Quantum Connection vs Entanglement: What's the Difference?
In summary, "quantum connection" and "quantum entanglement" are two different terms, with the latter being more established and commonly used. The term "quantum connection" is not widely used and may be a mis-translation or an attempt to be clever by a journalist. Both terms relate to the coupling of two qubits for use in quantum computing, but "quantum entanglement" is a more specific and well-defined term. More information can be found by searching for "quantum entanglement" on Google or Google Scholar.
louislaolu
TL;DR Summary
quantum connection vs. quantum entanglement
different or the same?
Do they mean the same?
Are there any differences?
Is the second one more common/newer/more standard than the first one?
Could someone please answer these questions or recommend something to read?
"Quantum connection" seems vague to me. It would have some relation to entanglement but I have no idea with confidence what it is. I would take it as quantum coupling of two qubits and using them as one system for quantum computing. Quantum entanglement is more established term as you can find some explanation in wiki or other sources.
louislaolu said:
TL;DR Summary: quantum connection vs. quantum entanglement
Where did you see the term quantum connection?
Likes vanhees71
Thanks a lot! Yes, searching Google for Quantum entanglement gives much more hits.
louislaolu said:
Transmission of information by quantum entanglement​
http://www.journalnano.org/?p=452 (the paragraph below Fig 3)
This is not a valid source for discussion here. The paragraph below figure 3 is wrong in any case. Journalists aren't physicists!
I actually came across 量子联系 (literally translated as quantum connection ) in the Chinese version of the science fiction The Three Body Problem. It was changed into quantum entanglement in the English version. I am trying to figure out the change.
"Quantum connection" is not a widely used term (in fact, it is the first time I've seen it and I've been doing this for quite a while), it sounds either like a journalist trying to be clever with his/her choice of words, or a mis-translation.
"Quantum entanglement" is a widely used, well defined term
Likes Lord Jestocost and vanhees71
Thank you for your reply! It helps me a lot.
