I Quantization of the electromagnetic field
Konte
TL;DR Summary
quantization, electromagnetic field
Hi everyone,
It is about the quantization of the electromagnetic field. The expression of field E and B are defined with:
-the annihilation a- and creation a+ operators, and the frequency ω.
So my question is: how does these fields must be expressed if they where "static"? I mean, how the electrostatic and magnetostatic fields must be expressed in quantized version?
Thank you.
Konte
Konte said:
Summary:: quantization, electromagnetic field
Hi everyone,
Thank you.
Konte
In quantum theory a "situation" is described by the state, not by the operators describing observables.
Here's a rough sketch of how this problem is solved, using a scalar field instead of a vector field for simplicity.
We start with the KG Hamiltonian with a spatially-dependent source ##J(\mathbf{x})##:
$$H = \int d^{3}x ~\frac{1}{2}\pi^2 + \frac{1}{2}(\nabla \phi)^2 + \frac{1}{2}m^2\phi^2 + J\phi.$$ Rewrite the Hamiltonian in terms of a new field ##\psi## related to ##\phi## via
$$\phi = \psi + K(\mathbf{x}),$$ where ##K## is some fixed function. If we choose ##K## such that
$$-\nabla^2 K + m^2 K +J = 0,$$then (after integrating out surface terms) the Hamiltonian will simplify to
$$H = \int d^{3}x ~\frac{1}{2}\pi^2 + \frac{1}{2}(\nabla \psi)^2 + \frac{1}{2}m^2\psi^2 + ...,$$ where the ommited terms depend only on ##K##. The important point is that now the linear term is gone and we can expand via creation-annihilation operators as if the field were free.
The groundstate of the field in the presence of ##J##, which I will call ##|\Omega\rangle##, is defined by $$a_\mathbf{k} |\Omega\rangle = 0$$ where ##a_\mathbf{k}## is the annihilation operator associated with the field ##\psi.## Now ##a## is related to the annihilation operators of the original field ##\phi##, which I will call ##b##, by some relation along the lines of $$a_\mathbf{k} = b_\mathbf{k} - f(\mathbf{k})$$ where ##f(\mathbf{k})## is some c-number. You can figure out what ##f(\mathbf{k})## should be exactly from the second expression above if you feel so inclined (I don't). In any case the definition of the groundstate ##|\Omega\rangle## can now be rewritten as
$$b_\mathbf{k} |\Omega\rangle = f(\mathbf{k})|\Omega\rangle,$$ which means that ##|\Omega\rangle## is some coherent state of the free theory.
Likes Konte, gentzen, mattt and 1 other person
I have a little question that answer can surely help me to understand more: how do we express the interaction term (in the Schrodinger equation) with electrostatic field in the "Stark effect" case when we treat the field as quantized field ? In semi-quantum case, it is only expressed as the product of dipolar moment with classical electrostatic field : ##\mu . E##
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
