Quadratic & Equation of a Circle
In summary: In order to go from ##y = 2x - 3/3 \Rightarrow y = 2x - 1## you rearrange the first equation in the format to becoming ##3y = 2x-3## which becomes ##y=2x/3/3##... Right...You should have solved your quadratic equation. I further assume, that we are only interested in real values?I've substituted it in the second equation in place of ##y##.##x^2+((2x/3)/3)^2 = 45##Led me to this quadratic.. ##13x^2-12x-396=0##.This way doesn't look right to me
Physiona
131
Two equations are defined as follows:
chart?cht=tx&chf=bg,s,FFFFFF00&chco=000000&chl=%7Bx%7D%5E%7B2%7D%2B%7By%7D%5E%7B2%7D%3D45.png
What is the value of
Quadratic Format: ##ax^2+bx+c=0##
##y^-x## = ##1/y^x##
I'm not sure In how to attempt this style of question as I know quadratic and equation of a circle fully. (This question has the quadratic in a different format)[/B]
I've attempted to rearrange the second equation into making y the subject:
##3y= 2x-3##
##y= 2x-3/3##
This way doesn't look right to me, though my teacher applied me with this methodology. Any guidance as if it's correct or not and how I should progress into getting the right answer?
  • chart?cht=tx&chf=bg,s,FFFFFF00&chco=000000&chl=%7Bx%7D%5E%7B2%7D%2B%7By%7D%5E%7B2%7D%3D45.png
What is the value of View attachment 223081?
##3y= 2x-3##
##y= 2x-3/3##
How do you go from ##y = 2x - 3/3 \Rightarrow y = 2x - 1## from the linear equation to ##y^2 = ((2x/3/3)^2## in the circle equation?
Likes Physiona
I don't get where the ##y^2 = ((2x/3/3)^2## has come from the circle equation; because isn't this meant to be in place of ##y##?
of ##y##.
The quadratic looks fine, but the first equation should be ##x^2 + ( (2/3)x - 1)^2 = 45##.
Okay, but why is the first equation ##x^2 + ( (2/3)x - 1)^2 = 45##?
Is my quadratic and attempt of the question right...?
You should have tried. One solution of the two will lead to the answer. It's a line intersecting a circle, so only two possibilities.
Yes I got two solutions,
##x=6## and ##x=−5.07692##
I require y though. I'm presuming I substitute one value in the equation to find y as I need that. Which equation to choose and which value is tricky.
Physiona said:
Which equation to choose...
Guess which: the linear or the quadratic. One of them sounds easier than the other.
... and which value is tricky.
That's why I asked for a real or (many) complex solutions. You should calculate with ##-\frac{66}{13}## instead of the decimal number. Then you will at least get both solutions formally. But I guess only one is requested.
Likes Physiona
I presume the linear is easier.
The value out of the ones I've calculated, clearly ##x=6## is easier to use. And I obtain y which I then use on to figure out ##y^-x##, correct?
Yes. I would calculate both. So in principle you'll know all other solutions, too, or can at least write them down, depending on your knowledge of complex roots.
Probably faster than all of this 45 is the sum of two squares. Can you think of two simple whole numbers whose squares add up to 45?
(Are you sure the question was y-x and not y-x ?)
Likes Physiona
I don't get it either, but I just copied it exactly from what you wrote.
Related to Quadratic & Equation of a Circle
1. What is a quadratic equation?
A quadratic equation is an algebraic expression that contains a variable raised to the second power (x²) and a constant (a) multiplied by the variable (bx) and a constant (c).
2. How do I solve a quadratic equation?
To solve a quadratic equation, you can use the quadratic formula: x = (-b ± √(b²-4ac)) / 2a. Alternatively, you can also factor the equation and find the values of x that make each factor equal to 0.
3. What is the equation of a circle?
The equation of a circle is (x - h)² + (y - k)² = r², where (h,k) represents the coordinates of the center of the circle and r represents the radius.
4. How is the equation of a circle related to the quadratic equation?
The equation of a circle and the quadratic equation have a similar form, with both containing variables raised to the second power. However, the equation of a circle also includes constants that represent the center coordinates and the radius of the circle.
5. Can a quadratic equation be used to solve for the coordinates of a circle?
No, a quadratic equation cannot be used to solve for the coordinates of a circle. The equation of a circle is used to represent the relationship between the coordinates and the radius, while the quadratic equation is used to find the values of a single variable.
