MHB Quadratic form, determine the surface
vincentvance
Hi,
I'm trying to solve this problem and I'm stuck.
What I want to do is determine the kind of surface from this equation:
x2-2y2-3z2-4xy-2xz-6yz = 11
Matrix representation:
1 -2 -1
-2 -2 -3
-1 -3 -3
I want to find the eigenvalues so I write the characteristic equation like this:
1-\lambda -2 -1
-2 -2-\lambda -3
-1 -3 -3-\lambda
(and the goal, of course, is to have this equal to zero to find the eigenvalues - lambda)
Then I want to reduce this to a 2x2 matrix and that's where I get stuck. I've done about 10 other problems similar to this one today and never did I get stuck at this point before, it makes me feel very confused.
Can anyone help me?
Thank you
Vincent
Hi, and welcome to the forum.
vincentvance said:
1-\lambda -2 -1
-2 -2-\lambda -3
-1 -3 -3-\lambda
I would swap the last two lines (this changes the sign of the determinant) and eliminate the leading $-2$ by subtracting double of line $\begin{pmatrix}-1&-3&-3-\lambda\end{pmatrix}$ from line $\begin{pmatrix}-2&-2-\lambda&-3\end{pmatrix}$.
\begin{pmatrix}
1-\lambda&-2&-1\\
-2&-2-\lambda&-3\\
-1&-3&-3-\lambda
\end{pmatrix}
\mapsto
\begin{pmatrix}
1-\lambda&-2&-1\\
-1&-3&-3-\lambda\\
0&4-\lambda&3+2\lambda
\end{pmatrix}
Then I would expand the determinant along the first column.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
