A Quantifying nonlinearity from data
  • A
  • Thread starter Thread starter BillKet
    Data
The discussion revolves around extracting the non-linear component, f(x), from a function defined as y = ax + b + f(x), where f(x) is significantly smaller than ax and b. The user seeks a method to quantify deviations from linearity using only measured values of x and y. It is suggested to perform linear regression to determine the linear parameters a and b, then analyze the residuals (y - ax - b) to model the non-linearity. Visualizing the data through plotting could also aid in hypothesizing the form of f(x). Ultimately, the focus is on understanding non-linearity rather than the specific values of a and b.
BillKet
Hello! I have a function of the form:
$$y = ax + b + f(x)$$
and I can measure experimentally only x and y. I also know that ##f(x)<<ax,b##, where ##f(x)## is some non-linearity in x i.e. it can't be absorbed into the ##ax+b## part (for example ##f(x) = cx^2##), but I don't know its form. Is there a way to extract ##f(x)##, by measuring only ##x## and ##y##? I am basically wondering if I can quantify the deviation of the expression above from linearity and connect that to the value of x. Thank you!
As a first pass, you could be in a lot of trouble if ##f(x)=x^2+2x+1=(x+1)^2##, which is going to be literally indistinguishable from adding 2 to a, 1 to b, and ##f(x)=x^2##.
That said, it sounds like maybe you don't care, and you are happy to just think of ##f(x)## as ##x^2## in this case. Is that right?
Yes! I am fine with redefining a and b if needed (i.e. absorbing those terms you mentioned above). I am purely interested in any deviation from linearity, regardless of the actual value of a and b.
And the thing you care about specifically is trying to estimate y given a value of x? Are we assuming your measurements are perfect with no noise?
I think you would start with doing linear regression to get ##y \approx ax+b## for some ##a## and ##b##. Then compute ##y-ax-b##, and attempt to model it with your favorite parameterized function. If you have a specific example, just drawing a plot of that would probably be a good start for guessing the shape of the non linear piece
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
