I Quadrupole moment tensor calculation for ellipsoid
The discussion focuses on calculating the element Q_{11} of the quadrupole moment tensor for a homogeneously charged rotationally symmetric ellipsoid. The formula for the quadrupole tensor is provided, and the integration process is outlined, including the transformation of coordinates. A key point of clarification is the introduction of the Heaviside step function, θ(1 - ρ²/a² - z²/c²), which restricts the integral to the volume of the ellipsoid. This function ensures that the integration only considers points within the defined ellipsoidal shape. The conversation highlights the importance of correctly applying the Heaviside function in such calculations.
LeoJakob
Determine the element ##Q_{11}## of the quadrupole tensor for a homogeneously charged rotationally symmetric ellipsoid,
$$\rho=\rho_{0}=\text { const. for } \frac{x_{1}^{2}}{a^{2}}+\frac{x_{2}^{2}}{a^{2}}+\frac{x_{3}^{2}}{c^{2}} \leq 1 $$
The formula is $$Q_{i j}=\int \rho(\mathbf{r})\left(3 x_{i} x_{j}-\|\mathbf{x}\|^{2} \delta_{i j}\right) d^{3} \mathbf{r}$$
I would calculate: $$ Q_{11}=\rho_{0} \int d z \int \rho d \rho \int \limits_{0}^{2 \pi} d \phi \left(3 \rho^{2} \cos ^{2} \phi-\left(\rho^{2}+z^{2}\right)\right) $$
With ##x_1=\rho \cos \phi,\quad x_2=\rho \sin \phi, \quad x_3= z##, but in the solution they calculate:
$$ Q_{11}=\rho_{0} \int d z \int \rho d \rho \int \limits_{0}^{2 \pi} d \phi \theta\left(1-\frac{\rho^{2}}{a^{2}}-\frac{z^{2}}{c^{2}}\right)\left(3 \rho^{2} \cos ^{2} \phi-\left(\rho^{2}+z^{2}\right)\right) $$
Where does the term ##\theta\left(1-\frac{\rho^{2}}{a^{2}}-\frac{z^{2}}{c^{2}}\right)## come from?
That is the restriction of the integral to the ellipsoid.
Ahhh, thank you very much! So it is a Heaviside step function , please correct me if I misunderstood you.
Yes, it is the Heaviside function.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
