MHB Quadratics: Quadratic Equations
The discussion focuses on solving the quadratic equation x^2 + px + 2p = 0. The discriminant is calculated as p^2 - 8p, which is essential for determining the nature of the solutions. For two solutions, the condition is p^2 - 8p > 0; for no solutions, p^2 - 8p < 0; and for one solution, p^2 - 8p = 0. Participants are encouraged to confirm calculations and explore the implications of the discriminant on the number of solutions. Understanding these relationships is crucial for solving quadratic equations effectively.
James400
Consider the quadratic equation x^2+px+2p=0
a. Find the discriminant.
b. Find the values of p for which there are 2 solutions.
c. Find the values of p for which there are no solutions.
d. Find the value of p for which there is 1 solution.
Please show working out! Thanks.
Mathematics news on Phys.org
How about your working out! :). How can we help if we don't know what you are struggling with :p.
For a. Find the discriminant:
=b^2-4ac
=p^2-8p
That's is as far as I have gotten, although I think that is right for a. correct me if I am wrong. So I just need to solve the others, although I have no idea how to do so...
Is anyone able to confirm whether a. is p^2-4-8p and help solve b through to d?
Ok, let's start from scratch.
$$ax^2+bx+c=0$$
$$a(x^2+\frac bax)=-c$$
$$a\left(x+\frac{b}{2a}\right)^2-\frac{b^2}{4a}=-c$$
$$a\left(x+\frac{b}{2a}\right)^2=\frac{b^2}{4a}-c$$
$$\left(x+\frac{b}{2a}\right)^2=\frac{b^2}{4a^2}-\frac ca$$
$$x+\frac{b}{2a}=\pm\sqrt{\frac{b^2}{4a^2}-\frac{4ac}{4a^2}}$$
$$x=-\frac{b}{2a}\pm\sqrt{\frac{b^2}{4a^2}-\frac{4ac}{4a^2}}$$
$$x=\frac{-b\pm\sqrt{b^2-4ac}}{2a}$$
Now plug your values for $a$, $b$ and $c$ into $b^2-4ac$.
Where is $b^2-4ac>0$? Less than $0$? Equal to $0$? Do you understand the relevance of these relationships?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
