Quantum decoherence and the emergence of space/time and gravity
In summary, the current research is attempting to determine how the properties of continuous time/space and gravity emerge from the Quantum smallest scale.
shunyadragonvv
TL;DR Summary
Quantum decoherence. and the emergence of continuous space/time and gravity
Does continuous space/time occur in Quantum smallest scale?
In another forum I have experienced a lot of combative dialogue asserting that continuous time/space is a property of the smallest Quantum scale. My present knowledge indicates this not true, and that the goal of the current research is determine how the properties of continuous time/space and gravity emerge from the Quantum smallest scale. I would like some feed back on this issue.
I realize this is a controversial subject as to how the emergence of time/space and gravity happen, but I did not believe that the concept of decoherence and that the large scale properties of continuous time/space were emergent properties of the Quantum smallest scale is controversial.
We don't have a confirmed theory of quantum gravity, so we have no way of answering your question. All we have are various theoretical hypotheses that are being pursued with ongoing research.
Likes dlgoff, vanhees71 and Dale
The question concerning Quantum Gravity is only part of topic. That would be simple based on the present evidence. Has gravity of the large scale been observed in Quantum particles? I fully realize the theoretical limits, and concerning this thread I am interested in the current knowledge of the concept of deconherence as to the nature of time at the Quantum smallest scale. Has any form continuous time of the large scale been observed as the smallest Quantum particle scale.
The
No. Individual particles are many orders of magnitude too small for any gravitational effects from them to be observable.
I don't know what you mean by this. We have seen no evidence of lack of continuity in spacetime at the smallest scales we can probe. Is that what you're asking?
Likes vanhees71 and Dale
There have been some very preliminary experiments (preliminary but still quite interesting) on quantum particles in gravity fields. This is by no means getting anywhere close to gravity arising at quantum-level dimensions. So it is not an answer to the OP's questions in that regard. It only gets to quantum particles being individually affected by gravity.
Sadly, I don't have any links for either of these.
There have been some attempts to see if anti-particles fall at the same rate as particles. As far as I recall, the results were that they do, but the level of accuracy was very poor. This was a test that I remember from a seminar when I was in uni. They were dropping anti-protons. (Fermi lab? Not sure.) The issues were to get an experimental device that had weak enough electric and magnetic fields to let them drop a useful distance, and compare to regular protons. They had not entirely solved this, so the charged particles tended to get flung in unhelpful directions.
There have also been some experiments where a particle loses energy by rising through a gravity field, and so it has a very tiny little difference in energy that does interesting interferometry things. This was over-a-beer talk with a guy that was doing it for his PhD.
Yes, experimental limitations at this time make it very difficult to get good accuracy for these experiments.
The experiment I'm aware of along these lines was done with neutrons, and basically tests whether the Newtonian gravitational potential due to height acts the same way as any other potential in the non-relativistic Schrodinger Equation. The results indicate that it does, but this is just testing standard non-relativistic QM with a gravitational potential. It is not testing any quantum aspects of gravity itself.
PeterDonis said:
No. Individual particles are many orders of magnitude too small for any gravitational effects from them to be observable.I don't know what you mean by this. We have seen no evidence of lack of continuity in spacetime at the smallest scales we can probe. Is that what you're asking?
I agree. The subject relates to the problem of the mergence of time from entanglement of Quantum particles. I believe recent research supports this.
What research are you talking about? Do you have any references?
Likes vanhees71
Quantum (Field) Theory as we know it and how particles are described is strongly based on a given spacetime structure, both in non-relativistic QM and special-relativistic QFT. The latter methods can be generalized to some extent to quantum field theory in "curved spacetime", i.e., in a given (classical) general-relativistic spacetime manifold. The quantization of the spacetime model itself so far has not been successful.
Answer to a formula and relevance to emerging time.
Formula attached
  • formula.docx
Formula attached
Formulas in attachments are not allowed. Please use the PF LaTeX feature to enter formulas directly in your post. There is a "LaTeX Guide" link at the lower left below each post window.
I solved it myself
The formula I could not post/
Are you going to post your solution?
