MHB Quadratic equations intersaction point is minimum instead of roots
The discussion centers on finding the roots of two quadratic functions within specified ranges and determining the relationship between these roots and the intersection point. The user notes that, for their defined ranges, the minimum value of the first derivative occurs at the intersection point rather than at the calculated roots. They seek to prove that the intersection point is always the minimum solution in this context. Clarifications are requested regarding the nature of the curves involved, and the user emphasizes their interest only in cases where the roots are real and within the specified ranges. The goal is to establish a mathematical proof for this observation.
gevni
I have 2 quadratic functions and I am interested in their root in the specific range. I use quadratic equation to get their roots and what I find that if their any real solution exist for both or any of the function that lie in it designated specific range, then the roots are maximum or minimum to the intersection point of range.
Let say here the intersection point is 5:
f(g) is for range [0<n<=5]
and
f(x) is for range [5<=n<10]
for f(g) real root using quadratic equation is 4.3 that lies within its range and results in equation =0 however, the minimum value of the first derivative I got is n=5 instead of n=4.3. And it is always the case and vice versa for f(x). How do I prove that intersection point in the range is always be the minimum solution?
Mathematics news on Phys.org
Can you clarify your question please? I didn't understand, what curves intersect: two parabolic curves each others, or parabolic curve and x-axis, or something else? Maybe provide a numerical example about your problem? That could make your question clearer too.(up)
Sorry about the confusion! Let me re-write my problem:
{GIVEN } \\
0 < x \le 5 \implies 0 < f(x) \le 5 \text { and } f(x) \text { is continuous,}\\
and \\
5 \le x < 10 \implies 5 \le g(x) < 10 \text { and } g(x) \text { is continuous,}\\
if f(x) or g(x) are not in the range then I am not interested, I am only interested in the case if roots are real and in range. I am trying to find the roots of both function individually and if roots are real and in range then the extrema is always on intersection point not on the roots that I got from quadratic equation, that is 5 in above case. How to prove it?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
