A Quadrupole radiation formula for gravity
Kostik
TL;DR Summary
Some help needed converting the formula for quadrupole radiation from geometrized units (##c=G=1##) to conventional units.
I derived the formula for the quadrupole radiation power emitted by a system of masses:
$$P=\frac{1}{45}\dddot{Q}_{kl}\dddot{Q}_{kl} .\quad\quad (*)$$ Note here that: (1) I am using geometrized units, so ##c=G=1##; (2) ##Q_{kl}## is the quadrupole tensor $$Q_{kl} = \int{(3x_k x_l - δ_{kl}\cdot r^2 )ρ} \, dV \quad (r^2\equiv x_k x_k)$$ and (3) repeated indices are summed over. (In Euclidean space ##R^3##, all indices are subscripts.)
This is essentially the same formula given by Landau & Lifshitz "Classical Theory of Fields, 4th Ed." (Eq. (110.16), p. 355) and Ohanian & Ruffini "Gravitation and Spacetime" (Eq. (5.75), p. 195): $$P=\frac{G}{45c^5}\dddot{Q}_{kl}\dddot{Q}_{kl} .$$ Landau & Lifshitz keep all factors of ##c## and ##G##, while Ohanian uses ##c=1## but keeps ##G## separate.
What I want to do is simply convert from geometrized units to conventional units, which means ##t## should be replaced by ##ct## and mass ##m## (or mass density ##\rho##) should be replaced by ##Gm/c^2## (or ##G\rho/c^2##).
Where I'm having trouble is that the power formula has a product ##\dddot{Q}_{kl}\dddot{Q}_{kl}##. So it seems to me that the correct way to convert ##(*)## to conventional units would be
$$P=\frac{1}{45} \left( \frac{G}{c^5} \right)^2 \dddot{Q}_{kl}\dddot{Q}_{kl} .$$ Obviously, this is wrong -- only one factor of ##G/c^5## should be used, which is also consistent with dimensional analysis. (In geometrized units, both sides of ##(*)## are dimensionless.)
I'm just not seeing why I should only add one factor of ##G/c^5##, when surely each factor of ##\dddot{Q}_{kl}## carries its own factor of ##G/c^5##? What am I missing here?
You just have to insert the factors of ##G## and ##c## so the dimensions match correctly. You know that ##[G/c^5] = M^{-1} L^{-2} T^3##. You also know that ##[\dddot{Q}] = [P] = ML^2 T^{-3}##, so ##[P]/[\dddot{Q}]^2 = M^{-1} L^{-2} T^3 = [G/c^5]##
But you have to also convert the LHS of the equation to conventional units, so one factor of ##G/c^5## goes on the LHS, and cancels one of the two factors of ##G/c^5## on the RHS, so the end result is one factor of ##G/c^5## on the RHS, as the references you give say.
Likes phyzguy and Kostik
Thank you!
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
