QR factorization for a 4x4 tridiagonal symmetric matrix
In summary, the QR factorization of a 4x4 symmetric tridiagonal matrix reveals that the top left element, ##r_{14}##, of the matrix R and the bottom left 3 elements, ##q_{31}, q_{41}, q_{42}##, of the matrix Q are zero. However, visually predicting zeros in other rows of R is limited in scope and may not be possible.
pyroknife
613
$$\begin{bmatrix}
a_{11} & a_{12} & 0 & 0\\
a_{12} & a_{22} & a_{23} & 0\\
0 & a_{23} & a_{33} & a_{34} \\
0 & 0 & a_{34} & a_{44} \\
\end{bmatrix}
\begin{bmatrix}
q_{11} & q_{12} & q_{13} & q_{14} \\
q_{21} & q_{22} & q_{23} & q_{24} \\
q_{31} & q_{32} & q_{33} & q_{34} \\
q_{41} & q_{42} & q_{43} & q_{44} \\
\end{bmatrix}
\begin{bmatrix}
r_{11} & r_{12} & r_{13} & r_{14} \\
0 & r_{22} & r_{23} & r_{24} \\
0 & 0 & r_{33} & r_{34} \\
0 & 0 & 0 & r_{44} \\
\end{bmatrix}
For the given 4x4 symmetric tridiagonal matrix A, determine which elements of its QR factorization is zero. The trick is to determine this visually.
I plugged a simple 4x4 symmetric tridagonal matrix into MATLAB and took its qr factorization and found that the top left element, ##r_{14}## of the matrix R and the bottom left 3 elements, ##q_{31}, q_{41}, q_{42}## of the matrix Q are zero. But the task was to determine this with ease and visually. Is there a trick to do this? I am not seeing it.
If we look at the process for factorising, we see that the ##j##th entry in the top row of the R triangular matrix is proportional to ##\langle a_1,a_j\rangle##, where ##a_j## is the ##j##th column of the original matrix ##A##. For ##j=4## that inner product must be zero because the first two components of ##a_1## and the last two components of ##a_4## are zero.
Ahh thanks I see this. But what if some of the elements in the original matrix ##A## along the tridiagonal band are zero? This still seems to fit the definition of a tridiagonal matrix? But if, say, ##a_{11}## was 0, then the solution is not unique?
And also, how does your process apply to the elements of Q, and to rows 2-4 of matrix R?
Edit: you mean ##j##th entry in the top row of the R triangular matrix is proportional to ##\langle q_1,a_j\rangle## right?
Looking at the process as set out here, we see that the expression of an element of R in terms of columns of A is only simple in the first row. So I think it would be hard to visually predict zeros in other rows of R. It would be possible, but would require thinking several steps ahead (probably beyond me, without a paper and pencil).
If there were other zeros in the tridiag band, one could visually predict. For instance, if ##a_{23}=0## then we know that ##r_{13}## will be zero because ##\langle a_1,a_3\rangle=0##. Ditto for ##r_{12}## if ##a_{12}=a_{22}=0##. So the method is fairly limited in scope. I doubt that there is a visual method that can get any further than that. Since your MatLab result shows that there is only one zero to be found, perhaps your lecturer doesn't believe there is any more general method either. After all, if these things could be completely determined visually, why would there be a need for an algorithm?
Related to QR factorization for a 4x4 tridiagonal symmetric matrix
What is QR factorization for a 4x4 tridiagonal symmetric matrix?
QR factorization is a method used to decompose a matrix into an orthogonal matrix (Q) and an upper triangular matrix (R). In the case of a 4x4 tridiagonal symmetric matrix, the matrix is decomposed into a 4x4 orthogonal matrix and a 4x4 upper triangular matrix with zeros in the off-diagonal elements.
What is the purpose of QR factorization for a 4x4 tridiagonal symmetric matrix?
The purpose of QR factorization for a 4x4 tridiagonal symmetric matrix is to simplify the matrix into a form that is easier to work with and perform calculations on. This decomposition also allows for easier computation of the inverse and determinants of the original matrix.
How is QR factorization for a 4x4 tridiagonal symmetric matrix performed?
The QR factorization for a 4x4 tridiagonal symmetric matrix is typically done using the Householder transformation method. This involves repeatedly applying orthogonal transformations to the matrix until it is reduced to an upper triangular form. The resulting orthogonal matrix and upper triangular matrix are then the Q and R matrices of the QR decomposition.
What is the significance of a tridiagonal symmetric matrix in QR factorization?
A tridiagonal symmetric matrix is a special type of matrix that has a large number of zero elements. This makes the QR factorization process more efficient and reduces the number of calculations needed to decompose the matrix. Additionally, the resulting orthogonal matrix and upper triangular matrix have simpler structures, making it easier to perform further calculations on the decomposed matrix.
What are some applications of QR factorization for a 4x4 tridiagonal symmetric matrix?
QR factorization for a 4x4 tridiagonal symmetric matrix has numerous applications in scientific computing, engineering, and statistics. It is commonly used for solving systems of linear equations, computing eigenvalues and eigenvectors, and performing least squares approximations. It is also used in data compression and signal processing algorithms.
  • Linear and Abstract Algebra
