Quadratic equation with roots of opposite signs
The discussion centers on finding the values of "a" for the quadratic equation 2x^2 - (a^3 + 8a - 1)x + (a^2 - 4a) = 0, which has roots of opposite signs. The key condition for this is that the product of the roots must be negative, leading to the inequality a^2 - 4a < 0. This simplifies to the range 0 < a < 4, confirming the book's answer. The participants clarify that the roots do not need to be equal in absolute value, focusing instead on the product being negative. The final conclusion is that the values of "a" that satisfy the condition are indeed within the interval (0, 4).
brotherbobby
At what values of ##a## does the equation ##2x^2-(a^3+8a-1)x+a^2-4a = 0## possess roots of opposite signs?
For a quadratic equation ##ax^2+bx+c=0## having roots ##\alpha,\beta##, the sum of the roots ##\alpha+\beta = -\frac{b}{a}## and product of the roots ##\alpha\beta = \frac{c}{a}##.
Given : The equation ##2x^2-(a^3+8a-1)x+a^2-4a = 0## with roots of opposite signs.
Required : What is the value of ##a## ?
Attempt : The roots of the equation must be of the form ##\alpha, -\alpha##. The sum of the roots ##0 = a^3+8a-1##.
I do not know how to solve this equation.
However, on plotting the graph of this function [##f(x) = x^3+8x-1##], I find that ##a = 0.125##.
However, this is not the answer in the book.
Answer : ##a \in (0;4)## (from book)
Any help would be welcome.
brotherbobby said:
What is the value of a ?
It asks for a range, not a value!
brotherbobby said:
The roots of the equation must be of the form ##\alpha, -\alpha## The sum of the roots ##0=a^3+8a−1##.
You make that up ! Nowhere is said that the absolute values should be equal !
What is a sufficient condition that two real numbers ##\alpha, \beta ## are of opposite sign ?
Likes docnet and Delta2
You should look for values of ##a## such that the product of the roots becomes negative.
Likes docnet
brotherbobby said:
Homework Statement:: At what values of ##a## does the equation ##2x^2-(a^3+8a-1)x+a^2-4a = 0## possesses roots of opposite signs?
Relevant Equations:: For a quadratic equation ##ax^2+bx+c=0## having roots ##\alpha,\beta##, the sum of the roots ##\alpha+\beta = -\frac{b}{a}## and product of the roots ##\alpha\beta = \frac{c}{a}##.
You have ##a## already in the original equation, so you shouldn't really use ##a## for the first coefficient here as well. You can and should simply write ##2x^2 + bx + c## here.
Hint: perhaps focus on ##c## and the quadratic forumula.
Likes docnet
Written in standard form the quadratic equation becomes
##x^2-\frac{(a^3+8a-1)}{2}x+\frac{a^2-4a}{2}=0##
The rule is, if the constant term is ##<0## then the roots have opposite signs.
So for which values of a does the constant term ##\frac{a^2-4a}{2}<0##?
Likes Delta2
BvU said:
What is a sufficient condition that two real numbers α,β are of opposite sign ?
That their product is negative?
Likes BvU
Thank you for your help. I have got it. Let me do the problem still for completeness' sake.
We have the equation ##2x^2-(a^3+8a-1)x+a^2-4a = 0## possessing roots of opposite signs.
We are asked for what values of ##a## will they do so?
Let the roots be ##\alpha, \beta##. They are of opposite signs, hence ##\alpha \beta = -\text{ve}##.
Original equation can be simplified to : ##x^2 - \frac{a^3+8a-1}{2}x + \frac{a^2-4a}{2} = 0##.
Product of the roots ##\alpha \beta = \frac{a^2-4a}{2} = -\text{ve}##.
Thus we have to find the value of ##a## for which ##a^2-4a = -\text{ve}## (since 2 times a negative number is negative.)
Continuing from above : ##a(a-4) = -\text{ve} \Rightarrow 0\le a \le 4\Rightarrow \boxed{a \in (0;4)}##, matching the answer from the book.
Thank you all very much.
Likes docnet and PeroK
  • · Replies 20 ·
  • · Replies 22 ·
