Quadratic Functions, and Completing the Square
In summary, In these three problems, the person struggled to solve them. They used the formulas provided to them and did not get the correct answer. They also asked for help with solving the problems and asked for the x- and y-intercepts for the function f(x) = 2xsquare + x - 6.
H.M. Murdock
34
I had a hard time completing the square of some problems. This is what I did with them, I would appreciate if someone could show me the mistake that I am doing and the right process in order to solve these problems.
Also, here there is an article about completing the square for anyone that dosent remeber about it.
http://www.uncwil.edu/courses/mat111hb/Izs/asolve/asolve.html#compsqr
First problem
Complete the square on y = 3xsquare - x + 1 to write it in the form y = a (x - h)square +k
y = 3xsquare - x +1
3xsquare/3 and - x/3 =
3 (xsquare - 1/3x) +1
(1/3)square = 1/9
3 (xsquare -1/3x + 1/9) + 1 - 1/3
The answer is y = 3 (x + 1/3) square 2/3
But the answer on my book is y = 3 (x - 1/6) square + 11/12
I d like to know what was wrong there.
Second problem
Complete the square on y = xsquare - 6x + 10 to write it in the form y = a (x -h)square +k
(xsquare -6x) + 10
(-6/2)square = 9
(xsquare - 6x + 9) 10 - 9
The answer is (x + 3)square + 1
However on my book the aswer is y = (x - 3)square + 1
I don't really know where did that "-3" came from.
Third problem
-What are the x- and y- intercepts for f(x) = 2xsquare + x - 6 ?
This quadratic funtions is in the form " axsquare + bx + c " so I used the formula " h = -b/2a "
in order to solve it.
a = 2 and b = 1 on the function
so h = -1/2(2) = -1/4
k = 2(-1/4) square + (-1/4) - 6
k = 1/8 - 1/4 - 6
k= 49/8
I would appreciate if anyone is able to tell me how to solve these 3 problems.
Thanks a lot in advance.
Hi,
on problem 1, You have to divide ALL of the terms by 3. I did this, and i didn't get what your answer is:
[tex]\frac{3x^2}{3}-\frac{x}{3}+\frac{1}{3}=0[/tex]
[tex]x^2-\frac{1}{3}x=-\frac{1}{3}[/tex]
that third term is then:
[tex]\left(\frac{1}{2}\cdot\frac{1}{3}\right)^2=\frac{1}{36}[/tex]
then add that to both sides:
[tex]x^2-\frac{1}{3}x+\frac{1}{36}=-\frac{1}{3}+\frac{1}{36}[/tex]
see what you get from there.
Second problem:
you got
[tex]x^2-6x+9=-1[/tex]
when you factor that you have:
[tex](x-3)^2+1 [/tex] (after you add the one back over)
Third problem:
You found the x-value for the minimum, not the x and y intercepts.
For x intercepts, set it equal to zero and solve.
Your y-int. is f(0).
CC
First problem:
as happyg1 said, you don't square (1/3). First you divide by 2, and then square that:
[(1/2)*(1/3)]^2 = (1/6)^2 = 1/36
and so
x^2 - x/3 + 1/36
is a perfect square, equal to
(x - 1/6)^2
Redbelly98 said:
First problem:
and so
x^2 - x/3 + 1/36
(x - 1/6)^2
Hi thanks a lot guys, I appreciate it , but where does the 2 of the division come from?
(x+a)^2=x^2+2xa+a^2. So if you see x^2+Ax, if it's part of the complete square (x+a)^2, A=2a. Just equate the coefficients of the linear factors.
Related to Quadratic Functions, and Completing the Square
1. What is a quadratic function?
A quadratic function is a mathematical function in the form of f(x) = ax^2 + bx + c, where a, b, and c are constants and x is the variable. It is also known as a second-degree polynomial function.
2. What is the vertex form of a quadratic function?
The vertex form of a quadratic function is f(x) = a(x-h)^2 + k, where (h,k) represents the coordinates of the vertex. This form is useful for graphing and finding the maximum or minimum value of the function.
3. How do you complete the square for a quadratic function?
To complete the square for a quadratic function, you need to add a constant term to both sides of the equation so that the expression inside the parentheses becomes a perfect square. Then, you can factor the perfect square and write the equation in vertex form.
4. What is the discriminant of a quadratic function?
The discriminant of a quadratic function is the expression b^2 - 4ac, which is used to determine the number and nature of the solutions to the quadratic equation. If the discriminant is positive, the equation has two real solutions. If it is zero, the equation has one real solution. And if it is negative, the equation has two complex solutions.
5. How do you graph a quadratic function?
To graph a quadratic function, you can plot points by substituting different values of x into the equation, or you can use the vertex form to determine the coordinates of the vertex and a few other points. You can also use the axis of symmetry (x = -b/2a) to find the x-coordinate of the vertex and then substitute it into the equation to find the y-coordinate.
