MHB Quadratic application question what was the jets speed from Bangkok to Tokyo
The discussion centers on a quadratic application problem involving a jet's speed from Bangkok to Tokyo, with a distance of 4800 km and a return speed reduced by 200 km/h. The key equations derived relate time, distance, and speed, leading to the quadratic equation v^2 + 200v - 480000 = 0. The solution reveals that the jet's speed from Bangkok to Tokyo is 600 km/h, as the negative root is discarded due to the requirement for positive speed values. Clarifications were made regarding the correct formulation of the speed equations and the interpretation of the roots. The final conclusion confirms the jet's speed as 600 km/h.
Wild ownz al
Hey this Quadratic application question is giving me trouble.
A jet flew from Tokyo to Bangkok, a distance of 4800km. On the return trip, the speed was decreased by 200km/h. If the difference in the times of the flights was 2 hours, what was the jets speed from Bangkok to Tokyo?
Just need the formula for the Jets speed and I should be fine with the rest.
This was my guess: 4800 = (x-200)(-2x)
Mathematics news on Phys.org
Hello, and welcome to MHB! (Wave)
I've moved your question to its own thread.
I would use the fact that time is distance per average speed. Let distances be measured in km and time in hrs. Let \(v\) be the plane's speed from Bangkok to Tokyo.
$$t-2=\frac{4800}{v+200}$$
$$t=\frac{4800}{v}$$
Now, these equations imply:
$$t=\frac{4800}{v+200}+2=\frac{4800}{v}$$
Multiply through by \(v(v+200)\):
$$4800v+2v(v+200)=4800(v+200)$$
Distribute after dividing through by 2, then collect like terms and arrange in standard form:
$$v^2+200v-480000=0$$
Factor:
$$(v+800)(v-600)=0$$
Discarding the negative root, we find:
$$v=600$$
Does this make sense?
AMAZING you are brilliant. Thank you :)
If the plane's speed is "decreased" by 200km/h then shouldn't it be (v - 200) instead of (v + 200)?
Also if you ended up with two roots how do you know which one is the planes speed?
The first equation represents the first leg of the journey, from Tokyo to Bangkok. But, \(v\) represents the speed on the second leg, the return trip, where the speed has been decreased by 200. And so the speed on the first leg must be \(v+200\).
Speed, in order to have any meaning, must be positive (it is a magnitude like distance), and so we discard the negative root.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
