MHB Quadratics: How to determine parabola equation.
  • Thread starter Thread starter James400
    Parabola
To determine the equations of parabolas given specific points, intercepts, and vertexes, the vertex form of a parabola is utilized. For the first parabola with a turning point at (1,6) and passing through (-1,8), the equation can be expressed as y=a(x-1)²+6, where 'a' is calculated using the provided point. The second parabola has x-intercepts at 2 and 7, and passes through (3,6), requiring a different approach to find its equation based on the intercepts. The discussion emphasizes the importance of showing work and understanding the steps involved in deriving the equations. Overall, participants are encouraged to share their thought processes for better assistance.
James400
Hi all. I need a bit of help determining the equation of some parabolas given points, intercepts and vertexes. Below are the exacts questions, any help will be much appreciated as I need this done soon!
1. A parabola has turning point (1,6) and passes through the point (-1,8). Find its equation.
2. A parabola has x-intercepts of 2 and 7 and passes through the point (3,6). Find
the equation of the parabola.
Please show working out!
Mathematics news on Phys.org
My reply to your other post holds here too. Please consider posting some of your work, or letting us know what you don't understand.
I'm a little confused as to where to start as a matter of fact!:) I know the final objective is to reach the equation in standard form using the information provided, but I'm not sure how to do that (the processes involved). I was just hoping to get a step through of the processes required to reach the answer.
Since we are given the vertex, let's use the vertex form of a parabola:
$$y=a(x-h)^2+k$$
Since the vertex (turning point) is given as $(1,6)$, we may write:
$$y=a(x-1)^2+6$$
Now, to determine $a$, we may use the other given point $(-1,8)$ as follows:
$$y(-1)=a(-1-1)^2+6=8$$
Solving the above equation for $a$, what do you get?
$$y=a(x-h)^2+k$$
$$y=a(x-1)^2+6$$
I'm all good with these questions now. I solved them a little while ago, but I'm still stuck on the other questions I posted.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
