac{7}{13}\cdot Z_3}{\longrightarrow} \begin{pmatrix}3 & 1 & -3 & 2 \\ 0 & -\frac{8}{3} & 6 & -\frac{1}{3} \\ 0 & 0 & -\frac{13}{4} & \frac{25}{8} \\ 0 & 0 & 0 & \frac{73}{26} \end{pmatrix} \end{align*}
After the Gauss elimination method do we get the matrix $R=G_3^{-1}P_1G_2^{-1}P_0G_1^{-1}A$ : \begin{equation*}R=\begin{pmatrix}3 & 1 & -3 & 2 \\ 0 & -\frac{8}{3} & 6 & -\frac{1}{3} \\ 0 & 0 & -\frac{13}{4} & \frac{25}{8} \\ 0 & 0 & 0 & \frac{73}{26} \end{pmatrix} \approx\begin{pmatrix}3 & 1 & -3 & 2 \\ 0 & -2,6667 & 6 & -0,3333 \\ 0 & 0 & -3,25 & 3,125 \\ 0 & 0 & 0 & 2,8077 \end{pmatrix}\end{equation*}
From the steps of Gauss method we get the matrices \begin{equation*}G_1=\begin{pmatrix}1 & 0 & 0 &0 \\ \frac{2}{3} & 1 & 0 & 0 \\ -\frac{2}{3} & 0 & 1 & 0 \\ 0 & 0 & 0 & 1\end{pmatrix} \ , \ G_2=\begin{pmatrix}1 & 0 & 0 &0 \\ 0 & 1 & 0 & 0 \\ 0 & \frac{5}{8} & 1 & 0 \\ 0 & -\frac{3}{8} & 0 & 1\end{pmatrix} \ \text{ and } \ G_3=\begin{pmatrix}1 & 0 & 0 &0 \\ 0 & 1 & 0 & 0 \\ 0 & 0 & 1 & 0 \\ 0 & 0 & \frac{7}{13} & 1\end{pmatrix}\end{equation*}
We have the permutation matrices \begin{equation*}P_0=\begin{pmatrix}1 & 0 & 0 & 0 \\ 0 & 0 & 1 & 0 \\ 0 & 1 & 0 & 0 \\ 0 & 0 & 0 & 1 \end{pmatrix} \ \text{ and } \ P_1=\begin{pmatrix}1 & 0 & 0 & 0 \\ 0 & 1 & 0 & 0 \\ 0 & 0 & 0 & 1 \\ 0 & 0 & 1 & 0 \end{pmatrix}\end{equation*} We have \begin{equation*}P=P_1\cdot P_0=\begin{pmatrix}1 & 0 & 0 & 0 \\ 0 & 0 & 1 & 0 \\ 0 & 0 & 0 & 1 \\ 0 & 1 & 0 & 0 \end{pmatrix}\end{equation*}
We have that:
\begin{equation*}G_3\cdot P_1\cdot G_2\cdot P_0\cdot G_1\cdot A = R \Rightarrow A=\left (G_3\cdot P_1\cdot G_2\cdot P_0\cdot G_1\right )^{-1}\cdot R \Rightarrow PA=P\cdot \left (G_3\cdot P_1\cdot G_2\cdot P_0\cdot G_1\right )^{-1}\cdot R\end{equation*} So we have that $PA=QR$ with $Q=P\cdot \left (G_3\cdot P_1\cdot G_2\cdot P_0\cdot G_1\right )^{-1}$.
\begin{align*}Q&=P\cdot \left (G_3\cdot P_1\cdot G_2\cdot P_0\cdot G_1\right )^{-1}=P\cdot G_1^{-1}\cdot P_0^{-1}\cdot G_2^{-1}\cdot P_1^{-1}\cdot G_3^{-1}\\ & = \begin{pmatrix}1 & 0 & 0 & 0 \\ 0 & 0 & 1 & 0 \\ 0 & 0 & 0 & 1 \\ 0 & 1 & 0 & 0 \end{pmatrix} \cdot \begin{pmatrix}1 & 0 & 0 &0 \\ -\frac{2}{3} & 1 & 0 & 0 \\ \frac{2}{3} & 0 & 1 & 0 \\ 0 & 0 & 0 & 1\end{pmatrix} \cdot \begin{pmatrix}1 & 0 & 0 & 0 \\ 0 & 0 & 1 & 0 \\ 0 & 1 & 0 & 0 \\ 0 & 0 & 0 & 1 \end{pmatrix}\cdot \begin{pmatrix}1 & 0 & 0 &0 \\ 0 & 1 & 0 & 0 \\ 0 & -\frac{5}{8} & 1 & 0 \\ 0 & \frac{3}{8} & 0 & 1\end{pmatrix}\cdot \begin{pmatrix}1 & 0 & 0 & 0 \\ 0 & 1 & 0 & 0 \\ 0 & 0 & 0 & 1 \\ 0 & 0 & 1 & 0 \end{pmatrix}\cdot \begin{pmatrix}1 & 0 & 0 &0 \\ 0 & 1 & 0 & 0 \\ 0 & 0 & 1 & 0 \\ 0 & 0 & -\frac{7}{13} & 1\end{pmatrix} \\ & = \begin{pmatrix}1 & 0 & 0 & 0 \\ 0 & 0 & 1 & 0 \\ 0 & 0 & 0 & 1 \\ 0 & 1 & 0 & 0 \end{pmatrix} \cdot \begin{pmatrix}1 & 0 & 0 &0 \\ -\frac{2}{3} & 1 & 0 & 0 \\ \frac{2}{3} & 0 & 1 & 0 \\ 0 & 0 & 0 & 1\end{pmatrix} \cdot \begin{pmatrix}1 & 0 & 0 & 0 \\ 0 & 0 & 1 & 0 \\ 0 & 1 & 0 & 0 \\ 0 & 0 & 0 & 1 \end{pmatrix}\cdot \begin{pmatrix}1 & 0 & 0 &0 \\ 0 & 1 & 0 & 0 \\ 0 & -\frac{5}{8} & 1 & 0 \\ 0 & \frac{3}{8} & 0 & 1\end{pmatrix}\cdot \begin{pmatrix}1 & 0 & 0 &0 \\ 0 & 1 & 0 & 0 \\ 0 & 0 & -\frac{7}{13} & 1 \\ 0 & 0 & 1 & 0\end{pmatrix} \\ & = \begin{pmatrix}1 & 0 & 0 & 0 \\ 0 & 0 & 1 & 0 \\ 0 & 0 & 0 & 1 \\ 0 & 1 & 0 & 0 \end{pmatrix} \cdot \begin{pmatrix}1 & 0 & 0 &0 \\ -\frac{2}{3} & 1 & 0 & 0 \\ \frac{2}{3} & 0 & 1 & 0 \\ 0 & 0 & 0 & 1\end{pmatrix} \cdot \begin{pmatrix}1 & 0 & 0 &0 \\ 0 & -\frac{5}{8} & 1 & 0 \\ 0 & 1 & 0 & 0 \\ 0 & \frac{3}{8} & 0 & 1\end{pmatrix}\cdot \begin{pmatrix}1 & 0 & 0 &0 \\ 0 & 1 & 0 & 0 \\ 0 & 0 & -\frac{7}{13} & 1 \\ 0 & 0 & 1 & 0\end{pmatrix} \\ & = \begin{pmatrix}1 & 0 & 0 &0 \\ \frac{2}{3} & 0 & 1 & 0 \\ 0 & 0 & 0 & 1
\\ -\frac{2}{3} & 1 & 0 & 0\end{pmatrix} \cdot \begin{pmatrix}1 & 0 & 0 &0 \\ 0 & -\frac{5}{8} & 1 & 0 \\ 0 & 1 & 0 & 0 \\ 0 & \frac{3}{8} & 0 & 1\end{pmatrix}\cdot \begin{pmatrix}1 & 0 & 0 &0 \\ 0 & 1 & 0 & 0 \\ 0 & 0 & -\frac{7}{13} & 1 \\ 0 & 0 & 1 & 0\end{pmatrix} \\ & = \begin{pmatrix}1 & 0 & 0 &0 \\ \frac{2}{3} & 1 & 0 & 0 \\ 0 & \frac{3}{8} & 0 & 1
\\ -\frac{2}{3} & -\frac{5}{8} & 1 & 0\end{pmatrix} \cdot \begin{pmatrix}1 & 0 & 0 &0 \\ 0 & 1 & 0 & 0 \\ 0 & 0 & -\frac{7}{13} & 1 \\ 0 & 0 & 1 & 0\end{pmatrix} \\ & = \begin{pmatrix}1 & 0 & 0 &0 \\ \frac{2}{3} & 1 & 0 & 0 \\ 0 & \frac{3}{8} & 1 & 0
\\ -\frac{2}{3} & -\frac{5}{8} & -\frac{7}{13} & 1\end{pmatrix} \\ & \approx \begin{pmatrix}1 & 0 & 0 &0 \\ 0,6667 & 1 & 0 & 0 \\ 0 & 0,375 & 1 & 0
\\ -0,6667 & -0,625 & -0,5385 & 1\end{pmatrix} \end{align*} Which of the expressions of #1 is the correct one? :unsure:
You have defined the matrices $G_i$ and $P_j$ such that $G_3\cdot P_1\cdot G_2\cdot P_0\cdot G_1\cdot A = R$ haven't you? 🤔
So that is the correct expression.
What were you uncertain about? (Wondering)
However, didn't you do an LR-decomposition with permutation rather than a QR-decomposition? :unsure:
Note that the resulting $Q$ is not orthogonal.
So the expression $R=G_3^{-1}P_1G_2^{-1}P_0G_1^{-1}A$ is wrong, isn't it? :unsure:
Ah yes, it is the LR-decomposition. (Malthe)
It looks wrong to me yes. :unsure:
Ok! Thanks! :geek:
