Qualitative theory of two-dimensional system
In summary, the qualitative behavior of the system of differential equations is described by the value of $\mu$.
Fantini
MHB
268
I am having trouble to work this question. It was asked in my exam in ordinary differential equations and I have no idea how to solve it.
Consider the system of differential equations
$$x' = \mu - x^2,$$
$$y' = - y.$$
Describe the qualitative behavior according to the value of $\mu$.
$$x' = \mu - x^2,$$
$$y' = - y.$$
What are the fixed points?
Are they sources or sinks?
Perhaps describe the possible solution curves by graphical inspection?
Fixed points happen at $(\pm \sqrt{\mu}, 0)$, but here is when the problems arise. If $\mu >0$ then we have one source and one sink, depending on whether it has positive and negative sign, respectively.
On the other hand, if $\mu \leq 0$ then I have complex eigenvalues with zero real part. How to go on about it?
Right.
Then you don't have fixed points.For a qualitative analysis I would tend to draw the solution curves for both $\mu > 0$ and $\mu < 0$, which would complete the qualitative analysis as far as I'm concerned.
If $\mu<0$ we can easily identify the vector field, $v(x,y)=(-,-)$ if $y>0$, $v(x,y)=(-,+)$ if $y<0$. Besides $v(x,0)=(-,0)$ for all $x\in\mathbb{R}$, so the $x$-axis is an invariant line. With this, you'll easily plot the phases plane.
$$x' = \mu - x^2,$$
$$y' = - y.$$
The two ODE are independent [one in x and one in y...] and, because $\mu$ is in the first, we focalize our attention on the ODE...
$\displaystyle x^{\ '} = \mu - x^{2}\ (1)$
It is a symple separate variables ODE, so that standard approach my be used. Supposing $\mu \ne 0$ [the case $\mu=0$ is to be treated separately...] You have...
$\displaystyle \frac{dx}{\mu - x^{2}} = d t \implies \frac{\tanh^{-1} (\frac{x}{\sqrt{\mu}})}{\sqrt{\mu}} = t + c \implies x = \sqrt{\mu}\ \tanh(\sqrt{\mu}\ t + c)\ (2)$
Very well!... now Your next step are...
a) find, using standard formulas, what is $\tanh(\sqrt{\mu}\ t + c)$...
b) analyse separately the cases $\mu>0$ and $\mu < 0$ [in the last case remember that is $\tanh i\ t = i\ \tan t$]...
c) analyse the case $\mu=0$...
Kind regards
$\chi$ $\sigma$
If $\mu>0$ we have 2 more invariant lines: $x=\pm \sqrt\mu$.
Are you sure I don't have any more fixed points? What if we somehow translate the complex number to two real solutions?
Fernando, by $v(x,y) = (-,-)$ do you mean that it is a sink? Sorry, I don't understand what you want to convey with this notation. :confused:
Kind regards
$\chi$ $\sigma$
Thank you $\chi$ $\sigma$, but it was written at the exam that we weren't required to solve for the equations, he said there was a simple way to do this. Furthermore, the original question said $x' = \mu + (-1)^{\text{academic number}} x^2$, which for some meant $x' = \mu + x^2$ and for others $x' = \mu - x^2$. He also explicitly stated that it did not matter much the sign, as long as the analysis was correct, hence why I chose the minus sign.
At the exam we didn't have access to the Hartman-Grobman theorem, but now we do. How could be such analysis carried out then?
By $v(x,y)=(-\mu-x^2,-y)$ we denote the vector field associated to the system. The linearized system associated to an equilibrium point $(x_0,y_0)$ is $$\begin{bmatrix}x'\\y'\end{bmatrix}=A \begin{bmatrix}x\\y\end{bmatrix},\quad A=J_v(x_0,y_0)= \begin{bmatrix}\frac{\partial v_1}{\partial x}(x_0,y_0)&\frac{\partial v_1}{\partial y}(x_0,y_0)\\\frac{\partial v_2}{\partial x}(x_0,y_0)&\frac{\partial v_1}{\partial x}(x_0,y_0)\end{bmatrix}=\begin{bmatrix}-2x_0&0\\0&-1\end{bmatrix}$$
For $\mu >0$ we have two equilibrium points $(\pm\sqrt{\mu},0)$ so,
$$J_v(\sqrt{\mu},0)=\begin{bmatrix}-2\sqrt{\mu}&0\\0&-1\end{bmatrix},\quad J_v(\sqrt{\mu},0)=\begin{bmatrix}2\sqrt{\mu}&0\\0&-1\end{bmatrix}$$
According to its eigenvalues, $(\sqrt{\mu},0)$ is an asymptotically stable node. (Have a look here for $\mu=1$) and $(-\sqrt{\mu},0)$ is a saddle point. (Have a look here for $\mu=1$). Also, have a look here to see the the complete phases plane
For $\mu=0$ we have only the equilibrium point $(0,0)$ and according to the eigenvalues of $J_v(0,0)$ we have an inconlusive case. But drawing the vector field we get its phases plane.
For $\mu<0$ we have no equilibrium points, but again, drawing the vector field we get its phases plane.
If x and y are real valued functions (which is what I assumed), an imaginary fixed point means that there is no fixed point (in real coordinates).
If x and y are complex valued functions, for $\mu < 0$ you get 2 fixed points at the complex coordinates $(\pm i \sqrt{-\mu},0)$.
Thanks for that!
I was trying to figure out how to make vector plots with W|A... and there they are! ;)
Allow me to present them as graphs.
$\mu < 0$ with no fixed points:
$\mu = 0$ with 1 saddle point:
$\mu > 0$ with 1 saddle point and 1 sink:
FAQ: Qualitative theory of two-dimensional system
What is the qualitative theory of two-dimensional systems?
The qualitative theory of two-dimensional systems is a mathematical framework used to analyze the behavior and properties of systems with two variables. It involves studying the dynamics of the system and identifying the possible equilibrium points, stability, and trajectories.
How is the qualitative theory of two-dimensional systems different from the quantitative theory?
The qualitative theory focuses on the overall behavior of the system, while the quantitative theory involves using numerical methods to solve and analyze the system. The qualitative theory is useful for understanding the general properties and trends of the system, while the quantitative theory provides more precise calculations.
What are some applications of the qualitative theory of two-dimensional systems?
The qualitative theory has various applications in fields such as physics, biology, economics, and engineering. It can be used to analyze and predict the behavior of complex systems, such as chemical reactions, population dynamics, and electronic circuits.
Can the qualitative theory of two-dimensional systems be applied to higher-dimensional systems?
Yes, the qualitative theory can be extended to higher-dimensional systems, but the analysis becomes more complex and challenging. In these cases, numerical methods and computer simulations are often used to study the behavior of the system.
Is the qualitative theory of two-dimensional systems limited to linear systems?
No, the qualitative theory can be applied to both linear and nonlinear systems. However, the analysis of nonlinear systems can be more challenging and may require more advanced techniques, such as bifurcation theory and chaos theory.
