Quadratic equation application
In summary, a quadratic equation is a mathematical expression in the form of ax^2 + bx + c = 0, used to represent a second degree polynomial. It has many real-life applications in fields such as physics, engineering, economics, and computer science. There are various methods for solving quadratic equations, and the number of solutions depends on the discriminant. In data analysis, quadratic equations can be used to model and predict relationships between variables.
paulmdrdo1
385
please help me get started with these problems.
1.) It took a faster runner 10 sec longer to run a distance of 1500 ft than it took a slower runner to run a distance of 1000 ft. If the rate of the faster runner was 5ft/sec more than the slower runner, what was the rate of each?
2.) It is desired to have an open bin with a square bottom, rectangular sides, and a height of 3m. If the material for the bottom costs \$5.40 per square meter and the material for the sides costs \$2.40 per square meter, what is the volume of the bin that can be constructed for \$63 worth of material?
THANKS!
Mathematics news on Phys.org
Let's begin with the first problem...
Let distances be measured in feet and time in seconds. Let $t$ be the time and $v$ be the speed of the slower runner. Using the relation between distance, constant speed and time:
\(\displaystyle d=vt\)
Can you construct the equations for the two runners? You will then have two equations in two unknowns.
$vt=1000$
$(v+5)(t+10)=1500$
do you mean like this? but I expect to get a quadratic equation. how's that?
Since you are asked for $v$, solve the first equation for $t$, and substitute into the second equation...it looks like a quadratic in $v$ will result. :D
my answers are
20ft/sec --slower runner
25ft/sec --faster runner
or
25ft/sec--- slower
30ft/sec--- faster
now how about the second problem?
We know the height $h$ is 3 m, but we don't know the length $x$ of the sides of the square bottom. We know the volume $V$ is:
\(\displaystyle V(x)=3x^2\)
The cost function is the area of the bottom times the cost in dollars per square meter of the bottom, plus the total area of the sides times the cost in dollars per square meter of the sides. Equating this to 63 will result in a quadratic in $x$.
$2(5.40)(x^2)+4(2.40)(3)(x)=63$
$10.8x^2+28.8x-63=0$
completing the square
$x^2+\frac{8}{3}x+(\frac{4}{3})^{2}=\frac{35}{6}+(\frac{4}{3})^2$
$x = 1.42m$
$V=(1.42)^2\times 3$
$V=6.05m^3$
is my answer correct?
You have an open bin rather than a closed box...
Oh yes! I just got excited and Included the part that should be open.
the answer is $V=8.33m^3$
I wound up with:
\(\displaystyle 3x^2+16x-35=0\)
\(\displaystyle (3x-5)(x+7)=0\)
Discarding the negative root, we are left with:
\(\displaystyle x=\frac{5}{3}\)
And so, the volume in cubic meters is:
\(\displaystyle V\left(\frac{5}{3}\right)=3\left(\frac{5}{3}\right)^2=\frac{25}{3}\)
MarkFL said:
I wound up with:
I'm just curious how did arrive at this?
I had:
\(\displaystyle 5.4x^2+28.8x-63=0\)
Then I multiplied through by \(\displaystyle \frac{10}{18}=\frac{5}{9}\)
to get:
\(\displaystyle 3x^2+16x-35=(3x-5)(x+7)=0\)
how did you know that multiplying the expression by that amount would give you a nice form? that's cool. please let me know.:eek:
Multiplying by 10 gets rids of the decimal point, and then the resulting numbers have 18 as their GCD. This gives you a quadratic with the same roots and having the smallest possible integer coefficients.
FAQ: Quadratic equation application
What is a quadratic equation?
A quadratic equation is a mathematical expression that contains a variable raised to the second power (also known as squared). It can be written in the form of ax^2 + bx + c = 0, where a, b, and c are constants and x is the variable.
What are some real-life applications of quadratic equations?
Quadratic equations are used in many fields such as physics, engineering, economics, and computer science. Some common applications include calculating projectile motion, designing bridges and buildings, predicting stock market trends, and creating computer graphics.
How do I solve a quadratic equation?
There are several methods for solving quadratic equations, including factoring, completing the square, and using the quadratic formula. The method you use will depend on the specific equation you are trying to solve.
Can quadratic equations have more than one solution?
Yes, quadratic equations can have two solutions (also known as roots) or no real solutions at all. The number of solutions depends on the discriminant (b^2 - 4ac), which is part of the quadratic formula.
How are quadratic equations used in data analysis?
In data analysis, quadratic equations can be used to model and predict relationships between variables. For example, a quadratic regression model can be used to analyze data that follows a parabolic pattern, such as the relationship between height and weight in humans.
17K
10K
