Quadratic Polynomial Problem: Proving Equality with Real Numbers
  • MHB
  • Thread starter anemone
In summary, a quadratic polynomial is a polynomial of degree 2, written in the form of ax^2 + bx + c. To prove equality with real numbers, the quadratic formula can be used. Any real numbers can be used for this proof. Proving equality is important for solving equations and understanding the relationship between quadratic expressions. Alternative methods for proving equality include completing the square and factoring, but the quadratic formula is the most versatile.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Let $P_1(x)=ax^2-bx-c,\,P_2(x)=bx^2-cx-a,\,P_3(x)=cx^2-ax-b$ be three quadratic polynomials where $a,\,b$ and $c$ are non-zero real numbers. Suppose there exists a real number $k$ such that $P_1(k)=P_2(k)=P_3(k)$, prove that $a=b=c$.
No one answered last week's POTW.(Sadface) However, you can find the suggested solution below:
We have three relations:
$ak^2-bk-c=m\\ bk^2-ck-a=m\\ ck^2-ak-b=m$
where $m$ is the common value.
Eliminating $k^2$ from these, taking these equations pair-wise, we get:
$(ca-b^2)k-(bc-a^2)=m(b-a)\\(ab-c^2)k-(ca-b^2)=m(c-b)\\(bc-a^2)k-(ab-c^2)=m(a-c)$
Adding these three we get
$(ab+bc+ca-a^2-b^2-c^2)(k-1)=0$
Thus, either $ab+bc+ca-a^2-b^2-c^2=0$ or $k=1$.
In the first case
$ab+bc+ca-a^2-b^2-c^2=0\\ \dfrac{1}{2}((a-b)^2+(b-c)^2+(c-a)^2)=0$
shows that $a=b=c$.
If $k=1$, then we obtain $a-b-c=b-c-a=c-a-b$, once again we obtain $a=b=c$.
FAQ: Quadratic Polynomial Problem: Proving Equality with Real Numbers
What is a quadratic polynomial?
A quadratic polynomial is a polynomial function of the form f(x) = ax^2 + bx + c, where a, b, and c are real numbers and x is the variable. It is a second-degree polynomial, meaning the highest power of x is 2.
How do you prove equality with real numbers in a quadratic polynomial problem?
To prove equality in a quadratic polynomial problem, you can use the quadratic formula or complete the square method to find the roots of the polynomial. If the roots are the same, then the polynomials are equal.
Can a quadratic polynomial have more than two solutions?
No, a quadratic polynomial can have a maximum of two solutions. This is because it is a second-degree polynomial, meaning it can only have two terms with the variable raised to the power of 2.
What is the discriminant in a quadratic polynomial?
The discriminant in a quadratic polynomial is the part of the quadratic formula under the square root sign, b^2 - 4ac. It helps determine the nature of the solutions of the polynomial. If the discriminant is positive, there are two real solutions. If it is zero, there is one real solution. And if it is negative, there are no real solutions.
How is a quadratic polynomial problem related to real-world applications?
Quadratic polynomial problems can be used to model real-world situations such as projectile motion, profit and loss analysis, and optimization problems. The solutions to these problems can help make predictions and inform decision-making in various fields, including science, engineering, and economics.
