Quantities in the Heisenberg Uncertainly Principle
In summary, the Heisenberg uncertainty principle is a principle that states that the degree of uncertainty in the position of a particle is inversely proportional to the precision of the measurement of its momentum. This principle is similar to the Heisenberg uncertainty principle for energy, in that the degree of uncertainty in the energy of a particle is inversely proportional to the precision of the measurement of its momentum.
Kremmellin
TL;DR Summary
I'd like to ask a question about quantities in the Heisenberg Uncertainly Principle
Hello, I am a Brazilian Physics student and would like to ask a question. Why are not all physical quantities related to each other by the degree of precision in the Heisenberg Uncertainty Principle? For example, why is it possible to determine the energy and position of a particle without its precision being inversely proportional to each other, but it is not possible to calculate energy and time with the same precision?
Hi, i am a Brazilian Physics student too.
When do you mean why, what exactly do you are waiting for an answer?
I mean, i believe there is two ways to answer it
Mathematically, which will show to you why this happens in some cases, and why it does not happen in other cases. And that is it, "it is true because we can show that it is true, and we observe in nature that it is true".
Or answering using an physical interpretation (maybe philosophically) to try to explain why make senses this is true, and not why this is true.
Likes Kremmellin
Because energy and position are not conjugate variables, but energy and time are:
https://en.wikipedia.org/wiki/Conjugate_variables
Likes Kremmellin
Actually, the correct term is conjugate observables (not "variables"). And time is actually not an observable, so there actually is not an energy-time uncertainty principle in the same way that there is, for example, a momentum-position uncertainty principle. There is something that is similar to an uncertainty principle with energy and time, but it takes more work to derive it. See, for example, here:
https://math.ucr.edu/home/baez/uncertainty.html
(Note that Baez in that article is using "operator" to mean the same thing as I used "observable" to mean above.)
Likes Kremmellin and vanhees71
Kremmellin said:
Summary:: I'd like to ask a question about quantities in the Heisenberg Uncertainly Principle
Let's take the example of a particle in an infinite square well. And consider an energy eigenstate. A measurement of energy has no uncertainty. And, as E=p22m, then a measurement of the magnitude of the momentum has no uncertainty. All the uncertainty is in the direction of the momentum: we know the magnitude of a measurement of momentum, but there's an equal probability of its being positive or negative. That means that the expected value of momentum is actually zero, and there is a uncertainty (variance or standard deviation) in the outcomes of momentum measurements.
The question you should be asking is why is the energy-time uncertainty relation similar to the HUP?
Note that time in QM is a parameter and not an observable. So, you should also be asking what does "precision in a measurement of time" mean?
Also, if you have an energy eigenstate, where the uncertainty in energy is zero, then the uncertainty in time is infinite! What is that supposed to mean? Does that mean that if you measure energy in an energy eigenstate, then a "measurement" of time is impossible?
Likes Kremmellin
The general Heisenberg uncertainty principle (HUP) for observables (and note that time is NOT an observable in QT for the reason that energy must be bounded from below to have a stable ground state; the energy-time uncertainty relation(s) have NOT the same meaning as the HUP for observables!):
$$\Delta A \Delta B \geq \frac{1}{2} |\langle [\hat{A},\hat{B}] \rangle|.$$
Then for ##\hat{B}=\hat{H}## note that
$$[\hat{A},\hat{H}]=\mathrm{i} \hbar \mathring{\hat{A}},$$
where ##\mathring{\hat{A}}## is the operator representing the time derivative of ##\hat{A}## (assumed that ##\hat{A}## is not explicitly time dependent).
So e.g., the HUP for position and energy reads
$$\Delta x \Delta E \geq \frac{\hbar}{2} |\langle \hat{v}_x \rangle|.$$
Here ##\hat{v}_x## is the velocity ##x##-component.
For the usual simple Hamiltonians for one particle
$$\hat{H}=\frac{1}{2m} \hat{\vec{p}}^2+V(\hat{\vec{x}})$$
of course you get
$$\hat{\vec{v}}=\frac{1}{m} \hat{\vec{p}}.$$
Note, however that in general ##\hat{\vec{p}}## is a canonical rather than the kinetic momentum. An important example is the motion of a (spin-0) particle in a magnetic field
$$\hat{H}=\frac{1}{2m} (\hat{\vec{p}}-q \vec{A}(\hat{\vec{x}}))^2,$$
where ##\vec{B}=\vec{\nabla} \times \vec{A}##.
Likes Kremmellin, PeroK and hutchphd
Related to Quantities in the Heisenberg Uncertainly Principle
1. What is the Heisenberg Uncertainty Principle?
The Heisenberg Uncertainty Principle is a fundamental concept in quantum mechanics that states that it is impossible to know the exact position and momentum of a particle simultaneously. This means that the more precisely we know the position of a particle, the less precisely we can know its momentum, and vice versa.
2. How does the Heisenberg Uncertainty Principle affect measurements?
The Heisenberg Uncertainty Principle affects measurements by placing a limit on the precision with which we can measure certain physical quantities. For example, if we try to measure the position of a particle very precisely, the act of measurement will inevitably change the momentum of the particle, making it impossible to know both quantities with absolute certainty.
3. What are the quantities involved in the Heisenberg Uncertainty Principle?
The Heisenberg Uncertainty Principle involves two quantities: position and momentum. These quantities are complementary, meaning that the more precisely we know one, the less precisely we can know the other.
4. Why is the Heisenberg Uncertainty Principle important?
The Heisenberg Uncertainty Principle is important because it fundamentally changes our understanding of the physical world. It shows that there are inherent limits to our ability to measure and predict the behavior of particles at the quantum level. This has implications for various fields such as quantum computing, chemistry, and astronomy.
5. Is the Heisenberg Uncertainty Principle a fixed limit?
No, the Heisenberg Uncertainty Principle is not a fixed limit. It is a fundamental principle that describes the behavior of particles at the quantum level, but it does not mean that we can never know anything about a particle's position and momentum. It simply sets a limit on the precision with which we can know these quantities at any given time.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Interpretations and Foundations
  • Quantum Physics
